Nothing moves when record selected
Awhile ago the jukebox was putting a record awayinto the carousel and it didnt line up properly and corousel wanted to turn, I pulled back on the grab bar to let the carousel turn and something broke? now the turntable turns continuously and nothing moves when a song in selected, I have a 1976 Rowe ami R 81 jukebox. I would prefer to pay to have it fixed but cannot find a serviceman to come to the house, I live in LaGrange Ohio, any helpers out there
    Champion:
    Habit-Forming:
  • 239 Answers
You're too far away for me so i would suggest getting another mech
Posted on Aug 09, 2014
3 Suggested Answers
  • 195 Answers
SOURCE: 45 (record) Jukebox. While playing the jukebox
Have you checked all the fuses or circuit breakers on the jukebox?
Are all the power supply led's lit?
Make sure that all the connection plugs into the boards are fully seated and making good connections.
After checking the above if the fault remains you will need to contact a Wurlitzer service engineer.
Regards
Alan Hood
ami-man
UK
Posted on May 26, 2011
  • 77 Answers
SOURCE: rowe ami r80 jukebox is exepting selections but keeps reapeating
I don't have a manual handy but it could be a few things, you may need to reinitialize the jukebox, maybe there is a dirty wiper or the control module may be on its way out. I would try to locate a repair manual for it, there might be an old vending company in your area with one.
Posted on Nov 28, 2012
My Rockola Tempo 1, just stopped mid record. Previously the carousel would slow down/hesitate at a certain point when selecting, but never stopped. Switched it on occasionally, with no movement.
I would put money on the belt snapping. 5 years is about right. Especially if you do not use it often. The slow down and hesitate is even more indication of a belt getting hard and then slipping and snapping. They need to keep moving to stay soft. Get a new belt and you will be likely good to go.
Oct 16, 2016 | Wurlitzer Rock-ola Jukebox
Sound leisure vinyl jukebox Model Nostalgia 1015 Fault , rotates several times after selecting record , stops at wrong record and does not select record from carousel Please can help
the selector switches are black corroded by now
and need cleaned and the plateing restored with plating fluid
take it too a restore person
Dec 21, 2014 | Audio Players & Recorders
Jukebox lights work - when turned on the record carousel does not reset and the LED display does not work and records do not play
The problem could be the selection and credit computer or possibly the K7 switch actuator. I can repair the computer and I stock the K7 switch actuator. Please email tech@wurlitzer-ohio.com
Jan 12, 2011 | Wurlitzer Jukebox 1015 One More Time...
Jukebox 1015 One More Time 100-Disc CD Changer: The turntable that holds all the records will cont...
There is a smal light at 6 oclock on the edge of the record carousel about the size of a torch bulb. If it isn't lit, that's your problem.
Dave F
May 17, 2010 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 3600 series wont select a record ?
If the buttons don't latch in, the machine is not in credit. Put on free play or put some money in.
Dave F.
May 30, 2009 | Wurlitzer Jukebox 1015 One More Time...
45's records won't turn and prior to that they only played side B
There's a motor under the back of the carousel about 11 oclock. You can see the drive gear if you bend down and look under the toothed base of the carousel. If you press the lever to rotate the carousel you'll be able to see if the motor is turning or not. If it is turning but the carousel isn't moving you could have a stripped nylon gear.
Oct 25, 2008 | Wurlitzer Jukebox 1015 One More Time...
Record Changer Arm
When the carousel reaches the correct count, the computer sends a signal to the gripper motor to start it. You could have a bad motor or a bad computer. But!....if the little switch at the front of the machine is in the off position (Gripper motor On/Off) that will give exactly the same effect. It's easy to knock Off when you are loading CDs.
Oct 02, 2008 | Wurlitzer Jukebox 1015 One More Time...
Rowe ami jukebox
Check the optical sensor, it may be blocked with dust.
Jun 09, 2008 | Audio Players & Recorders
The microswitch at the base of the gripper arm is what enables the scan motor when the gripper is over the carousel. You will probably find that the small lever on the base of the tone arm is not clicking the microswitch properly.
Dave .
May 20, 2008 | Wurlitzer Jukebox 1015 One More Time...
 Grubhead
Grubhead
