Question about Martin Yale 2051 Smart-Fold Paper Folder
Error code 101
When you press start to run the job, there is a click and it stops without pulling any paper. It give error code 101. We turned it on and off and reset the fold and paper size.
How to stop printing once it has started
For Brother Laser Machines. Start by pulling the paper tray out a little. This allows the page that is currently feeding through the system the chance to get through without jamming causing a whole slew of other problems.
Once the printer has stopped trying to feed the pages through coming up with an error saying paper out then you can look at deleting all the print jobs in the print queue on your computer. All but the one currently being printed should disappear when you delete them. The one that is left will be errored.
Then turn your printer off for 30 seconds closing the paper tray and try to delete that last job from the queue.
If it will not go then turn your printer back on and let the last couple of pages print out. these are pages that are stuck in the system. If the print job did disappear then just turn on your printer as normal and it should be clear of any jammed printing and you don't end up with Paper Jams in the printer to clear.
Sep 06, 2014 | Brother HL Office Equipment & Supplies
Canon ipf605 paper error
Here is what I've found out by trial and error.
Paper Roll Won't Load:
    -Usually occurs when the roll is less than 50% full
    -Printer will give the error "paper loaded askew"
    To Correct This:
      - Press and hold Stop until Job Cancel comes up on the
      screen
      - Press Menu
      o Scroll Down until Adjust Printer menu comes up
      o Press right side arrow next to OK button
      o Scroll down to Manual Band Adjust and press right side
      arrow again (or select one of the other adjustments)
      - Select Yes and press OK
      - Load paper roll - make sure paper is straight
      - When asked (printer will beep) select Plain Paper and
      press OK
      - Let paper load
      - When printer starts to print press and hold Stop to cancel
      job
      - Paper should now be loaded
      When all else fails load a new roll.
      This would be a temporary solution until the sensor is fixed.
Mar 12, 2012 | Canon imagePROGRAF IPF605 InkJet Plotter...
Error 6502 came up on my viewing box and I cant get it to clear. I dont know what caused it exactly. I had a paper jam and I pulled the paper out of the rollers to clear it now I have error 6502 and I dont...
Pls do the following :-
Error code 6502 The Error code 6502 can occur in the printer as a result of ink tubes caught under housing and jammed the print head against the right hand side of the printer. The printer is unable to do anything now and it will give an alarm light only. To fix this issue, you need to unplug the printer and then plug it back. You need to press and hold the power button of the printer and click the Stop button twice. You can then release the Power button and press Stop button for four times. The issue will be fixed and you can start your print jobs.
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 28, 2011 | Canon MX700 Office All-In-One InkJet...
Out of paper issue
Instead of restarting, try this:
1. Start
2. Run
3. Type this in the box: services.msc
4. Hit ENTER
5. Scroll down to PRINT SPOOLER
6. Right-click on it and choose RESTART
this will clear out your print queue without having to restart. Good luck!!
Hi this is the more effective way to refresh the print queue.
Manually Stop and Restart the Spooler Service
1. Click Start, click Run, type command, and then click OK to display the command.com window.
2. Type net stop spooler, then press .
3. Type sc config spooler depend= RPCSS start= Auto, then press . The spaces between = and RPCSS and = and Auto are important. Without these spaces, the command fails.
Type net start spooler, then press
NARENDER KUMAR RANA
narendertacl@gmail.com
narendertacl@yahoo.com
narendertacl@hotmail.com
Nov 15, 2009 | Kodak EasyShare Printer Dock Series 3
My Aficio 4006 says SC 450
SC450 Paper Transfer Bias Current Leak
There is a charge placed on back of paper as it exits the drum, it is placed on the back of the paper via a charge roller/carona or sometimes a bar of little teeth ie VVVV....its job is to make the now formed pic on the drum come away and be attracted to the paper
This charge is not traveling along the intended path, check the bed are is clean and check the transfer/seperation carona, make sure it and the grid is clean and the wire is intact and not shorting at either end block to frame.
Nov 07, 2009 | Ricoh Office Equipment & Supplies
Uncleared print job HP J5780 I'm pulling my hair out trying to print to my HPJ5780. With a failed manual duplex job, I tried to delete the print job from the queue. It came up fine as deleting - however...
Try stopping the print spooler service and canelling all the documents.
The Windows Print Spooler is a Windows XP "Service". You can start/stop it via the following steps:
  1. Click on the Start button
  2. click on Run
  3. enter "services.msc" without the quotes and press Enter
  4. Scroll down to Print Spooler
  5. Single-Click on Print Spooler
  6. The details will open in the middle of the window.
    • It probably shows Start -- if so, Start it.
    • If it shows Stop and Restart, I suggest Stop it, then Start it.
Jul 16, 2009 | HP Officejet J5780 All-In-One InkJet...
E 2 and service error 5100 on Pixma mp160 printer
You can try to clean out the printer check to see if there is any paper jammed in it somewhere
Then realighn the printer cartridges and run a test page.
Make sure that the paper tray is not overloaded
Dec 24, 2008 | Canon PIXMA MP160 All-In-One Printer
Ysstem will not back up, transient error, code 0X800423F3
1) Start the computer and press f8 on boot up and select 'Safe Mode without networking'.
2) In the start menu type 'cmd' (without quotes) and on the top search result right click the program and choose 'run as administrator'
3) Type "net stop winmgmt" without quotes and press enter to make certain the WindowsManagementInstrumentation (WMI) service is not running.
4) In the start menu click 'computer' on the right hand side. Go to the windows\system32\WBEM\ folder and rename the Repository folder to something else like OLDRepository (right click and choose 'Rename Folder'.
5) Reboot and restart as normal.
6) In the start menu type 'cmd' (without quotes) and at the top right click the program and choose 'run as administrator'
7) Type 'net stop winmgmt' (without quotes) and press enter to stop the wmi service.
8) Type 'winmgmt /resetRepository' (without quotes) and restart the system.
Reference: http://www.vistaforums.com/Forum/Topic14017-9-1.aspx
Jul 13, 2008 | Computers & Internet
Brother IntelliFax 1840C
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If that doesnt give you the code then try going into service mode by pressin menu key then *, 2 , 8, 6, 4  super quick!! Display goes blank or Maintenence mode is displayed, if not... not quick enough, do again to you get it, then press 77 start, error should display. press 99 to exit Maintence mode, dont play with other numbers!!
a couple of the most common errors are
Error 41 needs new print head costly
error 46 waste ink full, need new waste tank
Whats yours?
Oct 30, 2007 | Brother IntelliFAX 1840C Plain Paper...
Check paper light blinking and "E" code
trying to print the las job you had.
Try hiiting the cancel button when you turn it on
Oct 22, 2007 | HP PSC 1315 All-In-One InkJet Printer
Martin Yale 2051 Smart-Fold Paper Folder Logo
332 people viewed this question
Top Martin Yale Office Equipment & Supplies Experts
gbob59
1Teddybear
1Teddybear
Tom Chichester
Are you a Martin Yale Office Equipment and Supply Expert? Answer questions, earn points and help others
