Question about Vehicle Parts & Accessories
I DO NOT KNOW HOW TO REPLACE MY DISTRIBUT OR CAP
FIRING DYEFRAME
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 65 Answers
Why do you need to replace your distributor? - to replace the cap, carefully offer it alongside the old cap in position and make sure the clip points are in the same place, then start to pull out one wire at a time into the new cap in the same hole position as the fixed cap, when all leads are in, remove the old cap, fit a new rotor arm by pulling up and pushing in the new rotor.
Posted on Mar 29, 2014
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Mazda 323 firing order, is it clockwise on distributor cap
on the four stroke right hand ( clockwise ) turning engine the firing order is 1-3-4-2 but there are some exceptions on European model. The firing order is also clockwise set because your engine is right hand turn. For you if you like to see also what I stated you can remove the distributor cap if you know how,and by starting the engine you will see the rotor arm turning clockwise.
Jul 05, 2014 | 1993 Mazda 323
1989 f 150 loss of power in 2nd and misses the hole time..it has a 5.0 changed plugs wires cap and button and coil...dont know what else to do
if you already did a tune up, make sure you have the correct firing order. Ford made 2 different 5.0 one was for the mustang another for the truck. the mustang 5.0 firing order started 1,3,7,2,6,5,4,8 the truck firing order if I can recall correctly started 1,5,4,2,6,3,7,8. also might want to check or replace fuel pump.
Sep 22, 2011 | 2000 Ford Focus
I have a Chevy 2500 pick up truck. My son thought he'd replace the spark plugs. He removed the distributor cap, didn't understand it and now the truck won't start. He did not replace any spark...
firing order for 5.7 v8 is 1-8-4-3-6-5-7-2 mostly all of the chevy v8s are the same firing order. the rotor button in distributer turns clockwise, the cylinder numbers are 1-3-5-7 on drivers side, 2-4-6-8 is on passengers side. To get started get your distrutor cap[new one] look on the top you will see a #1that's where you begin you must know if if rotates clockwise or counter clockwise start in that direction then follow the firing order and cylinder line up. good-day!! if cap is not marked, just pull out #1 plug, put a straw or similar in plug hole on top of piston. turn engine over by crank in front of vehicle with a wrench, when the piston comes to the very top just before it starts going down. this is tdc. and rotor button should be pointing to #1 wire on dist, cap. follow from there. good-day !!
Aug 09, 2011 | 1994 Chevrolet Silverado 2500
Need to know the firing order for a 1982, 1.9 chevrolet S-10 four cylinder,and where is #1 on the distributor cap?
the firing order # is 1342, and the # 1 firing postion on the distributor cap should be at the 5 o clock position on the cap. this is according to the manual that i have. because the rotor turns counter clockwise. if you have any doubt, remove the #1 spark plug , and distributor cap , and bring the # 1 piston up on top dead center of the compression stroke, and the tip of the rotor will be facing the # 1 firing position.
Feb 13, 2011 | Chevrolet S 10 Cars & Trucks
How do i know my firing order is right first do i make sure my # one plug is up first
Yes. Bring number 1 piston to top dead center of the compression stroke. Remove the distributor cap and see which post on the cap the rotor button is pointing to. This is where the number 1 plug wire goes. Follow your firing order on the cap in the same direction the distributor turns and your firing order will be right.
Feb 01, 2011 | 1991 Chevrolet S-10
1995 Altima: what is the cause of oil leak around the distribut...
change the oil ring inside the distrbutor and change a new one
May 18, 2010 | 1995 Nissan Altima
My 93 rodeo is firing on 5 6 cl only
Its only a 6cyl so is it firing on 5 or 6? If 6 then its fine, and also if you know its only firing on 5 you should know which 1 isnt firing right? Start with the pplug/lug wires, distributer cap and rotor..
Mar 23, 2010 | 1993 Isuzu Rodeo
98 dakota 2wh drive 3.9 replace rotor & cap
Check this 1998 Dodge Dakota 2WD 3.9 liter V-6 VIN "X"
Good luck.
Jan 16, 2010 | 1998 Dodge Dakota
Firing sequence/numbering on distributor cap of Landrover Discovery 1, 3.9lit V8, 1998 model
Firing order is 1-8-4-3-6-5-7-2 Cylinder numbers looking at engine from front Left Bank 1-3-5-7 Right bank 2-4-6-8 Distributor has clockwide rotation,
Apr 26, 2009 | 1998 Land Rover Discovery
I need to install a distrubuter, need to know how to find top dead centre etc.
Distributor Cap grey_line.gif Inspect | Replace The distributor cap should be removed for visual inspection. Check the cap for:
Inspect the distributor cap and rotor. Courtesy of American Honda Motor Co., Inc.
  • Distributor cap locating tab. This tab assures proper location of the cap onto the distributor housing.
  • Distributor cap holddown. The distributor cap must be securely attached to the distributor housing to prevent contamination and to assure its location.
  • Dirt and water in the cap. These contaminants will require additional voltage in order to fire the spark plug. If available voltage is not enough to overcome this resistance then no spark will occur at the spark plug.
  • Center carbon insert. All of the high voltage coming through the coil on its way to the spark plug must pass through this insert. Any additional resistance caused by wear or contamination can cause the engine not to start or to misfire.
  • Tower inserts. The inserts are made from aluminum or bass so it is possible for them to oxidize. Aluminum oxide is an abrasive that can cause excessive damage to the distributor. If the insert is made from brass then the oxidation will appear green in color.
  • Cracks. If any cracks are present on the distributor cap then replacement of the part is required.
  • Carbon tracking. Carbon tracking indicates that the high-voltage of electricity has found a low-resistance conductive path over or through the plastic. The result is a cylinder that fires at the wrong time, or a misfire.
Also check for:
  • Physical or electrical damage is easily recognizable.
  • Electrical damage from high voltage can include corroded or burned metal terminals and carbon tracking inside distributor caps.
Things to look for when inspecting a distributor cap.
  • If the distributor cap has a mild buildup of dirt or corrosion, it should be cleaned. If it cannot be cleaned up, it should be replaced. Small round brushes are available to clean cap terminals.
  • Wipe the cap and with a clean shop towel, but avoid cleaning these components in solvent or blowing them off with compressed air, which may contain moisture. Cleaning these components with solvent or compressed air may result in high-voltage leaks.
  • Check the distributor cap and housing vents. Make sure they are not blocked or clogged. If they are, the internal ignition module will overheat. It is good practice to check these vents whenever a module is replaced.
Replace Distributor cap replacement instructions vary, so always follow the manufacturer's instructions.
General replacement procedures are as follows:
  • For spring-loaded caps, unsnap the clips and remove the cap. When installing the new cap, make sure the clips are snapped back into place.
  • For spring-loaded j-hook caps, push down and turn. It will unlock. Lift up to remove it. Position the new cap in place, then push down and turn to lock.
  • For caps with screws, use a screwdriver to loosen the two screws. Install the new cap and use the screwdriver to tighten the screws. Don't overtighten.
It is a good idea when replacing the distributor cap to remove the cap with the ignition wires attached. After you have installed the new cap, transfer the wires one by one onto the cap in their correct position. This way the firing order is accurate. If, for some reason after you replace the distributor cap, your vehicle does not function normally, check your firing sequence.
The distributor cap is mounted on top of the distributor assembly and an alignment notch in the cap fits over a matching lug on the housing. Therefore the cap can only be installed in one position, which assures the correct firing sequence. There is a tab or notch somewhere on the distributor body that must align somewhere on the distributor body that must align with a corresponding tab or notch in the cap. Once again, do not force something.
The rotor should be inspected and/or replaced when the distributor cap is replaced.
Firing Order Each cylinder of an engine must produce power once in every 720 degrees of crankshaft rotation. Each cylinder must have a power stroke at its own appropriate time during the rotation. To make this possible, the pistons and rods are arranged in a precise fashion. This is called the engine's firing order. The firing order is arranged to reduce rocking and imbalance problems. Because the potential for this rocking is determined by the design and construction of the engine, the firing order varies from engine to engine. Vehicle manufacturers simplify cylinder identification by numbering each cylinder.
Examples of typical firing order.
Regardless of the particular firing order used, the #1 cylinder always starts the firing order, with the rest of the cylinders following in a fixed sequence. The ignition system must be able to monitor the rotation of the crankshaft and the relative position of each piston to determine which piston is on its compression stroke. It must also be able to deliver a high-voltage surge to each cylinder at the proper time during its compression stroke. How the ignition system does these things depends on the design of the system.
Nov 19, 2008 | Ford F Cars & Trucks
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
