Set up Sony hcd-flx5d Home theater to work on As sound system and get audio from Samsung Led
Trouble with setting up home theater with samsung led to work as sound system
skotkolr
  • 558 Answers
SOURCE: HOME THEATER SYSTEM SET UP
75 ohm coax cable generally does not carry 5.1 surround, you may need to see if your cable box has a 5.1 surround capability, the cable company will be able to help you on that .one other thing the receiver you are using (distribution) may need to have the source changed to the one from the cable box ie. fiber optic or coaxial (orange rca plug). red and white from the cable box does not carry 5.1 surround, only stereo. thanks for using fixya!
Posted on May 28, 2008
ginko
  • 19396 Answers
SOURCE: sony home theater system started blinking protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
ginko
  • 19396 Answers
SOURCE: No home theater sound
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Bad speaker wiring.
Internal fault.
Regards.
  • 336 Answers
SOURCE: need to connect some samsung audio/video components
I'm guessing that you would like all your components to play audio through the HTZ320. In order to get audio from all these components you will need a digital optical cable from the tv optical out to the HTZ320 optical input. And some composit audio cables (red and white) from tv audio out to the HTZ320 aux input. The video and audio from the dish box, bluray, and the vcr are all going to have to go through the tv first and then to the HTZ320. Use HDMI cables to connect the dish box and the bluray to the tv inputs and composit cables (red white and yellow) from the vcr output to the tv input. If you can give the exact model of the tv I can help you sort things out further. I hope this helps you.
Posted on Aug 27, 2009
Sony DAV-IS10 doesn't get video and sound from Samsung 3D Blu-ray Player.
change the input settings on the SONY. sometimes there are are HDMI INPUTS AND OUTPUTS on high end systems. Make sure you are in INPUT
Mar 10, 2014 | Sony DAV-IS10 System
Sony HCD FLX5D not turning on
I know Ashish you fixed it but which transistor was it? Can you please let me know as i have the exact same problem....
Jan 05, 2014 | Audio Players & Recorders
I have a new samsung 40" led tv and i have
The specs say that it has an optical audio in on your home theater system. So the easiest way to hook up is to connect the optical audio out of your tv to the optical audio in of your home theater system and walla! What ever play on the tv will play on the home-theater system. You are looking for a Toslink optical audio cable
http://cgi.ebay.com/6-OPTICAL-FIBER-OPTIC-TOSLINK-DIGITAL-AUDIO-CABLE-6-FT-/370402436177
Jul 14, 2011 | Samsung UE40B7020 40 in. LED TV
Completed set up however sound only from front two speakers. ie no sound from centre speaker or rear speakers. Please tell me how to set sound to 5.1 I have a Samsung LED/LCD television
The television should be an output device for video, not a source of audio. IT gets its program material from higher up the food chain and so your audio should originate there, too.
Is 650w the model? Maybe HT-C650W? If you have the manual (I don't) find where it talks about digital audio connections from external sources. The cable box or whatever you want to watch will probbaly have a digital audio output. If you run THAT to the Samsung it might process it to multichannel.
Dec 26, 2010 | Samsung 650W 5.1-Channel Home Theater...
Cant get led tv to play sound through surround sound on blu ray
you have to have a connect going back into the player, the hdmi is only one way there should be and analog the red and white
or
an digital optical out from the tv
May 08, 2010 | Samsung HTC550 Theater System
I keep getting the 'rear check' message on the tower panel display and all cables are connected what could this be this is on my new HT-TXQ120 DVD HOME THEATER SYSTEM
With the home theater system off, press and hold the REMAIN button on the home theater's remote control for 5 seconds.
Note: You can release the REMAIN button when the POWER LED blinks blue.
With the wireless module turned on, use a ball point pen to press the RESET button on the back of the wireless module. The POWER LED in the front of the home theater blinks two times.
Turn on the home theater. The LINK LED on the front of the SWA-3000 changes from red to blue, indicating the wireless module has connected to the home theater.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Jun 29, 2009 | Samsung HT-TXQ120 Home Theater System...
Can't get the Samsung HT-z310 Home Theater to stay on AUX2
you need a fibre optical cable for this, simply you connect that from your dvd to tv and then set the input on the dvd to digi in. i have exactly same home cinema system.
Nov 27, 2008 | Samsung HT-Z310T Theater System
Home Theater - sound
If it is a new set up, make sure properall connector are properly connected. Have you tried removing the Bose just to isolate the trouble, just to pinpoint the source of that HUM. The sony is amplifying some unwanted signal.
Dec 21, 2007 | Samsung LN-T4665F 46 in. LCD Television
Swa3000
  1. With the home theater system off, press and hold the REMAIN button on the home theater's remote control for 5 seconds.
    Note: You can release the REMAIN button when the POWER LED blinks blue/Red depending on model.
  2. With the SWA-3000 turned on, use a ball point pen to press the RESET button on the back of the SWA-3000. The POWER LED in the front of the home theater blinks two times.
Feb 14, 2007 | Samsung HT-Q70 Home Theater System System
22 people viewed this question
 Grubhead
Grubhead
