Question about T-Mobile Wing™ Smartphone
My wing got water damage. I let it dry and everything works but it does not get signal. it keeps saying searching and flight mode back and forth. is there a fix for this or do i just need to trash it.
You just need to trash it the signel in f**ked!
Posted on Jun 15, 2009
Maytag Dryer Error code F-02
Somewhere in the instructions for your Maytag dryer there is a comment or direction to rotate the timer knob only clockwise. Otherwise you shorten the timer's working life considerably and wind up having to replace it.
Mar 18, 2014 | Maytag Dryers
How do you get the t-mobile wing out of flight mode
Flight mode is when you prevent your phone from receiving calls. click on where it says wi-fi:on/off and then click on the one that says phone. It will ask you for your pin if you set a pin for your sim.
Jan 02, 2010 | T-Mobile Wing™ Smartphone
Maytag washer won't shift to rapid spin dry (only slow back & forth)
Hi Jim, you issue could be caused by a couple either one of a of the following,
1) Draining problem, cant empty the water from the machine within the prescribed time limit - preventing the spin programme to commence. check pump filter is clear and waste water is pumping from the end of the waste hose, the hose itself could be blocked with limescale and detergent residue.
2) Unbalanced load, most machines wont spin 1 item, its a safety thing, if a machine spins with one heavy item it puts the drum out of balance resulting in excessive drum movement possibly damaging the inside of the machine and put indue stress on the bearings. Try putting it on a spin cycle with no clothes in
Unbalanced load detection can also be caused by a faulty motor tacho, this usaually positioned at the rear of the motor, this sends an electrical signal to the programmer telling when it is 'Safe' to spin. There also the posibility that the programmer is not reading the tacho signal or misinterpriting it.
May 20, 2009 | Maytag Washing Machines
VIZIO VO42LF says no signal when connect to PC after power on/off
Could be a sensitivity problem, have you tried to switch tv modes back and forth, sometimes if you do that it will save you from restarting the computer. I had a tv about 10 years ago that had a sensitivity issue, went to see about fixing it, unfortunately, the tv brand was no longer in the country and user service parts were not available.
Apr 11, 2017 | V, Inc. Vizio P4 Plasma Television
No network coverage/can't turn off flight mode
Sounds like your phone is stuck in flight mode for some reason. Have you tried a Master Reset (you will lose all your personal data if you do this).
Nov 16, 2008 | Sony Ericsson W760i Cellular Phone
My lg vx8300 phone
Go to settings and change the normal mode and re staret the phone settings will actvate.
Jun 24, 2008 | LG VX8300 Cellular Phone
FLIGHT MODE
start and home button in the same time (when the phone is turned ON)... than select OFF to flight Mode.
May 03, 2007 | Motorola Mobility MPx220 Pocket PC
T-Mobile Wing™ Smartphone Logo
88 people viewed this question
Top T-Mobile Computers & Internet Experts
ismael castillo
Marvin
Marvin
Edward Talavera
Edward Talavera
Are you a T-Mobile Computer and Internet Expert? Answer questions, earn points and help others
