TV makes all the right noises when it is plugged in. Clicks from standby as if it will power up then switches itself back off.
  • 700 Answers
If this is a crt type tv, you might having a high voltage circuitry faulty, either shorted diode, shorted HOT, or shorted flyback.
In general you have an overloading or short.
Posted on Jun 15, 2009
I have a RCA 42" model 42pa30rq and i was watching the tv and the picture goes out. I was trying to trouble shoot the tv on the y and x board but the x board is connected to the y board but still no type...
How much lld are you? How many Plasma sets did you repaired so far? Do you think repairing a plasma TV will be very like eating a ripe banana?
Contact any well experienced service technician; man.
"YOUR WORDS above REFLECTS YOUR IGNORANCE IN SERVICING SUCH ADVANCED TECHNOLOGY SETS.
What else to say? http://electronicshelponline.blogspot.com/
Oct 12, 2016 | RCA Televison & Video
I have a flat screen plasma TV. We were watchin a movie & I hit pause on the DVD player & the TV turned off. We have unplugged it & plugged it back in, it clicks & the standby light blinks 5 times.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window".
Aug 11, 2015 | Televison & Video
Tv won't turn on- its in standby mode. the young lad had the remote before it was turned on.... could he have pressed somethin on the remote which is now preventing it from coming on?
Powering up do you hear the relay click then you may see the display flash (not necessarily), but then the TV clicks back into standby mode. If so there is a component failure.
will need diagnosis by a repair shop. Too many different components it could be for me to guess. but
the common repair kit containes1 fuse (F302), 1 diode (D304), the power resistors (R927 and R929 for the board revisions with these two resistors) and the IC301 voltage regulator IC.
Feb 21, 2018 | LG 50PJ350 50 in HD-Ready TV
Lg 50pk550 wont turn on
Repair kit Now available on Ebay.. BUY NOW
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=200884727409
If you have any one of these LG Models TV below, and all of a sudden, the screen lights for only a few seconds, then goes into standby with a clicking noise. [Stuck in standby] When you try to switch it on, it tries but then just clicks and goes back to standby? In this video, I show you the components that goes bad, and the culprit that causes it all. The power supply board has already been bought from Ebay, but I'm still selling the voltage regulator that is dang near impossible to find on ebay, as well as the REPAIR KIT for this power Supply Board. Board model number EAY60968801. With any one of these PCB # EAX61392501/7, EAX61392501/10, EAX61392501/11, or EAX61392501/12 Please Make sure that you've already gone through the process of troubleshooting and testing your tv's power supply board before making any purchases.. I recommend that you get a tv tech to check it out, because every tv is different. Remember, the component, and the repair kit will only repair power supply model (EAY60968801) with the appropriate PCB numbers. You buy at your own risk
Mar 10, 2012 | LG 50PK550 50 in. TV
TV turned off by itself and now it won't turn back on
If the tv has nothing happening at all when you try and turn it back on including any noise, your power supply is broken. If it is still trying to turn on or does make noise, an internal component has come loose or been knocked off, most likely to your picture tube.
Dec 25, 2008 | Televison & Video
Set wont turn on red light just keeps blinking
this is a malfunction of the power supply block (inside your TV-device),or over load of it.please contact the nearest repair shop.
Aug 08, 2008 | Sony Televison & Video
Tv switches itself off to standby
Sounds like a fault in the remote receive circuit or power supply. ambient electrical noise is getting into the circuit somehere. As it is not a new TV, I would suspect power supply capacitors, as they dry out with heat and age. Probably best to take it to a repair shop that gives free estimates/quotes, as there may be more on its way out and this is the first symptom.
Nov 29, 2007 | Philips TV Tuner Video Capture PCI Card -...
GE 31GT740 clicks off and on
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Reverts to standby from switch on via TV or Video
No 5v rail because FET MTP3055 o/c. (BUZ71 will do nicely)
Goes straight to standby, after a quick burst of power
Replaced R952 (39K), had gone slightly high
Nov 23, 2007 | GE 31GT740 31" TV
Maxent MX-42vm10 42" Plasma
Generally, if a Plasma Tv is not coming out of standby, it means either the main board is faulty (most likely case) or Power Supply Board is not giving enough power to Main board to switch on the TV. In your case, I think it's the main board (aka Motherboard). Sometimes it's hard to tell to whether ceremic fuses are blown off by looking at them, so it's best to check with a multimeter. Check the fuses in the PSU and also whether it's outputing correct voltages. Also, can you hear a clicking noise right after you've switched on the TV or pressed the power button in the remote to make the Tv go from standby to ON. A clicking noise means one of the boards is shorting out. In your case, I don't think you'd hear a shorting out clicking noise, and I think replacing the Main board will get you out of standby.
Jul 27, 2007 | Maxent MX-42VM 42 in. Plasma HDTV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
