Question about Samsung PN42C450B1DXZA PN42C450 42 Plasma TV ATSC, QAM
Walked out of room and returned minutes later and TV was dead
How would I know what to replace?
    Top Expert:
  • Samsung Master
  • 75,320 Answers
Check and replace its main power supply regulator board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 28, 2014
What can cause a sub woofer and room speaker woofer to stop
Check wiring for loose connection...may have to open speaker enclosure.
Jan 04, 2016 | Velodyne CHT-8 Subwoofer
Polaroid 24 full hd led tv has no volume and no picture
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 19, 2015 | Polaroid Televison & Video
My hisense 50inch tv has no power what can i do?
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Nov 05, 2014 | Televison & Video
I turned the t.v. off at the t.v. not by the remote and walked out of the room. Later that day i went to turn it on and nothing no power light was on nothing at all when I unplug and plug back in no sound...
Make sure the power lead is fully into the socket if it isn't integral. Switch on the tv and hold the power button in for about 10 seconds. Make sure the fuse hasn't blown in the plug.
Oct 15, 2013 | Syntax LT27HV 27 in. LCD HDTV
Iiyama E2607WS just stopped working - completely dead - internal fuse OK
In most cases there are one or two capacitors in the power supply that open, and in some situations they have a bulge at the top making it easier to spot.
Apr 19, 2012 | iiyama E2607WS 26 inch Monitor
We started the oven to bake a pizza, set it to 400 and walked away. A minute later I noticed the oven had turned off, the display, everything. I can not turn it back on, the display is dead.
Hi
This means a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | Ovens
61a60 Toshiba Flyback
Have you check the HOT Q404?
I would suggest to check that transistor before you decide to replace the flyback. The way to know if you are getting high voltage would be to pay attention for like a charging/discharging static noise when you press the power button to turn the TV ON or OFF.
Let me know if you require further assistance.
Dec 18, 2008 | Toshiba 61A60 TV
Television repair
This Tv meesed up Vertical IC LA7033 ( LA7830) ( defected) and 2200uf 35 v, 100uf 35v, need be replaced all together, other possible cause, convergence (2) IC's stk392-110 . you can buy on matelectronics.com or tritronicsinc.com I will help with this . Thank you
Aug 12, 2008 | Toshiba Televison & Video
Samsung PN42C450B1DXZA PN42C450 42 Plasma TV ATSC, QAM Logo
62 people viewed this question
Jerry Greenberg
Jerry Greenberg
