Eiger vision EVP - DVD1
THE DVD PLAYER IS NOT SHOWING ANYTHING ON THE SCREEN. THE TECHNICAL SERVICE TOLD US IT WAS THE MOTHER BOARD.
5 Suggested Answers
  • 1153 Answers
SOURCE: DVD player isn't showing anything
do you hear movement inside like disc rotating, if so then the switch that closest lid is damaged. This is when you fold dvd down it hits this switch to turn monitor off. It could be damaged. If there is no noise or movement then power supply has damaged or batt dead and no power goes to it from power cord.
Posted on Aug 22, 2007
SOURCE: EVP 1048 D sound issue/no response from Eiger Vision
Called the manufacturer
Posted on Feb 12, 2009
  • 22 Answers
SOURCE: No DVD will play and it's stuck on DVD. All I get is a black screen. It's a EVP-104D1 mounted DVD Player in my car.
I've seen that issue a few times. Honestly could be a few things. If that is a envoy, I have noticed quite a few wiring issues with them. Try cleaning the contacts, or check your connections on the ground wire. There should actually be two ground wires the primary and the secondary.
Posted on Mar 15, 2013
yakoobsheikh
  • 24 Answers
SOURCE: Mounted DVD player does not work. EVP-104D1
these usally have inbuilt fuse which needs checking but check the
fuse for the player in the main fusebox
Posted on Mar 16, 2013
My Remote doesn't work, replaced the battery's works for the TV, but not the recorder, is there a default reset on the recorder? because I've changed the dvd3 to dvd1 so I'm not getting anything to display...
make sure remote and dvd select the same setting DVD1 on dvd recorder, so DVD1 on the remote, ther is some writing in the manual how to change the remote from dvd 1 to 2 and 3
Dec 31, 2010 | Sony RDR-HX825 DVD Recorder/HDD Recorder
Hello, I have a Panasonic DMR-EH65 DVD with HDD, when pressing any button on the remote control the display says DVD3, machine will not operate, took it apart to check for any bad connections, reassembled...
You could try Changing the Remote Control code for your DVD recorder. If you have more than one Panasonic device, there's an option to give each device its own Remote Control code. The Default is DVD1. So for FixMick, it sounds like someone may have changed the Remote Control code on your machine to DVD3. For Dador, someone may have changed the Code to DVD1. So you'll need to change the Code on either the device or the Remote to make them match up (see page 19 of the DMR-EH65 Users Manual ... you can download it from the Panasonic website)
Sorry FixMick. I don't know why your display isn't working.
Mar 15, 2009 | Panasonic DMR-EH65 DVD Recorder/HDD...
DvdRDR-GX360
It´s is easy to solve. Your DVD was seted to DVD1. Push enter button plus 1 no remote control.
Now you are able to commnad your DVD and go to System Menu and change to DVD3 again.
After it, don´t forget to backup your remoto control to DVD3. Push enter button plus 3
Dec 13, 2008 | Sony RDR-GX300 DVD Recorder
Inverted Screen (Upside Down)
SOME UNITS USUALLY DO HAVE A MENU FUNCTION TO FLIP THE SCREEN , HOWEVER IF THE UNIT HAS BEEN WORKING THIS WAY FOR A WHILE THEN IT MAY BE A SIGN THE UNIT IS REACHING ITS LIFE EXPECTANCY, IF REMOVING THE POWER DOESN'T WORK IT'S INTERNAL.
Aug 02, 2008 | Eiger Vision AV-710H Car Monitor
Dvd player in van no longer has sound
hi i have a toyota van and i have dvd play in it...the dvd player sound works with the radio station but i for got the channel...so cnu help what channel is it spousd to be....write back plzzz
thnks
Jul 18, 2008 | Eiger Vision AV-1301 Car Monitor
Insignia ns-dvd1-a
Also having same problem. Code bove is not working. DVD player may have been updated with new code.
May 28, 2008 | Insignia NS-PDVD8 Portable DVD Player
Dvd player tp21
try 1800 remotes. They have factory replacements for most of the eigervision stuff
Apr 28, 2008 | Eiger Vision AV-1301 Car Monitor
Command codes
Read page 23 in the manual.
Press "enter" & the #1 keys together for 5 seconds.
Then press stop.
Press "system menu" & change the option back to dvd3.
Then press "enter" & the #3 keys together for 5 seconds.
Press "system menu".
Or call Sony Main Support # 1-800-488-7669
Mar 07, 2008 | Sony RDR-GX355
NS-DVD1
YEs.REMOVE DISC
TURN PLAYER OFF
TURN PLAYER ON
OPEN TRAY
ON REMOTE PRESS 9-7-3-5
Box appears on screen use up and down arows to select REGION ONE or ZERO
PRESS ENTER ON REMOTE
TRAY SHOULD CLOSE
ENJOY YOUR DVDS
Dec 12, 2007 | Panasonic DMR-E50 DVD Recorder
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
