Question about Sony E-reader Portable E-book MP3 Player
Frozen sony e-reader
My sony ereader PRS-T1 is frozen on opening book screen. It froze while I was reading a book, so I restarted it. Now it is frozen on the opening book screen and I can't do anything. I've tried charging it, turning it off and on again, pressing restart...nothing works.
3 Suggested Answers
ani24das
  • 89 Answers
SOURCE: My sony reader is frozen. I cvharged it
The Reader may not turn on, or it may appear to be frozen if the unit needs to be reset, the battery is completely discharged or moisture condensation has occurred.
Please perform the below mentioned steps and check whether it helps.
Because each of these steps represents a possible solution to this issue, check the Reader status after completing each step.
1. Connect the Reader to a USB connection or optional AC adapter. Allow approximately 5 min for it to turn on. If it does not turn on automatically, try to turn it on again. If it still does not turn on, continue with the rest of this procedure.
2. Perform a soft reset. Just press the RESET button using a sharp-pointed object
3. After the RESET button has been pressed, slide the POWER switch to activate the Reader again. If the Indicator light next to the power button on the Reader is yellow , the unit is attempting to start up. If this is the case, allow it a few moments to complete startup.
4. If startup did not complete, connect the Reader to the computer or optional AC adapter and perform a soft reset again.
5. Disconnect the Reader from the computer (if applicable) and then slide the POWER switch to activate the Reader. Check if the Indicator light next to the power switch on the Reader is yellow (indicating it is turning on) and if the unit is responding.
6. If the unit is not responding but Starting up... is displayed on the screen, attempt a hard reset.
7. If the unit is still frozen, connect it again to the computer or optional AC adapter and while connected, check if the Indicator light next to the power switch on the reader is red . If this light is red , allow the Reader to charge for one hour so there is sufficient charge for troubleshooting.
* If your computer goes into hibernation or sleep mode, charging will stop and the red charge indicator on the Reader will turn off.
* It is recommended to charge the Reader while you are using the computer or to adjust your sleep/hibernation settings of your computer to avoid any interruption in the charging process. You also can use the optional AC Adapter model ACS-5220E.
8. Once the Reader has sufficient charge, perform these troubleshooting steps again.
9. Under certain circumstances, moisture condensation can occur. Moisture condensation can be caused by moving the Reader between temperature extremes or if the Reader has come in direct contact with moisture. If you suspect moisture as the cause, allow the Reader to sit for a few hours before attempting to turn it back on.
General notes regarding the battery status:
* You can verify the charge status by disconnecting the Reader from the computer and checking the battery indicator. The battery indicator will display 4 black bars when it is fully charged.
* It will take approximately 4 hours to achieve a full charge with a computer. It will take approximately 2 hours to achieve a full charge with the optional AC Adapter.
If the issue still persists, service of the Reader is required. Please follow the below link to get it repaired:
http://eservice.sony.com
Posted on Jan 21, 2010
  • 94 Answers
SOURCE: my sony prs 350 ereader
Hi!
If the Reader is frozen, you can try the following:
1. Disconnect the reader from the computer
2. Hit the reset button at the bottom of the reader for 3 seconds
3. Slide the power switch
4. Screen will blink and will show "Opening book"
5. Allow the reader to load and then see if operational
Note: If the reader get stuck again, connect it to the computer for 15-30 minutes and allow it to charge, make sure the red steady light comes on.
Good Luck!
eBookBoy
http://digialreader.freeforums.org
Posted on Jul 08, 2011
Sony PRST2 BC has frozen.
This screen is an electronic paper screen, meaning that when it displays an image it will stay that way until it receives electric signals that change it.
Basically, even if the device has no power it will display the last image it displayed.
Are you sure the device is certainly charged? Trying to turn it off and on whilst it's plugged in and charging will be sure of this.
Dec 22, 2012 | Sony PRS-T1 6" Digital E-Ink Pearl eReader...
Screen has frozen and not powering off
There's a small hole on the bottom used to reset the reader. I suggest you get an ink pen with a fine point or a toothpick or paper clip, and press in there to reset it.
I have had this problem with my PRS-300 before, and that usually fixes it. Sometimes, it erases all your books from the reader, though, but you can easily put them back on via USB.
Jul 11, 2012 | Sony Reader Pocket PRS-300
Prs 600 ereader screen contrast problem
The PRS-300 "Pocket Edition" ereader is a device that did provide a far better than ... I bought the Sony Reader Pocket Edition to use for my public library's downloads. ... Conservatively, I probably read upwards of 20 hours each week, both ..... Well lets just say it only seems like there are a few words on the screen at a time. ...
Jan 03, 2012 | Sony Reader Touch PRS-600
Prs 300 has a frozen screen will not turn off or reset or connect to computer
please look clearly there will be a reset button to restart if there is no reset button then open it with the help of secrew and cut the connection of battery and after few second reconnect the bettery to to turn on but remember the connection should be same as before the cutting mean to and - to - terminals
Sep 09, 2011 | Sony Reader Pocket PRS-300
I let my reader PRS-300 connected to pc all night to charge the battery, but now it doesn't turn on...what i can do??? and i tried to connect to pc again to see what happened, but not even the red...
Hi vailzamorta!
You can try to do a "Soft Reset" on the Reader. Do not worry, this will not affect your ebooks =)
2. Hit the Reset button at the bottom of the unit for 3 seconds with a paper clip
3. Slide the power switch at the top of the eReader
4. The screen will blink and show opening book.... allow the reader to load
Just in case here are some other steps to try in case this does not make any difference
http://digialreader.freeforums.org/solution-for-frozen-sony-reader-t10.html
GoodLuck!
eBookBoy
Jul 26, 2011 | Sony Reader Pocket PRS-300
Just purchased a sony prs350 pocketbook editiion yesterday and it it is frozen . What can I do?
Hi pmteach4u!
ecause of e-ink technology, sometimes it may appear that the reader is frozen, you can try to reset the reader
1. Disconnect the Reader from the Computer
2. Hit the reset button for 3 seconds at the bottom of the unit with a paper clip
3. Slide the power switch, the screen will blink and will show "Opening Book". Allow the Reader to load.
If the issue still persist, follow the steps on this link:
GoodLuck!
eBookBoy
Jul 24, 2011 | Sony Reader Pocket PRS-300
My sony prs 350 ereader screen froze when i was reading my book when i try to turn it off the light turns red and it is fully charged
Hi!
Good Luck!
eBookBoy
May 06, 2011 | Sony E-reader Portable E-book MP3 Player
Ereader seems frozen says protected by drm can not read any books i downloaded
Where did you download the books from? If from your public library, then you need to go to Adobe Digital Editions and register your computer and ereader (with the same id). If you bought the books from the Sony Book Store, then I don't know what the issue is.
Your library should have information on what you need to do.
Feb 15, 2011 | Sony Reader Touch PRS-600
My Sony reader prs-600 is frozen. The reset button doesn't do anything. How do I unfreeze it? A part of my screen still works, but a big part doesn't. What can i do?
Try holding the reset for 5-10 seconds, then flip the power switch quickly, three times. If this doesn't work, check the light next to the power switch. If it is flashing yellow, follow the same process. It might take up to three tries.
Jul 21, 2010 | Sony Reader Touch PRS-600
How do I download my new ebook onto my sony ereader? Not the PRS-600 but the PRS-300.
first, download and install the Reader Library Software in the Compouter. download the software frm http://ebookstore.sony.com/download/ . Then, purchase and download the books to the library. Connect the Reader to the Computer. The Reader will be listed at the left pane of the software window. Now, open the library and then drag and drop the book to the Reader.
Dec 28, 2009 | Sony Reader Touch PRS-600
Sony E-reader Portable E-book MP3 Player Logo
87 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
