Question about Thermador Ovens
Thermadore oven won't heat
I have an old thermadore SMW272. The oven went out and nothing worked. I checked all elements, high temp cutout , and temperature sensor. All were functioning. After I turned off breaker for 5 minutes and then back on. Oven worked again. Problem happened again a few weeks later and now the oven will not reset.
  • 20 Answers
Have you set the clock?
warmest regards
Richard The Repairman
Posted on Mar 31, 2014
Testimonial: "yes clock is set."
  • Richard  Saupe
    Richard Saupe Mar 31, 2014
    I think then that the clock needs replacing, best to call an engineer to check things over!
  • dan martyna
    dan martyna Mar 31, 2014
    I have already pulled the oven control board out, nothing obvious on the board (burn marks) I can get a new board and clock for about $300 but can't get the clock by itself. It would probably cost me that much to have a repair man come out and fix it.
5 Suggested Answers
SOURCE: Fan works, but Oven stays at 100 degrees. Tried
On my C301 U, I found the brown connector on the right side of the oven control board P3-2 loose. It looked connected but while doing a shake test- Whoop, there it is. It is the sensor for the temp probe. If it's loose all the fans run all the time.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=C301U&productCategoryId=0124100&brandId=1085&brandDescription=THERMADOR&modelName=BUILT-IN-OVENS&diagramPageId=00014&componentDescription=WIRING%20DIAGRAM&documentId=U2500861&blt=06
Posted on May 23, 2010
fixyourboard
  • 310 Answers
SOURCE: thermador smw272 oven does not heat. the op panel
Likely to be the Hi Limit Switch or the relay/power board.
Best Regards,
Bruce
www.fixyourboard.com
Posted on Jun 19, 2010
  • 414 Answers
SOURCE: I purchased a microwave/convect oven combo last
Ensure that the clock is set and that is not in auto mode, the clock is only linked to the main oven and therefore it will not opearte if the clock is not set correctly, all the best
Posted on Sep 05, 2010
Daniel S
  • 4323 Answers
SOURCE: Oven elements do not heat;
Hi
The issue can either be a bad electronic control/clock assembly or the oven temperature sensor (probe) has gone bad. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then 1100 then it is the sensor that is bad & if the rating is around 1100 then it is the board that is bad & should be replaced. Hope this helps...
Daniel
Posted on Jan 04, 2011
Oven will not heat up broiler works. its a thermador rdss oven
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101 ';
Mar 07, 2011 | Thermador SMW272 Electric Double Oven
Is there a reset for the oven in a thermador smw? I had it worked on years ago and the repai guy simply pressed a button and all was well...also is there a source for control panels, since mine is almost...
Never use Self-Cleaning!!! It will fry components, melt connectors, and burn wires. If you have violated this rule and an oven no longer works, it is probably not a bad element if neither the bake nor the broil work. It is likely the high heat cut out breaker.
On a Thermador CT 227 double oven, there is a panel on the right side (facing the unit) that is about 3 inches wide and runs from top to bottom held in place by about 6 or 8 screws. Turn off the power, slide the unit out of the kitchen cabinet, remove the sheet metal panel and you will see two high heat cut out breakers. They have a small red button in the center that resets the breaker. Push firmly and you should hear a click. If there is no click, check the unit for continuity. If it is open and the button push does not reset it, the unit may be fried. These breakers trip with high heat and will prevent both elements in an oven from heating. If the breaker is good, you'll have to test the leads to each element and then trace the dead lead to the problem.
Dec 27, 2010 | Thermador SMW272 Electric Double Oven
Thermador smw272 oven does not heat. the op panel
Best Regards,
Bruce
Jun 19, 2010 | Thermador C302U Electric Double Oven
Bake element does not heat up but broiler does. Do
The baking element is probably the problem...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Apr 06, 2010 | Thermador SMW272 Electric Double Oven
All elements cease to work after self clean
If the electronic control is blank then an inline fuse to the control has blown due to overheating in the area of the controls. If the controls are visable but nothing in the way of high voltage works then that is the limits in the rear of the ovens.
Feb 15, 2010 | Thermador SMW272 Electric Double Oven
The oven pre heats to desired temp and then loses
SOUNDS LIKE THE TERMOSTAT IS FAULTY REPLACE IT AND YOUR OVEN SHOULD WORK FINE.
Nov 09, 2009 | Thermador SMW272 Electric Double Oven
Thermador smw272y won't heat at all
The switches on the first circcuit card mounted horizontally in the space above the microwave enclosure and behind the control pannel have burned to the point that they no longer engage properly to close the power to the oven heating elements. I do not know anyone who has removed the plastic covers and cleaned them to the point of working again properly and do not recommend trying that approach. The only sure solution is to replace the circuit card that has the three switches.
Sep 01, 2009 | Thermador SMW272 Electric Double Oven
Oven will not heat - Thermador SMW272 Electric Oven
since you said the broiler does work , take the wires off the broiler element and put on the bake . then when you put on the broiler the bake should work . the light bulb principle, just remember to wrap all loose wire with electrical tape and disconnect from wall while working.
Dec 12, 2008 | Thermador SMW272 Electric Double Oven
Thermador sm272zs microwave/oven combo
Woke up this morning and heard my smw272 built-in oven beeping. Oh no! First the display (but at least the oven worked) now the oven is beeping (fault signal according to manual) and the thing is dead except for the microwave and warming bin. The only way to turn off the incessant beeping--which was driving me crazy--was to go outside to the fuse box and turn off the circuit to the oven. Yeah, I stopped the beeping but now I'm at the mercy of the unscrupulous service repairman--was quoted a flat fee to drive out and a hefty hourly rate (i.e., "value added" service charge). OUCH! Hey folks, please follow my simple advice if you want to avoid making a big mistake: NO MORE THERMADORS. RUN--DON'T WALK AWAY FROM THIS BRAND!!!
Pruneau
Aug 18, 2007 | Thermador SMW272 Electric Double Oven
Ovens Logo
180 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
goober123
Level 1 Expert
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
