Question about Titan Impact 540 High Rider Airless Paint Sprayer
Motor wont start
When plugged in the psi light comes on but when i flip the switch to the on position the motor wont start even if i turn the pressure dial nothing happens.
  • 50 Answers
Hi Josh,
A number of things are possible, starting with the obvious that there is fluid in the sprayer and it is under pressure. It is also possible that the pressure sensor (transducer), the motor or its connection to the control board are defective. Best take it to where you bought it to have the electrics checked, or at least have an electrician do it.
Posted on Apr 14, 2014
My 60 gallon kolbalt was running and stop when it filled now it wont go o ever with the tank drain it spins free it does nothing no sounds either
When you say it does nothing do you mean the motor wont come on or the motor comes on and it wont build pressure? if the motor comes on, there are several possibilities:
1. The unloader valve is stuck open
2. The valves in the head are bad
3. The flywheel is loose
If the motor wont come on, the pressure switch is bad (which holds the unloader valve open)
http://www.mastertoolrepair.com/air-compressor-parts-vt6362-p-60727.html
Oct 10, 2016 | Kobalt 3.7-HP 60-Gallon 155 PSI Electric...
Can I get 80 psi with dials set at 40 psi
this compressor should be able to fill your tires to 80 psi. Look for a pressure switch and adjust it so the motor shuts off at a higher pressure. Do not exceed 100 psi.
Sep 08, 2014 | Air Tools & Compressors
Lights flip up when car starts,never go's down
sounds like your on off switch in vichle is not working correctly as it may be stuck in the on position even though you switch it off. I say that only because there seems to be power on the light motor all the time and when you start the car they flip up> find the relay that goes to the motor off the lights it could also be that the relay is stuck in the on position. when you switch your lights on you should hear a click noise come from the relay if you dont then it is possible that it may be burnt inside> easy way to cheack is to start the car and remove one fuse at a time if nothing happens replace the fuse and do the next one until the lights close. all you will be doing is removing power off the relay, when you find the one that is powering that motor remove it and replace the relay
Sep 05, 2013 | 1981 Chevrolet Corvette
1981 c3 headlights flip out when car is started,but will go down
49de7c30-fce9-4e27-ae89-f6cfe5dc93d3.jpg Sounds like your on off switch in vichle is not working correctly as it may be stuck in the on position even though you switch it off. I say that only because there seems to be power on the light motor all the time and when you start the car they flip up> find the relay that goes to the motor off the lights it could also be that the relay is stuck in the on position. when you switch your lights on you should hear a click noise come from the relay if you dont then it is possible that it may be burnt inside> easy way to cheack is to start the car and remove one fuse at a time if nothing happens replace the fuse and do the next one until the lights close. all you will be doing is removing power off the relay, when you find the one that is powering that motor remove it and replace the relay
Sep 05, 2013 | Cars & Trucks
I have a sears compressor,125 psi, 1 hp 4 gal. When I flip the switch to turn it on it just humms
There could be a few different problems with the unit that would caused this.
If the motor just hums when there is no pressure in the tank then you will probably have a problem with the motor winding or capacitor.
If it hums when it is trying to start with air pressure in the tank then you may have a bad check valve.
Try removing the outlet tube from the compressor head to the tank and see if the motor will start. If it still will not start the bypass the pressure switch.. connect black to black and white to white... then see is the unit will start when you plug it in.
If is still will not start then you will need to have the motor serviced.
Oct 13, 2012 | DeVilbiss Air Tools & Compressors
For a while my 95 buick lesabre would start and cut off on me mid drive; hot, cold, full speed to not fast at all. now the car wont start. i have changed the starter, altinator, bat, plugs and wires,...
Just because you hear the fuel pump running doesn't mean the fuel pressure is correct, put a fuel pressure gauge on the car, 41-47 PSI (Pounds per Square Inch)Position the ignition switch and the A/C system in theoff position. Install a fuel pressure gauge to the vehicles fuel rail or fuel pressure test port.Confirm that no leaks are present, and visually verify the PSI reading on the gauge with the ignition in the on position.
Jul 23, 2011 | 1995 Buick LeSabre
Comperrsor pumps uoto preassure, but when the preasure drops it tries to start . The motor come on but will not turn compressor until preasure drops to about 20 lb. Then it will start and build up to...
Run the compressor until there is about 75 psi in the tank and turn it off at the pressure switch. Remove the black bleeder line from the pressure switch:
1. If absolutely no air comes out of the line you may have a bad start capacitor on the motor. Have it tested at an electrical or refrigeration shop or just replace it to see if it takes care of your problem.
2. If you get a short blast (five or so seconds) of air then nothing your pressure switch isn't letting the head pressure bleed off after the motor shuts off. This pressure has to be relieved or the motor has to fight the tank pressure when it tries to restart. Reconnect the bleed off line and turn the motor back on. If it starts normally, replace the pressure switch. If it struggles or won't start it is more indicative of a bad start capacitor.
3. If you get constant air flow from the bleed line the problem is with your tank check valve. This causes the same problem as above. Replace the check valve.
May 04, 2011 | Ingersoll Rand 30 Gallon Garage Mate...
My timer manual switch works,it turns the outside lights on and off. However the automatic dial,even when plled out and set to time to operate does not work.What 's going on? Isit me?
The two tabs are for On ad OFF.
One is slightly longer than the other. If the OFF tab is in the ON location, it won't work, it'll just click past the time and not flip the paddle to ON.
Try this, turn the dial (NOT pulled out) around slowly and see if it flips the paddle to ON. Keep turning it, slowly, and see if it flips to OFF.
If it works while you're "helping it" then it should work automatically. If it doesn't, maybe the gear is damaged and it can't move past a certain point.
Does the time move? Do you hear the motor running? I've seen the motors go bad. The manual flipping will work then, but the motor isn't running the clock around.
Jan 30, 2011 | Intermatic T101 - 24 Hr. Dial Time Switch...
The timer does not operate. Breaker flipped once. I flipped breaker to reset. It never flipped off again. I try the manual switch to get my pool pump running and nothing happens at all. The lines are...
START YOU VOLTAGE CHECK AT THE BREAKER , IF YOU PUMP IS 230 VOLT THATS WHAT IT SHOULD BE ABOUT 230-240 V . YOU CAN ALSO CHECK IT AT THE TIMER AT THE 2 SCREWS THAT SAY LINE (NO VOLTS ITS A BAD BREAKER) AND THEN CHECK THE 2 SCREWS THAT SAY LOAD WITH THE TIMER ON "MOTOR RUN" (NO VOLTS ITS THE TIMER)
Jan 05, 2010 | Intermatic T104M 208-277Volt 40-amp Timer...
Karcher K3.92 M 1750 PSI poweer Washer motor won't start. Followed Reset/Test/Reset sequence with cord plugged directly into outlet. Light on cord near Reset comes on when Reset pressed down but goes off...
They are sensitive to large extention cords. My father in laws pops reset when a small cord is used. If internally shorted- motor will continually pop the reset even plugged direct to outlet. Check voltage at outlet.
Jun 19, 2008 | Karcher 2500 PSI Pressure Washer
Titan Impact 540 High Rider Airless Paint Sprayer Logo
182 people viewed this question
Top Titan Air Tools & Compressors Experts
JOHN LAPIER
Steve Pack
Steve Pack
Vernon Taylor
Are you a Titan Air Tool and Compressor Expert? Answer questions, earn points and help others
