Question about Samsung LE Televison & Video
Tube broadcast i have an le26 which will not switch on.Red light just flashes.
    Top Expert:
  • Samsung Master
  • 75,571 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Posted on Mar 28, 2014
What does 3 flashing lights on the Red T Product Gas Furnace Mean?
Vac switch. pull door/find grey tube to induced draft motor/pull tube off/suck on tube to hear it click/if so you need to find a wire small enough to insert into motor tube being sure power is off before doing this. 112 to 16G will work. reatttach and power up to see what happens. Good luck
May 06, 2014 | Goodman GDS80904BNA Open Flame Heater
I have miele w500 problem is the soak/pre-wash
hi, the problem you are having with the "soak/prewash" light flashing after the wash has started is a common fault on the meile washing machine. Its a water sensor problem. remove all srews and bolts from front of machine and open the front panel. you will see a red in colour pressure switch at one oclock, there will be a black tube attached to it, remove the tube and replace it with a new one, or reverse the tube in reverse and you will find that the water intake level will be less and the fault of the "soak/prewash" light will no longer flash, problem solved. 0868887054 DAVID ASHBOURNE. MEATH.
Nov 14, 2012 | Miele Novotronic Premier 500 Front Load...
My furnace will not light. What does it mean when the red light on the circut board flashes 3 times?
Hello, a 3 flash on a circuit board means that a pressure switch is open, this could be due to a blockage in the flue pipe or the small tubing that goes from the inducer to the pressure switch is loose, leaking, or is blocked. You can try taking the tubing out and checking if there is anything in it blocking the pressure between the pressure switch and inducer motor and then attaching back on and make sure it's secure and tight. If that does not work that the switch itself is bad and must be replaced.
Jan 22, 2011 | Goodman GMS90703BXA Heater
Television red standby light is flashing. Will not take any other command from the remote or manually and will not switch on.
FBT,flyback transformer it dead,the big block of plastice with a red wire with a cap hook to a CRT(tv tube).No high voltage.
Sep 30, 2009 | Televison & Video
Tv is running then screen turns red and then stand by light flash
The red picture tube has an internal short. Hitch is that the tube is no longer availible. But the tube can be rebuilt. A tv shop can pull the tube assembly and ship it off. This is a very reliable repair but expensive. Average cost is between $400 and $500.
Jul 10, 2009 | Sony KP-57WS500 57" Rear Projection...
Turn on pic turns red with thin bright red horizontal lines
Sorry to say, but that's usually the sign of a bad picture tube. One of the elements inside the tube shorts and you see the picture you describe, and the set shuts down due to high voltages getting to places it shouldn't. There's no solution except picture tube replacement, and that is uneconomical. You're better off replacing the TV when the tube goes bad.
Mar 31, 2009 | Toshiba Televison & Video
Tv Red Screen
There is only a few reasons for this problem and it is a bad video IC on RED CRT board or Defective RED TUBE disconnect CRT board at end of neck on red tube Look at IC on That board while disconnected from tube turn TV on if it keeps playing without shutting off Tube is defective.
Feb 20, 2009 | Sony KP-51WS500 51" Rear Projection...
5 flashing light code
Disconnect RED Tube CRT board if set plays without shuting off RED tube is bad or video IC on CRT is bad.
Feb 12, 2009 | Sony KP-51HW40 51" Rear Projection...
Screen went blurry 20 minutes later no picture no sound just red flashing light on front
These sets had bad welds in the gun assemblies of the picture tubes. Now, one of the tubes has failed (shorted) and the cost would be too high to replace all three.
Mar 02, 2008 | Sony KP-51WS510 51" Rear Projection...
580 ex speedlite
Turn on flash while pressing some of those buttons with good batteries
Try switching from Meter to Standard Mode and move head around.
Try move the flash head(flash tube) in Manual mode.
It's in electronic locked up because you're moving that flash tube zoom too much. 98% of photographers use that mode:-(
Alexander
atdlee@netzero.com
Dec 07, 2007 | Nikon Speedlight SB-800 TTL Flash
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Televison & Video Logo
27 people viewed this question
Jerry Greenberg
Jerry Greenberg
