Question about Iview 705nb 7" android netbook
Iview 705nb can't get past android figure
Tried restart no good battery full charge has not been used for long time.(1 year) Only Android shows up. osas2.2-kernel2.6.32-build v1.3.1
Wont load past android logo
Give it about 2-5 minutes , if that doesn't work try holding the power and volume button until it shows you a reboot option.
Mar 31, 2014 | Hannspree SN10T1 101 Tablet
Proscan tablet won't turn on
Try this. Plug your charger in. Then press the power button repeatedly until the screen comes up with a charge icon showing.
Hold the power button down until the blue screen comes up. Then if it boots up just leave the tablet alone and give it some time. You should see an android come up and then a scan of the android words start . This takes time. Don't be impatient . It may boot into a factory reset mode. Just start again with the factory screen.
You can try repeating the process if it doesn't work the first time.
Mar 22, 2014 | Proscan 10.1-Inch Internet Tablet,...
Android launcher stopped unexpectedly
Disconnect the battery for 10 minutes. Then try again. Are you doing the 3 finger hard reset?
Dec 04, 2013 | Sylvania Synet7lp Mini Tablet 1. ghz Arm...
Pattern unlock android
do a factory reset most of the time this works it take it back to the orignal state when you bought it
it should up load all the needed files to restart it with out ant troubles
Aug 23, 2013 | Iview Cyberpad 756TPC Tablet
Freelander android PD 20-3G 7"
try replace the battery or the charger
Jun 05, 2013 | Tablets & eReaders
Htc amaze 4g wont turn on after charged
Try leaving the battery in with it charging all night, if the phone won't turn on after that, you'll need to exchange it.
Jan 16, 2013 | HTC Amaze 4G Android Smartphone
Iview 705nb 7" android netbook Logo
Top Iview Tablets & eReaders Experts
Hjalmer Lamminen
Hjalmer Lamminen
Are you an Iview Tablet and eReader Expert? Answer questions, earn points and help others
