Question about Sewing Machines
Silver 302 sewing machine
I have loaned a silver 302 from a friend and as a bit stuck as I have no manual!! All I am wanting to do is basic stitch but not loose and not tight but the thread is looping I don't seam to be having much luck
  • 39 Answers
If it is your top thread looping then the top thread is too loose and you need to tighten the top tension. Usually the higher the number the tighter the thread. If it is the lower thread looping to the top then try loosening the top thread first by lowering your tension number. If this doesnt work then depending on whether or not you have a separate bobbin case, which has a small flat screw 3-4mm diameter which can be turned by the flat of your thumbclockwise to tighten, if looping and anticlockwise to losen. Normally only the top tenison needs to be fiddled with. If you have to change the lower(bobbin) then one way of checking a good tension is to let the bobbin drop whilst holding the thread and it should drop comfortably with a small pull on the thread a little bit like operting a yoyo:)
Posted on Mar 28, 2014
bargainbox
  • 1388 Answers
SOURCE: Machine not sewing
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
If you are certain that all threaded correctly, did you have a fabric jam and pulled it loose ? If so, the timing may well be affected.
Post an update and we'll get this right.
Bargain Box
Posted on Feb 03, 2008
bargainbox
  • 1388 Answers
SOURCE: Loose stitching underneath. HOW CAN I FIX!!!!
I'm **t sure what you mean by freehand stitching........do you get a good even stitch with zig zag, this is the most important first test ?
Ensure that all is clean and free of lint jams....**w for tension troubleshooting .......
This solution is for tension problems...if you can**t form any sort of stitch, the issue is quite different, so please let me k**w if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "k**tting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and **t to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do **t gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would **t recommend fiddling with bobbin tension without good reason, it may end up with missing small *****s and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (**t soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is ** lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension ***** in the middle of the metalwork....
4c76dc1.jpg ...the other ***** at one end is holding it all together, so beware....it is **t a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's ** trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension ***** very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it can**t be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....** case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (a**ther reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistant diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Mar 09, 2008
  • 323 Answers
SOURCE: unable to adjust tension,
Sounds like the bobbin thread is not inside the tension on the bobbin case. This normally happens when the bobbin is upside down. Insert the bobbin and pull on the thread.The bobbin should turn counter clockwise.
sewman7
Posted on Jul 18, 2008
bargainbox
  • 1388 Answers
SOURCE: My bottom thread is loose when sewing a straight stitch
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
TOP THREAD TENSION:
projects).
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
back properly.
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
OTHER ISSUES:
case....no case ? then make some sort of cover !
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
Posted on Jul 24, 2008
Mimito7
  • 128 Answers
SOURCE: Top thread stitches correctly but bottom thread loops.
FYI---- Loops on the bottom-- problem is in the threading..
Loops on the top--- problem is with the bobbin.
Posted on Apr 19, 2009
I have a Singer Serenade 30 and have set everything according to the manual for zig zag but it still sews straight. Help!
Make sure that your needle shaft is not stuck, move it back and forth, oil if necessary. I had it happen to me once, but mine was caused by a bent needle shaft after loaning it to someone, and I had to do this each time I wanted to zig zag stitch. .
Mar 12, 2011 | Sewing Machines
I have silver 8 stitch sewing machine that want stitch right underneath
Try threading the machine with the presser foot up and see if this will resolve the problem.
Mar 08, 2010 | Janome Jem Silver 662 Mechanical Sewing...
Viking 2000 6430? sewing machine, only sews in reverse.
Your stitch length dial is stuck. Your machine is in need of oil. If you open the back of your machine and see the bit that moves when you turn you stitch length dial. oil that bit and warm it with your hair dryer. It should become loose. It take a bit of warming and working the oil into the machine. You have to repeat this process a few times.
I do have the service manual at sewingnz@gmail.com
Jan 25, 2010 | Husqvarna Sewing Machines
What are the settings for regular sewing, I do not have a manual. It has 3 knobs on the front and 1 on top? This might have something to do with my problems.
The three front dials are as follows....left to right-Stitch width, type of stitch, and stitch length. The dial on the top adjust the top tension.
For straight stitch you want 0 stitch width, straight stitch, 3 for stitch length.
For zig zag you want turn your stitch width to how wide you want the zig zag, choose zig zag stitch, and choose how close you want the stitches to be on the stitch length dial. Practice on a piece of fabric. Usually for zig zag you will want to loosen your top tension a little bit.
Aug 11, 2009 | Brother XL-5130 Mechanical Sewing Machine
Machine sews only in reverse
Be sure you are in the correct stitch pattern...if you are on a buttonhole stitch or a stretch stitch it normal for the machine to sew backwards. Be sure your length is to the right of 0 and not in a strtch stitch model or buttonhole mode.
Bonnie
Jul 28, 2008 | Kenmore 15218 Mechanical Sewing Machine
Changing stitches on a White 1418 sewing machine...
I have a White 1418. Here's how you do it:
1. Attach the buttonhole presser foot (should have come with your machine) and place the fabric underneath.
2. Set the stitch length knob to 0, the zigzag width knob to 5, and set the needle position to center. Sew 3-5 stitches.
3.Change the stitch length to 0.5, the zigzag width to 2, and the needle position to left. Sew to the entire length of your buttonhole.
4.Set stitch length knob to 0, zigzag width knob to 5, and needle position to center and sew about 3-5 stitches
5. Set the stitch length knob to 0.5, zigzag width to 2, and set needle position to the right. Pressing the R button (reverse button), sew up to the top stitches.
6. Remove the fabric and open the button hole with a button hole cutter.
Sounds complicated, but it's really easy. I love this machine, you just have to know how to use it!
Sep 18, 2007 | White Sewing 1418 Mechanical Sewing...
Sewing Machines Logo
99 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
