Question about Ovens
Whirlpool oven powers on but the burners and the oven do not heat
I lost power the other day it may have affected. Model number RF361PXKQ
    Genius:
  • 1,114 Answers
Turn the circuit breaker off and back on for the stove, and see if that works.
Posted on Mar 27, 2014
Testimonial: "I did that a few times and nothing. I even put the oven on clean and I saw the mechanism that locks the door turn and lock the door. Put all burners on and oven on and no heat. Shows on by lights but no heat. I looked for fuses and see none"
SOURCE: My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Posted on Dec 08, 2008
jumptrout51
  • 3361 Answers
SOURCE: whirlpool oven will not heat up after self lean
Check the overload thermostat inside the back panel of the oven.
No continuity? Replace it.
Posted on Mar 11, 2009
heavyice
  • 374 Answers
SOURCE: I have a whirlpool oven model no. G2P61/01SR/WH. It does not heat
The problem lies in your magnatone used for heating up the oven.You need a replacement for that.
Posted on Jun 04, 2009
  • 574 Answers
SOURCE: My frigidaire oven won't heat. The burners work
You have two elements turn on the broil and see if the top element comes on if it does replace the bottom element.
Posted on Aug 24, 2009
heatman101
  • 43501 Answers
SOURCE: Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on Apr 07, 2010
Whirlpool gas range
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Jul 26, 2014 | Whirlpool Ovens
My whirlpool stove RF365PXMQ0 will not heat up the top burners or the oven. What could be wrong?
need to get a volt meter and check the incoming power( at the plug ) and make sure you have 240 volts!! it only takes 110 volts to run the top burners, and takes 240 volts to run the oven!!
Feb 10, 2012 | Whirlpool Ovens
Lower element stop working, wouldn't heat past 140 degrees, then tried to used the stove top and those stop working completely. Is there a safety feature to cuts the stove top off? Also is the element...
Hi and welcome to FixYa, I am Kelly
This sounds as if you have lost half of the power to your Oven. It can be from a partially tripped main Circuit Breaker for the Oven or an internal wiring problem of a burned wire or terminal. It can also be the range control itself. but I doubt that since you said the burners also do not work (depending on model) If you have separate burner controls definatly NOT the range control.
If you pass your model number we can better help you. The fact that the lower element is only reaching 140 degrees is pretty much indicating that your oven is operating on 110V vs 220V. The causes again are input power, oven wiring or the range control.
Reset the Oven CB and check BOTH ends of the range cord (if you have one) for signs of hot terminals. For a direct connection look closely at the terminal board where the house wiring connected to the oven.
With a MODEL number I can look at manuals and diagrams to better assist you. Please pass that complete MODEL number in any future responses. Most any future response I provide after I get a MODEL number will involve using a meter and opening the oven to troubleshoot.
Thanks for choosing FixYa,
Kelly
Feb 23, 2011 | Maytag Ovens
The oven portion of my kitchen aid superba range won't heat up.All of the topside burners are working fine. I recently turned the breaker off then back on to this appliance, would this have affected this...
there is an element in your oven that needs to heat up before it will light. it needs to be replaced. collect the serial number and model and if you go to sears they should be able to help you with the problem
Feb 09, 2011 | KitchenAid Ovens
Whirlpool oven ''feature not available''
That happened to my fairly new Whirlpool double oven. But I remembeedr the power in the neighborhood had flickered earlier in the day. So I went to the circuit breaker and shutoff power to the oven for about 30 seconds and turned back on. Everything normal now. I just assumed the slight flicker in the power affected to programming.
Jan 24, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool Oven Model GS440LEMQ bake eventually turns off
As per the problem you submitted ,According to the manufacturer service pointer cause of the intermittent bake burner operation is improper air flow to the burner.
The correction is to replace the bake burner with the new modified burner and igniter assembly.
- The part number for the burner & igniter assembly is AP3598752
http://www.appliancepartspros.com/part_details.aspx?part_id=3598752 --------- to get more help please click on this link directly http://www.applianceaid.com/gas.html
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 31, 2009 | Ovens
Ge range model # js968 has power but cooktop & oven don't work
Check for proper power (control panel is 120V, burners and heat element are 240V) You may have lost connection in one of hot wires causing the burners/elements not to work yet the control panel still will
clarkco
Feb 25, 2009 | Ovens
No power to clock or oven with the door closed
it sounds like the oven lost its neutral feed. I would check where the cord goes on for a good connection at the middle terminal(white) if not there it may be lost elsewhere Dont forget to rate my solution as solved if i answered you question accurately....Thanks!!!
Sep 30, 2007 | Whirlpool RBS245PDS Electric Single Oven
Our oven's heating elements will not come on althought the display seems to work correctly.
Wekiwa, your TCO, (thermal cutout) probably opened during the high temps in self clean. You will have to remove the back panel and replace it. It should be just under the vent back there. Part number 4450934. You can ohm it out first to make sure, it will show open (no continuity) if bad. This is an easy job, won't take you that long. Kill power to the range before going back there. In doing a little more research on your model, I see there was a service flash where they recomend moving the TCO over to one side so the cleaning cycle doesn't affect the TCO. This may be covered by Whirlpool. You might want to call them and inquire. Catriver..post back.
Dec 18, 2006 | Whirlpool RBS275PD Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
