Question about JSG Oceana MBS-MCP-200 Monarch
Printer option will not work
How do I hook up a printer
Printer cannot be contacted over network
when you hook the printer up to the computer that is in the net work you have to go to printer options on each individual computer in that network and serch for that specific printer name and add it to the printer list.
May 13, 2012 | HP PSC 1600 InkJet Printer
My printer light is flashing and I am unable to print
Could be several options
First shut off and disconnect printer from pc and reboot without printer hooked up
once reboot hook it back up and turn on to see if windows found new hardware.check paper and ink
All else fails re-load printer driver
Jun 22, 2011 | Lexmark X1240 All-In-One InkJet Printer
I just bought a apple macbook pro and would like to use my printer over the network rather then having to connect usb every time i want to print. how do i do this i have a big pond wireless modem its the...
you can buy a print server to connect to your printer to the network. however could you please list the printer type you have? some printers do not work over the network with a print server on mac.
the printer will still function as long as you got a phone line to it for faxes however some features like scanning will not work over the network.
Mar 07, 2011 | Computers & Internet
Hi I have some problems to instal my printer Lexmark Inkjet X5650 in Win 7
First thing to do for this my friend is check the Microsoft Compatability Listing to see if your printer is supported.
Search 'Microsoft Copmpatability List' for a link.
If your printer is not listed, visit www.lexmark.com/support for a proper driver for 7. If they dont list your printer under 7, they dont support it either. You might find a 3rd party driver that will work.
If the OS and Lexmark dont support the printer, your options get real limited. Option one: hook your printer to a different computer that will run it (98/XP/Vista) and use it as a print server on your network. Option two: new printer.
Jan 01, 2010 | Lexmark All-in-One Printer with PictBridge
Not working?
You'll need to install the copier drivers to your laptop to get the print options to function. Don't confuse fax functions with printer functions. Having the unit hooked up to the phone line allows you to send and receive faxes. You need to be hooked to your PC/laptop with the proper print drivers installed in order to print.
Aug 03, 2009 | Brother MFC 7420 All-In-One Laser Printer
This unit will not receive faxes. It just shows as phone being off the hook. If I call the fax number I have a busy signal. If i plug a regular analog phone to it, it works fine. I just can't get this...
Well its just setting in the printer control pane.Theres an option fax settings under the menu button.Under that you will find the relevant options to turn it off.If you want any further support, an online technician from techbuddies can help you for free.For this log on to http://tinyurl.com/m7ghqz
Jun 18, 2009 | HP Officejet Pro L7680 All-In-One Printer
Date is not displayed on LCD or on printed photo
Date can only be printed on photo when it will be printed through Picbridge option on digital printer.
When camera hooked with PC via usb, there are options of mass storage and Picbridge and can be selected by pressing menu button.
In Picbridge printing procedure camera hooked directly with digital printer and printer asks for date printing settings.
Jan 15, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
HL-2040 printer won't function
You can't hook up two HL 2040 with 1PC. It will make your PC crazy and don't know which printer should go for printer.
You must remove 1 HL2040. After that you should be fine.
Dec 04, 2008 | Brother HL-2040 Laser Printer
HP OFFICEJET 5610V No scan options
If you get the error while trying to scan with your HP 5610v All-In-One, the easy way to scan from your printer is to click on start, go to Paint and then File, the option "From Scanner or Camera" will come up.. click there and poof - you can scan anything you want and save it where you want... Problem solved!! good luck!!!
May 24, 2008 | HP Officejet 5610 All-In-One InkJet...
JSG Oceana MBS-MCP-200 Monarch Logo
44 people viewed this question
Top JSG Oceana Water Sport Experts
Tom Chichester
Bill Boyd
Are you a JSG Oceana Water Sport Expert? Answer questions, earn points and help others
