Question about Kenmore 27" Electric Unitized Washer/Dryer - 61532 - White
How to replace washer lid latch and part # for it
The washer gets to the spin cycle then stops, appears latch is not engaging
  • 33 Answers
Need the entire part number.
Posted on May 27, 2014
Washer stops during normal wash cycle for a minute or more, and then continues. Would replacing the timer fix it?
If it actually goes on and finishes the cycle and that really bothers you replace it. If not leave it alone and allow a little more time to complete its cycle. The lid switch only keeps the spin cycle from going with the top open.
May 23, 2014 | Whirlpool Washing Machines
Kenmore model 23832100 washer will not spin in rinse cycle kenmore model 23832100 washer fills, agitates, and drains, but will not spin. Makes noise after draining. BUT if I manually turn off the machine...
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Mar 30, 2013 | Washing Machines
Washer souds like trying to engage but won't
If the motor hums and will not pump out or spin, the motor is bad. It reverses direction and the reverse windings appear to be burned out.
Dec 28, 2009 | Kenmore 22422 Top Load Washer
Washer will not spin
I fixed it yesterday. After checking the continuity of my lid switch and pressure switch and finding them ok I removed the tubing from the pressure switch and applied air (blew into it). There was a clog and blowing on it removed it for now. Apparently the pressure switch was telling the machine that the tub was full of water and wouldn't let it start the spin cycle. I ran three loads last night and it worked perfect. I may have to remove the connection on the side of the tub and clean it properly if it clogs again.
Mar 23, 2009 | GE Washing Machines
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
Will not complete cycle
hi. i would check the lid switch fill the tub to low level let it start to wash stop the washer now put it to the spin cycle pull out knob close the lid slowly if it does not pump replace the lid switch now push on the lid. if it goes now .replace the lid switch .thanks te appliance doc. rate me please
Aug 22, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer estate brand ETW4300SQ Model
If the washer fills and stops at the rinse cycle, and then will not spin or drain, you more than likely have a defective lid switch. If you open and close the washer lid and do not hear a “clicking” sound, the switch has probably come loose, or has broken. There are two mounting screws that hold the switch in place along the washer rim. Also, inspect the lid to ensure the small plastic piece that pushes down on the switch when the lid is closed has not broken off. This is called the “lid strike”. If the lid strike is broken or missing, the lid switch will not activate. If you diagnose the problem and need to replace the switch, you can click on the following link for advice on how to replace it:
http://www.fixya.com/support/r397101-replacing_lid_switch
If you need further assistance, such as where to get replacements parts, please let me know. I hope this helps you.
NOTE: You do not need to drain the wash tub to replace the switch. Once the switch has been replaced, the washer should spin and drain, which will prevent you from needing to bail water.
May 23, 2008 | Estate TAWB600JQ Top Load Washer
Washer lid will not open after cycle
suspect bad lid latch there is usually a 4-6 delay after washer stops before latch will release anything much longer proably lid lock ..remove 2 screws bottom front panel front drops and comes off switch is on right remove screw each side of top lift up 2 screws hold latch in place remove wires and screws and replace latch
May 22, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washer Stuck in Cycle
The timer is bad / shorted. Mine used to try to spin with the water in it... that was a sight to see!
Jan 11, 2008 | Whirlpool LSN1000LW Top Load Washer
Washer will not pass wash cycle...Will not Drain
Nightshade, in most cases, no spin, no drain is a lid switch problem. If you advance the timer to the spin position does it spin? If the machine is agitating you can rule out the coupler. If you are sure that it is not a lid switch problem, then you are probably looking at a bad timer....Catriver..post back.
Nov 08, 2006 | Roper RAS8445KQ Top Load Washer
Kenmore 27" Electric Unitized Washer/Dryer - 61532 - White Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
