Question about Centric Brake Disc for 02 2002 BMW 330Ci Rear, Driver Or Passenger
Brake light dash light on
Abs and brake lights alwaws on
    Problem Solver:
  • 14 Answers
May be some malfunction in ABS. because of error in ABS both ABS and brake light are glowing.
Take car to service station as they will be having tool to diagnoist fault in ABS.
Posted on May 08, 2014
Abs flashes on and off on dash then brake light flashes on and off brake lights flash when dash lights flash
dashboard brake light flashing randomly - Forums.focaljet.com
forums.focaljet.com/.../662231-dashboard-brake-light-flashing-randoml...
May 14, 2012 - 12 posts
Car run great the only issue is the dashboard brake light is flashing randomly. ...Finally, the instrument cluster is hardwired to the ABS module, ... Also,i change the parking brake switch and the light goes on & off less frequent.
what does ABS flashing light mean at the dashboard of my 1996 ...
https://answers.yahoo.com/question/index?qid...
May 3, 2009 - What does ABS flashing light mean at the dashboard of my 1996 ... just hard enough to skid a tiny but, then back off a hair to stop skidding.
ABS Brakes Troubleshooting - How to Troubleshoot Anti ...
www.popularmechanics.com/cars/how-to/a461/2265091/
Jan 30, 2016 | Cars & Trucks
Light wont turn off
it could be worn brakes for the red dash brake light if you mean the cars rear brake lights in the back of the car won't turn off the brake light switch at the brake pedal has shorted out making them stay on also you say the abs light is on there could be an issue with the brakes/sensors/air in the system if both dash lights are on the red one and the yellow one
Aug 23, 2014 | Cars & Trucks
I have a Mercedes c280 1996. My speedometer and odometer don't work along with abs. The abs light is on a long with the brake light on the dash. I have replaced the speed sensor and still isn't working?
hi i would check the abs module its located on the abs pump it controls the speedometer and can also bring lights on the dash eg abs &the brake warning light
Nov 23, 2013 | Cars & Trucks
91 Buick park avenue abs light. This happened after my friend was driving down the freeway and his tire blew. Now it just blew the rubber off and he was able to drive t off the freeway on the belts. And...
ABS LIGHT AND MODULE TROUBLESHOOTING:
Anti lock brake system light comes up when there is issue with car brake systems. It can be low brake fluid or faulty ABS fuse or its issue with brake system or assembly. Your vehicles brake system needs inspection.
To troubleshoot these issues, I suggest you to refer the help links provided below. There are direct links with accurate solution, for these specific issues.
Click the link below and follow the procedure: ------
All types of ABS LIGHT / brake problems and repairs
http://howtobyme.blogspot.com/2011/11/abs-and-service-light-comes-on.html
ABS light stays on but brakes work fine?
http://howtobyme.blogspot.com/2011/11/abs-light-stays-on-but-brakes-work-fine.html
VCS and ABS lights go on and off intermittently on Lexus?
http://howtobyme.blogspot.com/2011/11/vcs-and-abs-lights-go-on-and-off.html
The ABS and Traction Control Lights stays ON dash of car?
http://schematicsdiagram.blogspot.com/2011/06/abs-and-traction-control-lights-stays.html
ABS & Brake lights warning indicator steady on dash and speedometer not working for Dodge Ram?
http://howtobyme.blogspot.com/2011/11/abs-brake-lights-warning-indicator.html
Battery Light and ABS Light on Dash
http://whoisbyme.blogspot.in/2012/07/battery-light-and-abs-light-on-dash.html
Sometimes ABS light comes on while Driving?
http://howtobyme.blogspot.com/2011/12/sometimes-abs-light-comes-on-while.html
How Anti-Lock Brakes Work?
http://technoanswers.blogspot.com/2011/11/how-anti-lock-brakes-work.html
Brake System Troubleshooting?
http://technoanswers.blogspot.com/2011/11/brake-system-troubleshooting.html
Anti-lock brake light stays on all the time?
http://technoanswers.blogspot.com/2012/01/anti-lock-brake-light-stays-on-all-time.html
ABS light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
ABS trouble codes for all models?
http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html
2008 Toyota Highlander: ABS warning light Blinking and OBD Error codes Coming?
http://technoanswers.blogspot.in/2012/05/2008-toyota-highlander-abs-warning.html
2003 Lexus ES: VSC, TRAC OFF, ABS lights ON?
http://technoanswers.blogspot.in/2012/04/2003-lexus-es-vsc-trac-off-abs-lights.html
2008 Toyota Highlander Hybrid: Warning Lights Abs, Vsc & Brake Are On?
http://technoanswers.blogspot.in/2012/04/2008-toyota-highlander-hybrid-warning.html
ABS & Brake warning lights remains steady on dash?
http://schematicsdiagram.blogspot.com/2011/12/abs-brake-warning-lights-remains-steady.html
Can I drive the car without ABS fuse connected?
http://schematicsdiagram.blogspot.in/2012/02/can-i-drive-car-without-abs-fuse.html
Where is ABS/TCS module located on 2005 Cadillac Deville
http://schematicsdiagram.blogspot.com/2011/12/where-is-abstcs-module-located-on-2005.html
ABS motor keeps running?
http://schematicsdiagram.blogspot.com/2012/01/abs-motor-keeps-running.html
When the car stops, abs pump turns ON?
http://howtobyme.blogspot.com/2011/12/when-car-stopsabs-pump-turns-on.html
Replacing ABS unit on Buick Century?
http://technoanswers.blogspot.in/2012/02/replacing-abs-unit-on-buick-century.html
2008 Toyota Tacoma: ABS causes Brake pedal fade?
http://technoanswers.blogspot.in/2012/04/2008-toyota-tacoma-abs-causes-brake.html
Toyota Camry: Premature ABS Actuation?
http://technoanswers.blogspot.in/2012/04/toyota-camry-premature-abs-actuation.html
How to replace ABS Modulator Control Unit on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-replace-abs-modulator-control.html
How to replace ABS Pump Assembly on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-replace-abs-pump-assembly-on.html
How to remove ABS Accumulator on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-abs-accumulator-on-acura.html
How to remove ABS Control Unit on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-abs-control-unit-on-acura.html
These details will help.
Thanks.
Feb 04, 2013 | Cars & Trucks
I have a 2002 Saturn Sc2 in normal wether conditions the abs pump will kick in when applying the brakes. There is no abs light or brake light light that comes on in the dash. I unplug the abs fuse an
Probably a faulty wheel speed sensor on one of the front wheels. you will need a computer scanner or code-checker to determine if a sensor is bad... also, (unlikely) if your car has a tire that does not match the other 3 in diameter (wrong size tire) -- that would cause the same problem.
Aug 27, 2012 | Brakes for Saturn SC2
HOW TO GET RID OF THE ABS AND BRAKE LIGHTS ON DASH
Hello, welcome to Fixya!
The ABS and brake lights on your dash board is cause by low brake fluid/oil level. When the brake fluid/level of your vehicle is low, the ABS light and brake light will appear on your dash board, indicating that it needs to be checked.
So open your bonnet and check the brake fluid/oil and make sure it is not low. The brake fluid/oil is the first that needs to be checked in a situation like this.
If the above appears not to be the problem, please let me know.
Regards.
Nov 17, 2011 | Cars & Trucks
Changed rear pads. Brake indicator on dash is still blinking and chiming. How do you reset
Is it the "brake"repair light blinking & chiming?? Or is it the "ABS" brake light blinking/chiming. Brake light should be red, ABS amber
Sep 05, 2011 | 2001 Chevrolet Tahoe
Red brake light flashing on dash also yellow abs light on
we have 2002 passat tdi auto...the brake light on the dash has started flashing when we put it in park with a kind of clicking noise. any ideas?
Nov 10, 2009 | 1999 Volkswagen Passat
Dash board parking brake and ABS lights stay
you have an abs fault. have your abs system scanned for codes.
your base brakes will continue to function normally
Apr 13, 2009 | 2002 Chevrolet Suburban 2500
Centric Brake Disc for 02 2002 BMW 330Ci Rear, Driver Or Passenger Logo
288 people viewed this question
Top Centric Computers & Internet Experts
David Payne
David Payne
Are you a Centric Computer and Internet Expert? Answer questions, earn points and help others
