Question about Dryers
Dryer has no power
Recently repaired now has no power
  • 400 Answers
Not enough information. Model number? What was repaired and by whom (DIY or pro)? Check power connections, circuit breaker, control wiring. Check schematic (usually on or inside case) to trace out power flow. Fuse in control panel? These are all ideas of where to start checking. I hope it is helpful to you.
Posted on Mar 27, 2014
Testimonial: "It is a frigidaire affinity, model # FASG7021NW0 front load dryer. I did the repair myself. I replaced the high limit thermostat and thermal limiter. A week later and now has no power. There is a washing machine that is connected to the same outlet and it is working properly. Any suggestions?"
  • Pedro Yanez
    Pedro Yanez Mar 27, 2014
  • downhille Mar 28, 2014
    This is my second try at making a suggestion. For whatever reason, the Fixya website would not take my response before, and I tried 2 different ways.... hopefully you will get this. I found the manual online, and in the troubleshooting guide it suggests resetting the thermal limiter. Since this is one of the parts you replaced, I would start there. I would also try a power down in order to reset the microprocessor. I hope this is of help. Sorry it took so long to get back.
Samsung Dryer DV665JW has no Power. I already checked the plugs and Breaker system, they are okay but nothing happens when I press the power button. It is 4 years old. Is it worth repairing ?
First, when you say "no power", is the front panel display totally dead? If so, and you're sure 240v is getting to the back of the dryer where the power cord connects, then its most likely the main board has been blown--did you have a power outtage recently? They are notorious for damaging circuit boards. If the dryer lights up but won't do anything when you push the start button, check the door switch--it's a safety feature that won't allow the dryer to run with the door open. There are also thermal fuses inside which, if open, will kill the power. BTW, yes, the dryer is worth fixing--the cost of a repair won't be near what a new dryer will be.
Aug 14, 2015 | Samsung Dryers
Dryer will not start. Power light is on. No coins are stuck in drum liner. No blockage. Recent repair replaced mother board at a cost of $500.00. The same repairman rep
Without a complete model number it's hard to say which direction to go. You might need a door switch, some door switches with an interior drum light will be a 3 wire switch allowing the interior light to come on but not the dryer start when the door is closed. Some dryers had a start relay mounted inside the control panel, which is controlled by the main board, failure of these relays can cause a no-op situation. Pleazer Appliance...
May 06, 2014 | Whirlpool Dryers
FRIGIDARE DRYER WONT START
Hi elclarkjr - First, have you recently clean the lint screen/filter? Also check that the power cord is not damaged. Otherwise the dryer may possibly be experiencing more serious issues like; a wiring failure, faulty control board, thermal limiter, or defective door switch that only a professional can repair. I personally recommend consulting a service provider for a proper diagnosis and to move forward accurately.
Feb 23, 2013 | Frigidaire ATF6000ES Front Load Washer
Dryer model DBSR453EB1WW won't start. It has power and the light comes on when the door is opened, but when you try to start it there is nothing.
8_29_2011_7_53_41_pm.jpgYou might have a tripped high limit. Looks like this.
Mounts on rear wall atop the heater element. If the dryer needs cleaning it someimes will overheat and trip this limit. I recently repaired one of these and made some PHOTOS
Aug 29, 2011 | GE DBSR453EBWW Electric Dryer
My whirlpool dryer WED5800SW0 won't start. It is receiving power because the timer switch still makes the clicking sound before you start the dryer. I have had recent issues of the pin not engaging...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2011 | Dryers
GE Gas Dryer DBSR453GB1WW began squeaking during the most recent drying cycle. We should we try to repair ourselves or get a repair tech?
The squeaking noise is most likely emitting from the drum bearing (key#543). In order to access and replace the drum bearing will require removing the drum. The drum bearing/sleeve is part# WE1M462. I added the instructions on how to remove the drum in the images below. NOTE: Disconnect the power cord from the power source before servicing the dryer.
Jan 13, 2011 | GE DBSR453GBWW Gas Dryer
Laundry room flooded
could be as simple as a blown thermal fuse.  most places will allow credit for a service call toward purchase of a new machine if repairs are too costly
Jul 28, 2010 | Kenmore 65924 Electric Dryer
Power outage recently. won't turn on
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 10, 2010 | Kenmore 64672 Electric Dryer
I recently moved and now my dryer is flashing PF
According to Whirlpool, all you need to do for “PF” (power failure),
is check the following:
Was the drying cycle interrupted by a power failure?
Press and hold START to restart the dryer.
To view the owner's manual for your dryer click on this link & choose the model # that you have from the list.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=WED8300&siteCd=WHRCOM&userType=Consumer
May 27, 2010 | Whirlpool WED8300S Dryer
We were recently given a kenmore dryer, without a
Here is a tip about hooking up dryer cords...
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
May 09, 2010 | Dryers
Dryers Logo
Top Dryers Experts
