Question about GE WBVH6240F Front Load Washer
Clanking noise during spin cycle, burning smell too
Made a clanking noise (different than out of balance load sound). Went to check and found machine smoking. Stopped it and unplugged it. Checked next day and no wires burnt. Plugged in and started. Seemed to work. Did a spin and rinse cycle (empty). Was loud in the spin and as it accelerated, began clanking louder. Was not able to isolate where it came from. Could not tell but thought I began to smell something hot/burning again so stopped machine.
  • Kathy Burdick Mar 28, 2014
    I had this same type of thing happen to my machine. The installation people forgot to remove the shipping pins which then caused the machine to not run properly after a few years it broke the brackets that hold the drum in place. The drum then would fall forward against the rubber seal causing smoke and a burning rubber seal.
  • 244 Answers
SOURCE: very loud washer during spin cycle
it will be your bearings not the belt or pulle you can check this out by having it empty open the door place the palm of your hand on the outside were the top of the door closers to place your fingers ti the inside of the top of inner drum and pull your fingers towards your palm if there is the slightist movement than the bearings need replacing
Posted on Aug 22, 2007
SOURCE: High Pitch sound during spin cycle
sometimes the high pitch will come from rear bearing open door pull up on basket see how far it moves up down also ck the pump for thngs in it
Posted on Feb 25, 2008
SOURCE: GE Top load washing machine stop and stars during spin cycle
I had the same problem. The machine will do the washing cycle. At the start of the spin cycle it would start turning with a lot of clicking sounds and then would stop spinning. The water pump would continue working without problem. The motor tries to start again in about three minutes, however, repeats the same behavior. I have a reasonable mechanical and electrical knowledge. I was sure that the overload protection switch of the motor was tripping. I opened up my machine---a GE super capacity top loading machine. Took off the belt and turned the transmission pulley. It turned easily in both directions (washing and spinning). Hence, the transmission was good. Next, I checked any water accumulation in the spin tub. If the water is not drained properly before the spin cycle, it would overload the motor. There was no water clogged in the spin tub. Finally, I dismantled the electric motor. There was a clutch assembly underneath the motor pulley. I dismantled it and found the clutch very dirty with some grease that had turned sticky. I cleaned the assembly thoroughly with alcohol and assembled back the machine. The machine is running perfect after that. Conclusion: The clutch assembly was mis-functioning. Reason: When the spin cycle starts, the spin tub is very heavy and cannot achieve the full speed quickly. On the other hand, electric motors must get to their running speed fairly quickly or else overheating of motor would happen. A proper functioning clutch allows the motor to run at their optimal speed while transferring enough torque to the spin tub to slowly speed up the tub to its fullest. In my case, the clutch was sticky, thus overloading the motor which would trip as it overheats.
Posted on Mar 02, 2009
  • 106 Answers
SOURCE: Loud banging noise durning washing machine spin cycles.
First plug off the wall. Open the machine from behind to examine if any shock-absorbers(known as dampers) or springs have come off or broken. Your dealer could help with spares. But you could do the job yourself.
For spares: (which is good)
SOURCE: GE washer stopped spinning and smell of burning out lingered
I am going through this right now and best I can tell..needs a new belt. Pop the front off of your washer (UNPLUG IT FIRST:)) and see if there are black shavings on the bottom. The appliance place where we usaully order our parts from do not carry this belt in stock so it will have to be ordered. Price from them was $19.00+ tax
Posted on Aug 13, 2009
Machine making a knocking noise during spin cycle. The drum shaft has alot of free play front to rear and I suspect that is where the problem resides.
If your machine is making louder than normal noise during spin it could be the failure of the basket. Mine is just under three years old and the basket became looser than normal in the tub. I diassembled the machine...a lot of work...and found the aluminum casting around the shaft and bolted to the basket had rotted away. It looks like it was attacked by the bleach since I had my water checked and its pH is fine. It is likely the root of the smell we have experienced with our clothes when they sit too long in the machine. I spoke with GE and they gladly agreed to replace the parts needed but it is a ton of work to install them. I plan to treat the new part with some zinc chromate if I can get some before the parts arrive. See the picture if it attached correctly.
Nov 16, 2009 | GE WSXH208A Front Load Washer
Fisher & paykel GWL11 washer won't rinse
sounds like you have two problems, the burning smell is probably the pump,out of balance is usually due to worn aout suspension rods
Oct 14, 2017 | Fisher and Paykel GWL11 Top Load Washer
Washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Burning smell and smoke
Sounds like the belt has burnt off. You can check this by tilting the machine back and looking under it. Sometimes the belt gets hard and just starts to slip, then it will smoke and burn off. If this is the case, Just replace the belt and this will fix it.
Feb 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Mah3000 aww making extremely loud, clanking, grinding during spin
Gotta admit tonytools albeit not cheap has the best easiest tool to do that rough difficult repair.
Jan 01, 2009 | Maytag Neptune Washer
Washer just stopped
I would check the drainpump ans see if there is something jammed inside like a coin or screw,nail etc before doing anything else .Unplug the machine first though . A burning smell will occur with a load of water trying to spin .
Nov 06, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Loud noise on Spin Cycle
Oct 11, 2007 | Admiral AW22 Top Load Washer
GE WBVH6240F Front Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
