Question about Fish
How-to set-up a home aquarium
Looking for some "tips and tricks" about setting up a 40 gallon home aquarium
  • 2,760 Answers
As with any aquarium its all in the method !!
first think about the placement of the tank ? can I get to everything easily ? is there a power source close by ? whats already on that outlet? is there anything that water would damage by it getting on nearby ? and last but most important will the floor support its weight (this is the #1 thing that's forgotten most ) 8.33x40= 333 lbs !! and that's just the water !! the tank adds another 40 pounds and then think of the gravel , me id count on having about 500 pounds there for that size tank . remember the floor will need to remain steady with that weight on it (not springy) , its not uncommon to reinforce floor joists underneath a tank with steel beams !!!
if this is your first large tank id go slow and add only a few fish to start off , you'll be playing catch up with your water chem to get a "happy" point at first and it be a terrible shame to loose a ton of fish due to that !!
Posted on Mar 21, 2016
How do set the temp on a 15 gallon tank
leave the heater unplugged in the aquarium in for several hours.Then plug it in briefly and see if the neon bulb lights up (sort of an orange color). If it is on, turn the temp set knob counter clockwise until it goes out. Then turn the knob clockwise slowly until the light comes on again. Now your heater is set for approximately the current temp of the aquarium water. Now adjust the knob in very small increments, waiting hours between adjustments until the water is at the temp you want.
Jul 29, 2014 | Fluval Hagen M50 Submersible Aquarium...
What is an open aquarium stand?
An open aquarium stand is a standard stand that made of light materials (glass, metal) and can hold glass aquariums of up to 40 gallons. It has a rectangular shape.
Sep 09, 2012 | Fish
When is it useful to use 2 heaters instead of one?
Typically, larger aquariums require 2 heaters in order to get the same amount of heating as smaller aquariums. For example, you should buy 2 100 watts heaters for a 40 gallon aquarium.
Sep 05, 2012 | 1topstore Fish
How do I know what size heater to buy for my aquarium?
The basic rule is that a heater needs to use 5 watts in order to heat 1 gallon of water. For example, if your aquarium has 10 gallons, then you need a 50 watts heater. If you have a 50 gallons aquarium, then you need a 250 watts heater.
Sep 05, 2012 | Fish
How can I properly determine the amount of watts per gallon of lighting I need for my aquarium?
How many watts you need depends on the type of plants and the volume of the tank. Here is an excerpt from an article that will help you determine proper wattage.
Instructions
Identify the species of plants you have in your tank or that you plan to put in your tank and how much light that species needs. Each species of plant will have an optimal lighting requirements, from low light to bright light. To determine the plant species, compare photos on the Aquarium Plants Photos and Profiles page of the Aqua Hobby website, or take samples of the aquatic plants to your local aquarium store for identification.
Write down how much lighting each of the plant species in your tank needs. Give each plant a rating of low, medium or bright. The books "The Complete Fishkeeper" and "Freshwater Aquariums for Dummies," as well as your local fish store, are good sources of information for this.
Review your list and determine what type of plant dominates your tank. For example, if you have mostly plants that need bright light, then use a bright-light formula. If you have an equal mix of plant lighting needs, then use a medium-light formula.
Calculate a range of watts of lighting you need for your tank with one of the following formulas, depending on the amount of light you determined you needed for your plants. For low light, multiply one and two by the number of gallons. For medium light, multiply two and three by the number of gallons. For bright light, calculate three and five by the number of gallons. For example, for a 20-gallon tank with plants that need medium light, you would get a range of 40 to 60 watts (2 x 20 = 40 and 3 x 20 = 60).
Read more: How to Determine Watts Per Gallon for Aquarium Lighting ' eHow.com http://www.ehow.com/how_8014286_determine-per-gallon-aquarium-lighting.html#ixzz23KB8HErA
Aug 14, 2012 | Fish
Is it possible to make my own aquarium filter at home?
I have found you a how-to guide on making your own filter for your aquarium; however it is only productive for aquariums containing up to 40 gallons of water.
http://www.ehow.com/how_7718545_make-aquarium-water-filter.html
Aug 14, 2012 | Fish
Are all aquariums made out of glass? We want to buy an aquarium for our home but I don't know much about what to look for.
No. Although many aquariums are made of glass, some are made from acrylic plastic. While glass aquariums are cheaper per gallon and harder to scratch, acrylic versions weigh less and are harder to break. You need to consider all of the advantages and disadvantages of each and then make your decision.
Jul 31, 2012 | Fish
What are the different sizes and shapes of aquariums I can buy for my home?
There are so many varieties of both size and shape. I found you a great buyers guide that explains several varieties, as well as how many gallons of water go in each.
http://www.oldtownaquarium.com/?q=aquarium-shapes-and-sizes
Jul 31, 2012 | Fish
Fish Logo
420 people viewed this question
Top Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Are you a Fish Expert? Answer questions, earn points and help others
