Question about Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125
My pieps froze and now my tankless water tank leaks how do i get a new part
I haave a aq125 blp molde #08700704 ser. # 7703531977
    Genius:
  • 1,114 Answers
Bosch Aquastar 125B Water Heater Repair Parts Pre January 2003
Bosch Aquastar 125B Repair Parts Selection Grid
This web site has Aquastar 125B parts. It appears your unit was manufactured 7/7/02, so that is what I pulled up for you. At least this will be a start for you to locate the part. I hope these links work.
Bosch Aquastar 125B Water Heater Repair Parts Post February 2003
Posted on Mar 27, 2014
3 Suggested Answers
gary1121
  • 332 Answers
SOURCE: Looking for Outdoor Tankless propane water heaters
it will tell you right on the box if it for indoors or out doors either way they have to have a cover over them,,
Posted on Jun 09, 2009
SOURCE: aq 125 blp Bosch tankless water heater, pilot
Natural Gas: Pilot burner or orfice may need to be cleaned. Pg 11 manual.
http://www.boschhotwater.com/Portals/7/TechManuals/125BL_English.pdf
Most tank and tankless gas water heaters today suggest annual cleaning and maintenance of burner.
Open following links for Bosch troubleshooting resources:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/125BLTechSupport/Troubleshoot/tabid/474/Default.aspx
Posted on Jun 14, 2011
Leaking tank
Replace heater?
Do not install tankless.
Call for service?
Manual does not show troubleshoot or repairs
Bosch site does not show the AE125 series water heater any longer
http://waterheatertimer.org/pdf/Bosch-AE115-AE125_manual.pdf
Gene
Oct 19, 2014 | Bosch PowerStar AE125 AE125 Whole House...
What is the best replace the elements and thermostats or just get a new waterheater
Best is to replace anode rod, and leave elements and thermostats alone until they go out. IF you can get the anode out.
http://waterheatertimer.org/Replace-anode-rod.html
Anode rod prevents tank from rusting. Anode rods deplete over time in most situations, and then tank begins to rust. If the anode can be successfully removed, and updated, then tank rusting stops, and you're tank is good for another 10 years.
So answer to question is: Depends if tank is rusty, and if tank is sitting in drip pan to protect home from possible leak.
http://waterheatertimer.org/Leaking-water-heater.html
Tank-type electric heater is unique since it can last almost indefinitely, with maintenance. Therefore maintaining tank-type electric water heater can pay you $5-10 per month.
http://waterheatertimer.org/How-to-maintain-water-heater.html
Ordinary electric tank type can outlast all other water heaters, and be far simpler to fix yourself than any other type heater: including gas tank-type, electric hybrid tank-type, electric-and-gas tankless etc. More complicated heaters will eventually fail, and the lifespan is limited. Which is argument against buying expensive water heaters that are controlled by computer chip etc. Avoid tankless promotion. Tankless cost more..Period.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
May 01, 2013 | Water Heaters
Bosch 125fx heater barely heats water
1) Recommend replacing tankless with ordinary tank-type gas water heater.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
http://hometips.me/Mar/Which-is-best-gas-water-heater.pdf
2) Tankless cannot be exposed to more than 11 grains hardness in water or unit will fail within 2-5 years. Water softener is required.
http://hometips.me/Tls/Battelle_Water-softening-research.pdf
3) Descaling tankless water heater each year will not restore functionality, or restore efficiency of tankless, nor restore full efficiency to tank-type gas water heater.
4) Bradford White side-by-side testing research comparing their tankless with their tank-type shows that tankless will save $1-8 per month on energy bill vrs ordianry tank-type ....but conclude that tankless 'fall far short of payback' due to maintenance, repair, installation and replacement costs.
Study compared full cost, and not just monthly energy bill, since All costs are energy.
Feb 16, 2013 | Water Heaters
Water not as hot as it was.
Tankless require yearly service to keep burner and combustion parts clean and check electrical connections, gas solenoid, gas pressure, venting, etc.
Read product manual for advisories and recommended maintenance.
Yes, aren't you glad you saved the manual.
Always check that local area has affordable and qualified service technician for your brand before buying tankless.
Before calling service technician, copy following link for general troubleshoot resources, including some manuals, and links to Bosch.
http://waterheatertimer.org/pdf/No-Error-Code.pdf
Try turning temperature down.
The fact there is no error code, and the gas is not firing correctly, means you have a small unit with no error codes and PC board has failed ... or it means you have a unit with error codes and possibly bad PC board.
If problem is the PC board, then Bosch will send you new board, and expect same level of repair success as though your computer's motherboard was replaced.
You can buy ordinary box-store tank-type heater and install yourself same day for about $325.
Then maintain and fix it yourself. I recommend AO Smith/American/State/Reliance/Kenmore/Whirlpool since these are easy to maintain with clear directions in manual, plus AO Smith posts service manuals for the whole line of products, and any local plumber can fix them with ez-to-locate generic parts.
Sep 07, 2012 | Bosch & Tankless Water Heater
I have a bosch mod. 45557701 tankless elect. water heater I need a new thermal cutout switch, and cann't find anyone who sells it. I have to reset all the time all day long it makes sounds like a air...
1) Call Bosch.
Gas Products Technical Support: 800-642-3111
Electric Product Technical Support: 866-330-2729
2) Save money and buy whole new tank-type
electric water heater at local box store for $250, and go on-line and get coupons before purchase.
http://waterheatertimer.org/pro-n-con-for-tankless-water-heater.html
Sep 15, 2011 | Bosch PowerStar AE125 AE125 Whole House...
Failing ignition on Bosch Aquastar AQ125-HX tankless on demand water heater. Carefully followed all directions on device to best of ability. Gas supply is full and on. Water pressure should be...
Before calling service technician, open following links for Bosch troubleshooting resources:
Resources at Bosch
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/tabid/370/Default.aspx
Typical Bosch Aquastar manual:
http://waterheatertimer.org/pdf/Bosch-aquastar-170vp-manual.pdf
All tankless and tank-type gas water heaters require regular cleaning and maintenance.
It is unknown if your unit needs maintenance or repair parts, but catching up on maintenance using information from manual is good place to start.
Gas appliances are increasingly complicated and experienced technician is good resource to have in local area before installing tankless.
Apr 16, 2011 | Bosch AquaStar Indoor Natural Gas Tankless...
I have a bosch aq125 ding? the hot water is not sufficient to the temperature for a health dept to pass the restaurant to stay open. how do i get a hotter temp? is there something that is clogged or not...
That is a residential unit and at maximum will raise water temp 90 deg at 2 gallons per min.. You need at least one commercial unit with a thermostat that will allow high enough water temp. to pass health dept. requirements, and a self heating dishwasher at a minimum.
Jan 21, 2011 | Bosch & Tankless Water Heater
Jun 09, 2009 | Bosch AquaStar Propane Tankless Water...
Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125 Logo
138 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
