Question about Garden
HARD START WANTS TO START WHEN COLD BUT TAKES AWHILE...ONCE RUNNING, IT RUNS AND IDLES GREAT.....START UP AFTER IS GOOD
  • DAVE DUDEK
    DAVE DUDEK Mar 29, 2014
    tries to start but cant when cold....once it starts, it runs fine
  • DAVE DUDEK
    12 hp.ic motor
  • 57 Answers
Probably choke not engaging properly, if you have to ask it is probably a workshop job.
Posted on Mar 30, 2014
4 Suggested Answers
SOURCE: 8n tractor runs good at first then after awhile starts to sputte
Check fuel filter in the shut off bowl. Then check the needle and seat in the fuel sediment bowl on the bottom of the carb.Also check the float when you pull off the sediment bowl.
Posted on Apr 15, 2009
libaredneck
  • 119 Answers
SOURCE: my john deere 345 shuts down while running.
check the tank for debris blocking fuel outlet. also change fuel cap as it could be pulling a vacuum on the tank.
Posted on May 05, 2009
  • 6468 Answers
SOURCE: my lt 1000 17.5 hp riding mower will backfire once in awhile when starting but runs fine once it starts. why
first smell the oil is there a gas smell to it?the needle valve maybe dripping fuel and over flowing into the intake
Posted on Apr 19, 2012
Could bad maf sensor and bad idle air valve have vehicle stall then hard to start for awhile and cuts off after 10 minutes of driving
I would also suspect the ignition module. They tend to work ok for a few minutes when they are cold, then fail once they warm up. If you wait awhile for the ICM to cool down, it will work as well as it can until it warms up again. A code scanner is your best friend to know where to start looking, and to perform tests and log data.
Feb 16, 2016 | 1997 GMC Yukon
Ram idles rough at start then fine after warms up
1. Injector cleaner.2. Does it have enough miles (75K-plus) to consider changing plugs?3. What's the air cleaner look like?4. Any codes showing?Here I am trying to give answers when I probably know less than you....Good luck.
Dec 16, 2011 | Dodge Ram 1500 Cars & Trucks
XLT1200 hard to start in water after it has been running awhile. Once starts, runs good. Why so hard to start once the engine is warm?
fuel pump diaphrams could be hard ! compressions all over 100psi minimum pressure? carbs clean ?
Aug 29, 2011 | Yamaha Boating
Ram 1500 239 runs about 8 to 12 miles then backfires and looses power let sit a while and run good for acuople more miles before running bag again
It sounds like your ignition coil is overheating. Once it cools down it will fire properly until it gets hot again. Replace the ignition coil and you should be all set.
Feb 23, 2011 | 1994 Dodge Ram
2003 f250 diesel 6.0 hard start when cold, idles rough and dies. runs great once warmed up. Battery light is on but volts are 13.? Not sure if the 2 problems are connected or not
It sounds like your preheat system is not working properly on the cold startup. Haynes has a Diesel Engine Repair Manual, part #10330 that will help you correctly diagnose and repair.
Battery volts at 13 is good but a fully charged battery should be close to 14.2. It would be a good idea to get the alternator output checked and a load test done on the batteries.
Hope this helps.
Jul 12, 2010 | 2003 Ford F250 Super Duty Crew Cab
Very hard to start in the morning.Has new battery, plugs and plugwires and engine turns over good but it takes 8-12 trys before it starts. After it does start if you touch the gas peddle it dies. After it...
Fuel injected? My 87 Porsche and 89 Alpha Romeo have Bosch fuel injection system (the best). They both have a cold start injector driven by the onboard computer. Computers hardly ever fail. But the sensor that tells the computer that the engine is cold can fail or the cold start injector can fail or be dirty. Please go to your autoparts store and get a repair manual, best $ 25 you will ever spend. Good Luck!
Mar 06, 2010 | 2000 Volkswagen Jetta TDI
Very hard to start but once it idles for a minute it runs great any suggestions?
cold start is not working right,, thats why its hard to start, when it warms up a little it runs ok,,,,fix the chock!
Nov 14, 2009 | 2003 Buell Blast
Hard to start
check the wire connected to the air filter housing for good connection. Also check the rubber intake tube for any cracks or holes. Mine did the same thing.
Jan 20, 2009 | 1992 Eagle Talon
1991 dodge colt won't idle when engine is cold.
probably oil, it may be too thick when it's cold but once it warms up it liquefies and your engine runs smoothly. you could try changing oil, I'm guessing if you have a high performance oil the chances this is the problem may be greater since high performance things are usually geared towards working well when everything is hot
Jun 29, 2008 | 1991 Plymouth Colt
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
