Question about Daewoo FRSU20IA Freezer
Water leakage I see some water in front of my freezer..What might be the issue as it not that ofter from every alternate day I see some water
    Problem Solver:
  • 4 Answers
Probably the drain line from the freezer is clogged with debris or it is frozen. Empty the freezer and shut it off and defrost the line and check the drain line for proper flow.
Posted on Mar 30, 2014
Ice buildup in bottom of freezer--puddle of water on floor
this sounds like your freezer is operating properly, except that the drainage of the water when going through the defrosting mode is not draining properly, pooling on the bottom of the freezer and then freezing. Check the drainage hose for the defrost in the lower pan. I would remove everything, place in ice chest, let the unit completely thaw out and then inspect. I hope this is beneficial.
Aug 05, 2009 | Freezers
Why is my fridgidaire freezer leaking water and the defroster not working?
Hi Friend, this is Z. Thank you for your post!
I understand your Frigidaire freezer is leaking and not defrosting; however is water leaking from behind, front or underneath? Also, did you notice any error codes, noises, or other strange functions prior to this issue? With this information I can assist you better in pinpointing the problem.
Jul 07, 2014 | Frigidaire Freezers
Our frididaire upright was working fine and we noticest leakage and the compressor is on and running and it is cold but the food was defrosting. When you close the door we do not hear the "sucking...
if it has a water in the door let me clarifiy I mean water like a water dispencer common with side by sides the hose some times will cause the seal not to seal properly
Feb 27, 2011 | Frigidaire 20.3 cu. ft. Upright Freezer...
Doesn't freeze water or other liquids
dear sir/madam
i think there is low gas problem then please contact to your maintenance personnel for find out the leakage and brazing it. after refill gas.
hope answer the question
thank you
please vote!
Sep 02, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Not really cold, Defrosted it and put everything back from the coolers and the water btl on the door hasn't frozen all day. The frozen meats are holding their own and staying frozen but not real cold in...
u've brocken the coolent circulating pipes which v;ll be surrounded in the freezer box....!! due to the leakage of compressed gass....its not getting cold,.
thnak u sir...
all d best, have a great day
Jul 18, 2009 | Freezers
Freezer not freezing, and leaking
If this unit has an ice maker and you noticed water leaking into the refigerator, I had a similar problem. The water turn off valve for the ice maker had a small piece of sand or grit lodged in it and stopped the valve from closing properly. So it could not turn of completely and the valve became increasingly more sloppy as the piece of sand was wedged in further. The solution was to replace the samll valve. An easy job for someone a bit handy.
If the water has frozen in the bottom of the freezer compartment the colliing port for the cold air may also be affected. Don't chip the ice out of the bottom, defrost it with pans of hot water.
Hope this helps
May 03, 2009 | Frigidaire Freezers
Leakage and warm sides
The outsides should will be warm.  This is normal because the condensor lines run thru the cabinet from about half way up the sides and over the top.  Which is why the you shouldn't have anything stacked on top of the freezer and enough room on the sides of it for air flow.  As far as the water leak, tell me exactly where you see the water and does the bottom of the freezer (inside) have a sheet of ice on it.  If there is ice there then the drain behind the bottom panel in the freezer is frozen over and will have to be thawed out.  Let me know what you find.  If you have further questions I may need the entire model # on the sticker inside the freezer.
Oct 21, 2007 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Daewoo FRSU20IA Freezer Logo
199 people viewed this question
Top Daewoo Freezers Experts
mike cooper
Ken Wieczorek
Ken Wieczorek
Keith Poitier
Are you a Daewoo Freezer Expert? Answer questions, earn points and help others
