Question about Xstamper Office Equipment & Supplies
How to clean housing on xstamper #1
My xstamper #1 was turned upside down with the caps from the ink wells off & ink spilled out on the the inside edge of the stamp & now ink continues to spill out around the edges randomly
Eddie Rentas
  • 59 Answers
SOURCE: lifting the top to clean spills
Hi
Look under the counter top find the bolts that secures the stove top, unplug the power and remove the top, then look around the edges of the stove top and you should see some small screws that atach the glass to the frame, remove those and lift the glass carefuly, "DO YOUR THING" and then just reverse the steps and done.
Eddie Rentas
Tupper Lake NY
Posted on Jun 26, 2008
SOURCE: Spilled wine in keyboard
it really depends, on the logitech stuff they have the accidental spill holes in the bottom so liquid doesn't pool but there is a possibility that it could have saturated the board and ruinied the internals, just try to dry it out as best you can and hope for the best
Posted on Jun 12, 2009
  • 1738 Answers
SOURCE: My Dell Laptop will not type any numbers except 5
You probably shorted your keyboard. You can buy a replace fore resonable price.
Posted on Nov 21, 2009
SOURCE: Polaroid PoGo Digital Photo photographs streaky with purple edge
TO CLEAN PRINT HEAD, TAKE AN A4 SHEET OF PAPER CUT IT TO SIZE FOR THE POGO,BUT MAKE IT (3) THREE THIKNESSES THIK, FEED IT IN UNDER THE PRINT HEAD AND CLOSE LID, WHILE THE PAPER IS BEING EJECTED PUSH UP ON THE PAPER THAT IS BEING EJECTED WITH YOUR FINGERS, YOU MAY NEED TO DO THIS A NUMBER OF TIMES, BUT IT WILL CLEAR THE STREAKING. IT WORKED FOR ME AND MY POGO DOSE BRILLIANT PRINTS.HOPE THIS HELPS PEOPLE. JB
Posted on Feb 25, 2010
alicantecoli
  • 22156 Answers
SOURCE: My 2004 VW Beetle, convertible top is coming loose
araldite ,epoxy resin two pack type adhesive
Posted on Oct 12, 2010
White macbook 10.5.8 pop spilled on keyboard
Ooouch ! After you've dabbed up (the spill) as much as you can, you may find some keys sticking ... i.e. when you touch (push) it (down), it doesn't pop up immediately. These are the keys you'll want to clean individually.
You can pop off the key top off (with your fingernails) from the top corner of the key. Once the key-cap top (cover) is pried open, lift the key-cap upwards and detach it from the bottom edge. You'll hear pop's when you do this. Once the key-cap is off, you'll see the mechanism under it. You'll want to clean things as best as you can ... very carefully. If the underside of the key top (cap) is sticky/dirty, rinse/wash it (with water), dry it well (before reinstalling it). Often the "stickiness" is caused by the (white translucent) plastic pieces (at the very top) not dropping flat down (immediately) after you lift it. (You wouldn't want to disassemble the parts below the (white translucent) square plastic pieces. Just clean/wipe it carefully using a cotton swab/toothpick).
You can remove the top (square plastic) pieces by pushing the tabs at the bottom corners ... downwards ... using a toothpick. This "top" square piece is actually two (square) pieces (snapped together), one inside the other. The inside piece is supposed to spin easily/quickly .... if not. it's probably sticky/dirty, rinse/wash it (with water), dry it well (before reinstalling it).
The trick is to make sure you know/remember how to reassemble the 2 pieces (after taking it apart and washing/rinsing/drying it) applying the right connection points to fit ... before you put the key-cap back on . The key-cap is put in place by just putting it in place and pressing down to snap it back on.
The larger keys (Shift, Space, etc.) has metal bars holding down the cap, etc., so it may take more effort to pop the key top (cap) off.
If you have quite a few to do, and you don't want to risk breaking anything, the Apple store is probably your next stop.
Oct 26, 2013 | Computers & Internet
I cannot put the two pieces of my received versadater stamp together and my stamp did not come with instructions....
I worked for a company that sold these stamps. Xstamper made some changes to this stamp & in doing so, the dater part would no longer attach to the received piece. Contact the company you purchased this from. Xstamper fixed our problem by going back to their older model so the two pieces would join together.
Mar 30, 2011 | Xstamper VersaDater Line Dater, Message...
Close ink cover
several things could cause you to get this kind of error
1) You put the cartridge in too quickly..always slide ink cartridges in squarely and carefully pushing in so as to not make air pockets in cartridge
2) Ensure that all the cartridges are facing up, if upside down, ink will move around and....cause air pockets
3) Don't twist or force the cartridges into place..they only fit one way, and if you twist and force them they can damage the contacts
4) Make sure that is it a Brother brand ink cartridge..they use a patented connection and generics do not have the proper connections
5) Removing the yellow protective caps with the cartridge upside down can also cause air pockets to form..air inside the ink cartridges is a HUGE cause of faults, but most people don't even realize that it would make a difference
6) Removing the yellow caps without twisting the green pressurizing knob may also leafd to air pockets.
Dec 14, 2010 | Brother DCP 165C Compact Color Inkjet...
How to open canon ip1900 coverings
Remove the paper and cartridges.
With the printer facing you, open the cover and remove the 2 screws you can see extreme left and right. These are the only screws needed to remove the covers.
Now turn the printer upside down and look for 2 arrows on the left and right side of the printer. Stil a screwdriver up where they point to to undo the catches. Now shove the two side panels backwards from the printer.
To release the remaining top panel and lid, pull it off its plastic catches.
Apr 19, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
I spilled a small amount of coffee onto the keyboard while the computer was in use. I immediately turned it upside down and dried it off. I cannot get it to power " on"
Don't power it on. If that is doesn't seem kind of all water proof kind. Take out the battery and the AC power supply. Turn the laptop upside down without closing the screen monitor and let the coffee be out. Dry it/or take it on a reputable shop( I may suggest).
Have it clean. Hope it doesn't fry something inside.
Sep 21, 2009 | Lenovo ThinkPad T400 - Intel Centrino 2...
Keyboard not responding after food spill and clean up
what type of food spill and how did you clean it affects the keyboard. What type of keyboard is it? Is a separate keyboard like for a desktop or is it on a laptop? for desktops, quickly turn the keyboard upside down to prevent fluids going further into the keys. After food spill, use a can of 'air'. Use short blasts to help blow out and dry any moisture out-at the same time, be sure to have the keyboard with keys facing down. for laptops, almost same-turn entire laptop upside down to allow fluids to escape. Be careful not to let the fluids come in contact with screen. Hope you have done some of this. If it doesnt work, you may need to replace the desktop keyboard and for laptops-take to repair shop for internal cleaning. Hope this helps
Aug 24, 2009 | ASUS Computers & Internet
Fault Code 08.001.44 Paper Jam
That is a failure in the maintenance kit tray area.
1. The Cap/Wipe/Purge belts have loosened up or are out our alignment. - Adjust the Cap/Wipe/Purge belts and follow the procedures outlined in the Service Quick Reference Guide for adjusting these belts and proper alignment. 2. Ink contamination or spilled wax is keeping the Cap/Wipe/Purge from properly moving. - Clean up spilled ink from the drum maintenance rails guides, sensors, and pulley belts. 3. The Drum Maintenance rail guides are out of position. - Remove and reseat if necessary. These rails may have suffered fatigue and may show signs of cracking or breaking. If this is the case it is a recommendation to replace the Drum Maintenance rail guides
The maintenance drawer itself may have the end tabs worn down from lifting up and down.
Mar 27, 2008 | Xerox Phaser 8200 Laser Printer
Spill
U can open it up....
But the speaker/Woofer may got damaged, which had to be replaced....
Contact the local tectnicians..
Dec 17, 2007 | Harman Kardon SoundSticks Computer...
Top Xstamper Office Equipment & Supplies Experts
k24674
Are you a Xstamper Office Equipment and Supply Expert? Answer questions, earn points and help others
