Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Cub Cadet LT 1046 blade won't engage
Blade won't engage
    Problem Solver:
  • 5 Answers
Check all your safety switches.
Posted on Apr 29, 2014
bbreton
  • 437 Answers
SOURCE: cub cadet lt 1018 blade will not engage when i
It sounds like the PTO is not engaging. This is the pulley on the bottom of the crankshaft and the belt for the deck goes around. It may be time to buy a new electric PTO to solve this problem.
Go to www.precisionope.com. and put your information in. you should find a part number you need there.
Posted on Sep 28, 2009
bbreton
  • 437 Answers
SOURCE: I have a cub cadet LT 1045 and every so often the
There are a few possibillites: a bearing is starting to go on the quill assembly or idler pulley; the PTO on the engine is heating up and quitting to work until it cools off; or you may have a switch going bad. I would look at this first.
HTH
Good Day
Posted on Nov 10, 2009
  • 3 Answers
SOURCE: My Cub Cadet i1042 tractor shuts off when the
Check for bent blade against deck housing.Possible you bent something on mowing deck,check all spindles and pulleys.You could have something hung on blade and making contact with deck. Rarely will the motor be hurt from hitting object on rider.
Posted on Apr 25, 2010
  • 15139 Answers
SOURCE: Sounds like a blade is hitting something on my Cub Cadet LT 1042.
with tractor off and key in pocket check blade for straightness if straight then check by moving it up down if loose check retaining nut if nut tight then possible mandrel bearing burnt or shaft bent also check the mandrels are bolted correctly to deck lastly but least likely is a bent deck
Posted on May 09, 2010
SOURCE: CUB CADET LT 1046 WONT CRANK
LT1024 Won't start. It spins over but doesn't act like it is firing.
Posted on May 15, 2011
Ltx
Contact mtd.com help desk. Tech help can get you to the right parts to make needed repair. Most likely it is your blade spindle assembly that has been bent allowing belt to slip. It is not that diifcult to replace.
Jul 18, 2014 | Cub Cadet 2012 - LTX 1046 - 21.5 HP...
Why does my cub cadet die when i engag the blades
Bad pto switch or child back up switch on trans. shorted
Jul 01, 2014 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
My john deere 14sb mower starts but kills when I engage the blade
Check your safety seat switch. Unplug the wiring harness to the switch and place a paper clip into the harness. This will bypass the switch unless you have a continuity tester to test the switch.
Aug 07, 2013 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
How do you remove the pto on Cub cadet LT 1046?
it should pull off after removing the center bolt
Aug 05, 2012 | Garden
Cub cadet rzt 50, hit stump, blades wont engage but not bent
The blades on this cub cadet are activated with air pressure. Chances are that when you hit that stump, you either blew a fuse or the control module that allows the blades to spin. Begin by checking the fuses. J.
May 28, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
PTO WHEN PULLED DOES NOT ENGAGE....BLADES DO NOT START...
Check your mower deck spindles and belt. If belt is slipping at all the PTO will not engage.
May 10, 2010 | Cub Cadet Lawn Mower Blade Drive Belt CUB...
My Cub Cadet i1042 tractor shuts off when the blade is engaged. This happened after I ran over a ***** and/or stump. Every time I try to engage the blade the engine shuts off.
Apr 24, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet lt 1018 blade will not engage when i pull knob up
Sep 28, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
329 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
