Question about Miller MAXSTAR 350 715959360197 UPS System
Miller Maxstar 350. Message HLP 20
Hi! I have a Miller 350 MAXSTAR that overnight stopped working! When I turn on nothing happens! I checked all parts of the electric panel, electrical voltage of 400 V is present. I opened it and I tested my electric voltage across the switch bouton. Everything works! So from time to time it comes on about 5 seconds and then turns off. He showed me an error message HELP 20 and according to the manual: Indicates that the power supply of the primary does not work. When it is turned on the first card said: Interconnect / Control Board there are two LED lights in one full and the other flashes from time to time ... Here I am a bit so I headed calls for your lights! thank you
4 Suggested Answers
SOURCE: I have a miller maxstar 140 str that does not work
i have a miller 210, when i pull triger it makes clicking noise and does not feed wire, then when i pull trigger again it works, does this sound like a gun problem or controller problem
Posted on Feb 20, 2010
SOURCE: Miller 130XP won't feed wire
need a replacement wire feed motor for a millermatic 130xp
Posted on Mar 21, 2010
  • 23 Answers
look for a reset button or fuse
Posted on Dec 17, 2010
Blinking ready light
Its telling you theres an error in your system possibly a wire jam
Oct 30, 2014 | Miller Maxstar 150 STL TIG/Stick Welder -...
Need owners manual for miller maxstar 140 tig/stick welder
Contact Miller Electric on their website. If you want a Technical Manual, Miller doesn't sell those to the public. They're only available to authorized repair facilities. If you're interested in purchasing one, contact me with the serial & model numbers. I may have it in PDF format.
ToBIGWillie@aol.com
Aug 25, 2014 | Welding Tools
Hel -10 on max star 200
The Help 10 code on a Miller Maxstar 200 indicates a depressed trigger. If it still doesn't clear, replace the trigger control.
Jul 29, 2014 | Miller Welding Tools
Plugged in Miller Dynasty 350 and it said REL RMT. Wouldn't let me change the settings, all I could do is turn it on and off. I checked the owners manual inside and out and couldn't find...
Hi:
Legend REL RMT means release remote, this happens when your torch's trigger is depressed and you need to release the trigger to continue.
Check the owner's manual on section 7-4 troubleshooting, it's there.
Sep 08, 2011 | Miller DYNASTY 350 TIG WELDER w/TIG TORCH...
I am throwing an error message HLP what is the problem
Hi:
After the HLP should be a number on it. What number is showing you?
Jul 30, 2011 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
I need a power cord to my LCD monitor, don't know the brand but it says Maxstar corporation on the back. There is also a model number A170E1-TT and the DC input is 19V 2.6 A.
Look at the power socket. It should be the same as the one on the back of the computer.
You should be able to find one in just about ant electrical, electronics or computer store.
Jan 31, 2011 | Westinghouse Electric LCM-17v2 17"...
I have a maxstar 150 tig welder that i take with me in our race car trailer, the trailer has a 6.5KW onan NHE generator in it, the welder fails to turn on with this generator, i checked volatge and freq...
Here is the spec sheet for your welder. The only problem that I can see is maybe your power cord is too small. As you can see on the spec chart, the minimum the machine will draw at 115 volts is close to 20 amps. Now your have to multiply that by 1.5 for transformer surge. So now you are looking at 30 amps, which means you will need size 10 gauge wires in your extension cord. If you are going to do some heavier welding, you may even need to go to a #8 cables. What happens also, when you try to draw a lot of current, the generator will bog down, thus providing less power. It would be better if you could use 230 volts. https://www.millerwelds.com/pdf/spec_sheets/DC27-1.pdf
Oct 23, 2017 | Miller Welding Tools
I have a miller maxstar 140 str that does not work I get no weld output. the ready light comes on initially then fades and blinks once.
Feb 03, 2010 | Miller Welding Tools
Miller MAXSTAR 350  715959360197  UPS System Logo
47 people viewed this question
Top Miller Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
ray gallant
GreenHotrod Hotrod
GreenHotrod Hotrod
Are you a Miller Computer and Internet Expert? Answer questions, earn points and help others
