Question about InFocus Office Equipment & Supplies
Words are showing backwards
Words and picture are showing backwards
    Novelist:
  • 85 Answers
Your projector has been set up for rear projection - you need to change it to front projection. Access the setup menu, then use the option to flip the image horizontally. Viewing the image in a mirror may make it easier for you while navigating through the menu options
Posted on Apr 09, 2014
How do I get my photo off "words"
Click on your name/picture, click you picture again on your account profile, click your picture to edit, choose existing or take photo. You will be prompted to Save changes.
Oct 20, 2014 | Apple iPhone 5
Words are spelt backwards
Your projector has been set up for rear projection mode (projecting the image from behind a translucent screen. You need to access the setup menus and reorientate it for front projection. Using a mirror to view the image whilst navigating through the menus may help :o)
Mar 27, 2014 | NEC VT465 Multimedia Projector
My picture is reversed.
The yoke of your tv has a reverse position try to put the connector in other yoke terminal
Oct 28, 2012 | Panasonic Televison & Video
My tv shows backwards
check deflecton yoke coil. wrong connection.
May 31, 2009 | Televison & Video
Zenith picture problems
Your TV is showing signs of age. It's displaying something called "vertical foldover" which is due to capacitors in the set's vertical output section that need to be replaced. These failed parts can stress the vertical output integrated circuit, and if that goes bad your picture will collapse to a thin horizontal line. The capacitors themselves (usually 3 or 4 need to be replaced) are pretty cheap. A TV shop in your area (if there are any still around!) could fix it and the repair should be under $100.
By moving those rings on the tube's neck (which is actually the back) you have messed up the set's convergence. Those rings are magnets which adjust the electron beams in the tube so the red, green and blue images line up correctly on the tube face. The rings are often marked with a stripe after adjustment to show how they were lined up. Look carefully at them and see if there are any marks you can go by to reset them. To properly converge the set some equipment is needed to generate the adjustment test pattern. Again, a shop could do it for you.
All things considered, at this point you might seriously consider replacing the set. Not because the troubles aren't fixable, but because other parts can start failing because of age, and by now your picture tube is on borrowed time as well.
Apr 13, 2009 | Zenith C27A24T 27" TV
Image is upside down and words backwards
malfunction in the camera and will need repair
olympusamerica.com/repair
Oct 17, 2008 | Olympus FE-210 Digital Camera
Samsung d900
Its the connector problem. You need to change that.
May 13, 2008 | Samsung SGH-D900 Cellular Phone
My Screen is upside down and the words are backwards
The first thing I would do is a reset. Read your manual about this process, which often requires pressing two buttons at the same time or take your batteries out, wait a minute and put them back. See if resetting helps. Not being familiar with your camera, speciffically, Ithis sounds like the firmware in the camera is reading the info back to you backwards when it processes the image (from memory) for you to view. That means it is the firmware in the camera that is defective and sometimes you can update or reinstall that. I would check the manufacturer's site for updates or recalls and if it is under warranty, send it back to be fixed.
Jan 28, 2007 | Fuji FinePix A120 Digital Camera
139 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
