Question about Smeg SE210X/1 Stainless Steel Electric Single Oven
Hi, ive just been given a smeg fan oven, but there are no instructions i dont know how to opperate the oven or anything else on it, the oven is stainles steal and has 4 control knobs, 2 on the left and 2 on the right, and a dial in the middle with wot looks like jugs in picture style on it and a plastic peg you can pull out, can any body help thanks ron
  • 1,266 Answers
Http://www.smegtech.com/site/smeg/myapp/libretti/index.php?lang=EN
Try this web site. If this is not your oven, reenter the correct model number in the box on the left and it should provide the correct manuals. It will also ask you to specify the language you want the manual in.
Hope this helps.
If you find the model number and have trouble with this site, let me know and I'll give you a hand.
Posted on Jun 16, 2009
Instruction manual for smeg fan assisted oven
Download the manual from the link below.
http://www.smegtech.com/site/smeg/pdf_libretti/914771429-GB.pdf
Hope this helps.Thanks!
Ken.
Jan 14, 2012 | Ovens
Hi My power box just tripped and my oven turned off, prior to this happening it was working fine. I have a smegg oven model se378mfx5. It now wont heat up, it turns on ok but wont allow me to set the...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Feb 16, 2011 | Smeg Ovens
Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Oct 09, 2009 | Smeg SE250XUK Stainless Steel Electric...
The light and fan works but no heat comes on in oven.
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on Facebook please How to Video Tutorials on Domestic Appliances
Jul 08, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Smeg oven
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
Dec 08, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Smeg double oven
possible the fan is just stuck. turn oven on and give the fan blade a flick with a small screwdriver and see if it runs
Sep 21, 2008 | Smeg SE250XUK Stainless Steel Electric...
Smeg oven
How long is the oven in operation before you check the air flow ? Most Smeg ovens are electronically integrated and sensitive.
Jan 24, 2008 | Ovens
Smeg SE210X/1 Stainless Steel Electric Single Oven Logo
1,016 people viewed this question
Top Smeg Ovens Experts
Hjalmer Lamminen
Hjalmer Lamminen
Jason Harris
Jason Harris
Are you a Smeg Oven Expert? Answer questions, earn points and help others
