Question about GE Profile JGSP44 Dual Fuel (Electric and Gas) Kitchen Range
Simmer is to hot
I have a jgsp44b ge 30" slide in gas supposedly has a 'precison' burner for specifically for simmer.  the burner is small, but it boils my gravies/sauces rapidly as opposed to simmer.  this is 2-3 cups of liquid in a pot.  i've tried different size pots to see if heat retention would be different, but to no avail...any ideas on reducing the btu's on this burner or other solutions?  thanks!
  • 3 more comments
  • cajunjimbo Nov 05, 2007
    i have been out of town for the past week, i will try your suggestion but first i need to find a screwdrivers small enough to reach thru the hole in the knob bracket to get to the set screw. thanks!
    i have been out of town for the past week, but i tried your suggestion tonight. unfortunately, i don't have a screwdriver small enough to fit thru the hole in the knob bracket, so i will have to get one. thanks!
  • cajunjimbo Nov 06, 2007
    got the right screwdriver and it worked! thanks mike!!
  • bazco Nov 07, 2007
    I have this stove JGSP44 it is hooked up for natural gas but I want to use Propane gas I have those 4 pieces to put in the center of each burner but does anyone have a suggestion before I do this.
  • Anonymous Mar 28, 2014
    can i adjust gas output
  • 290 Answers
I am hesitant about answering your question because if the flame is adjusted incorrectly it could be dangerous.
Remove the knob and look inside the stem of the gas valve. You will see a very small adjustment screw. This is where you adjust the flame for the burner.
What I usually do is light the burner and turn it to the lowest setting. Hold the stem in this position and turn the screw. They are usuall kind of stiff to turn.
You want to adjust the flame so that it just comes to the top of the burner cap at the low setting.
This is the important part!!!
When you have got the flame adjusted, put the knob on and turn the flame to high. Quickly turn it from high to low, if the flame goes out, adjust it higher. Repeat this test until you can turn it from high to low quickly and it stay lit.
Also important to remember. When turning the screw, a little turn goes a long way.
Post back if you have any questions.
Posted on Oct 31, 2007
  • Michael  Lindley
    Michael Lindley Nov 03, 2007
    Just wanted to follow up on your range and see if you got it adjusted.
Where do I find the orface and air intake on the GE Range
Sealed burner ranges the orifice is in the center of each burner, down inside(brass color). Open style burners the orifice should be under the lift off burner or in some case where the burner tube goes back to the control panel at the control knob. Almost all will be brass color. Oven orifices are at the end of the burner tube where the gas would come into the burner. Air adjustments are usually right near the orifices. A small sliding window with 1 screw holding the adjustment in place.
Mar 23, 2015 | GE 30" Self-Cleaning Freestanding Gas...
I need to know the btu input for a ge cooktop (gas) model gejgp975sekss
I see if I can find a diagram, ensure you posted right model number here.
Aug 29, 2008 | GE Kitchen Ranges
Igniter switch on top burner will not shut off
try thoroughly cleaning the burners, particularly the holes in the ring that the gas come through. The gas come through to heat the ignitor so that the ignitor knows to stop trying to light the burner ; if the holes are clogged the ignitor doesn't heat.
The burner is easily disassembled from the top by removing a thin bolt, and you can clear the holes with a paper clip.
Sep 21, 2013 | DCS RGS-305 Professional Gas Kitchen Range
My burners won`t click to light
What is the complete model number of the unit?
Dec 15, 2012 | GE Profile 30" Slide-In Gas Range -...
GE gas range on propane, using propane jets, the burner regulator knob has little effect on heat output. Is this a gas burner valve issue?
You also need to set the regulator to LP. The symptom described is an indication that the regulator is still set to natural gas. The manual should tell you how. As I remember, there is a cap on top of the regulator that is removed to allow access to a retainer that needs to be turned over so the "LP" is facing up. Check your manual or look it up online
Sep 18, 2012 | GE Profile JGSP44 Dual Fuel (Electric and...
GE stovetop with propane, too hot to simmer
I think you are right. Check for an optional valve for propane in your service manual or online on an appliance parts website. You can look up a schematic of all the basic parts.
Dec 03, 2009 | Car Audio & Video
I use one of the large burners most of the time and the minimum setting(simmer or ?) seems to have increased over last 4-5 years so that I have to turn burner off and let food cool, then turn on again,...
I am not sure of this Model but most of the Gas Rail Cocks ( Taps) when you remove the knob you will find either a small hole drilled into the spindle This would be the Low Burner (simmer Rate) Adjustment there would be a small screwdriver requiredto do this , if its not there ,then there is usually a small screw on the side of the tap under the Knob Hope this will help you
Jul 18, 2009 | GE 36 in. Profile JGP963 Stainless Steel...
Dcs 48" gas range igniter comes back when set on low/simmer
This is not a solution but something to think about for troubleshooting.
On the DCS there are two ports that feed gas to the burner.
One for high flame and one for simmer.
On the DCS if the flame is snuffed out on simmer it will automatically reignite.
So if the igniter will not shut off while on simmer, the sensor is bad and is trying to reignite the burner.
May 11, 2009 | DCS 24-24G-1 Gas Kitchen Range
Simmer is too hot
one way is the orfice that goes inside the burner.some have a little screwin the knob shaft to ajust.if no screw its the orficc.theres a tech sheet that will give you more detail about that on that stove.bottem drawer area or back.also so ranges have orfices on them in the back also.God bless,tom
Jan 01, 2009 | GE 36 in. Profile JGP962 Gas Cooktop
GE Profile JGSP44 Dual Fuel (Electric and Gas) Kitchen Range Logo
539 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
