Question about Little Tikes Cozy Coupe
Forgot to add the door
I forgot to put the door in place before I inserted the long screws and now I can't get the door in and i cant get teh screws out to disassemble.
How did you get the door attached... Same problem
Posted on Aug 05, 2016
I removed the freezer door and now I cannot reattach it.
Generally you just reverse the removal process. Place hole in door bottom over lower door hinge pin and place door in closed position. Insert top hinge in top hole---align hinge screw holes with holes in fridge cabinet and insert screws. Not sure what is giving you the problem. If you need more help post back brand and full model number so I can look it up.
Apr 21, 2015 | Refrigerators
Want to switch the side the door opens on my lg dryer
The directions for reversing the door can be found on page 13 and 14, with pictures of the operation. Open the door to reverse. Check the 10 screws that need to be removed (6 on the left, 4 on the right). Remove 4 dummy screws with a screwdriver. Remove the two screws from, and disassemble, the latch. Hold on to the hinge while removing 4 screws from the hinge (to prevent the door from dropping). Remove the door from the cabinet cover. Move the door to the left side and insert a hinge into a hinge hole. Hold on to the hinge while screwing down the hinge (to prevent the door from dropping). Insert the latch to the right side and install the screws. Screw down the 4 dummy screws to the right side. Check that the door closes and latches properly.
Feb 02, 2013 | LG SteamDryer 7.3 Cu. Ft....
How to remove drivers side door 1993 olds ciera
If you have any electrical controls in the door open the panel and disconnect them so you can remove teh door from the wiring harness. otherwise, open the door and support it on the outer edge away from teh hinges, use an impact driver with proper bit fitted to it, available at Auto Zone, Pep Boys, Advance Auto, or Sears (it uses a hammer to generate torque energy to break the torque in tight spots like an impact wrench) Remove the lower Hinge screws or bolts (These are usually a large Phillips head or a Half Inch bolt head), Then remove the upper retaining screws or bolts. To make it a little easy to handle if you are doing this by yourself, remove all of the screws or bolts from the lower hinge then put 1 back in a couple of turns just to hold the hinge. Repeat the process for the upper hinge. after doing this empty your hands, lift the door slightly and remove the 2 screws or bolts you put back in. after removing the door remove the hinges from the door side so you can use them in the new door.
Sep 19, 2011 | 1993 Oldsmobile Cutlass Ciera
2004 Ford Freestar SEL real hatch locked cant open. where or how do I find direction to fix
Kathy, You would need a small screw driver and a foot rule or a metal strip about an inch wide and a foot long. Collected? Now, with the screw driver you must remove the plastic moulding that is there on the outer side of the drivers door glass. Just put the screw driver head in the gap between the moulding and the door frame and push upwards. Do it at a number of places and the moulding will come out. After that you must insert the foot rule between the glass pane and the gap in the door over the place where the key hole is directly below it. Push the foot rule down so that you hear a click sound. If you hear it you will notice the door lock has opened. Cheers. Now replace the moulding by placing it where it was and pressing it downwards till the whole moulding is in its place.
Jun 30, 2011 | 2007 Ford Freestar Limited Minivan
How do I disassemble my dryer?
Difficulty: Moderately Easy
Things You'll Need:
* Putty Knife
* Screwdriver
Step1
Unplug the dryer and move it away from the wall. This will provide work space around the dryer.
Step2
Open the lint trap door and remove the two screws with a screwdriver. Pull out the lint screen.
Step3
Remove the console by unscrewing the four screws that connect it to the top. With the screws removed, disconnect the wiring harness and set the console aside.
Step4
Insert a putty knife between the top and front panel 2 inches from the corner. Press in to release the holding clip and pull up on the top panel to remove it from the clip.
Step5 With your hands, lift up on the corner to disengage the top from the remaining holding clips. Set the top aside.
Step6 There are two screws at the top of the front panel that secure it to the side panels. Remove the two screws with a screwdriver.
Step7. If equipped with a toe panel, insert a putty knife at the top center of the panel. Press in and release the retaining clip and pull the toe panel off by hand.
Step8. Place boards underneath the front of the drum. The boards will keep the drum in place when removing the front panel. Remove the front panel by swinging the top out and lifting it to remove from the bottom tabs.
Step9. The rear panel is removed by unscrewing the attaching screws from the side panels and bottom with a screwdriver. The dryer is now disassembled and all parts are accessible
Mar 07, 2011 | Dryers
Where does sim card go??
At teh top of teh phone you will see a small hole. Insert a pin into that hole and gently push it in. A sim bed will pop outin which you put in your sim and push it gently back into place.
Jan 22, 2011 | Apple iPhone 3G
The player will not work and I can't open the door?
Grab a screw driver , remove the case of the dvd player, remove teh DVD, then junk teh DVD player.
Aug 25, 2009 | Sanyo DWM400 DVD Player
Need to disassemble deadbolt with concealed screws
If it's like my deadbolt, pull the inside faceplate off. It's just pressed in place and the screws are behind it.
May 30, 2009 | Kwikset Powerbolt/Electronic Deadbolt-...
Conair hc318d reassembly
i have hc318d clipper it been use two time and havent use it in a year so was going to use it last nite and the small blade fell out. i try to put it back in and it want hold keep falling out
Dec 17, 2007 | Conair HC100RCS Hair Trimmer
Little Tikes Cozy Coupe Logo
192 people viewed this question
Top Little Tikes Toys Experts
 Russ Hill
Russ Hill
Brett Duxbury
Brett Duxbury
Bill Boyd
Are you a Little Tikes Toy Expert? Answer questions, earn points and help others
