Question about GE Adora DSS25KSTSS Stainless Steel Side by Side Refrigerator
My GE Adora Model dss25ksra refrigerator decided last night to stop working. It's a case of "the lights are on but nobody is home". The lights inside will come on when the doors open, but the compressor and fan are not operating. I pulled out fridge and vacuumed off the dust from the compressor (which I occassionally will do) but this didn't seem to help. I looked for a reset switch on the compressor thinking maybe it could have overheated, but I couldn't see a reset. Do I have a motherboard issue here? Thanks, David
  • GE Master
  • 4,654 Answers
Yes it does sound like a motherboard issue=> WR55X10942 Main Control Board It is also good to replace the=> WR07X10057 Start Relay and WR62X0079 Run Capacitor and examine the condenser and evaporator fan motors to insure they are working properly if the motherboard has been replaced. I am here should you need me, Thanks John Tripp Appliance 911
Posted on Mar 28, 2014
dididsaythat
  • 291 Answers
SOURCE: ge side by side not cooling enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting,
Posted on Sep 08, 2007
watugot
  • 290 Answers
SOURCE: freezer works but fridge remains warm.
The same fan that circulates air in the freezer also blows air in to the fridge. If you open the freezer door and hold the door switch closed you should hear the fan running. If not you have a failed motor or motor control. Look at the back wall of the freezer section and see if there is a heavy frost build up. If so. you have a defrost system problem. Please post back with what you find and with the complete model number and I will try to walk you through the steps of checking everything.
Thanks/Mike
Posted on Oct 27, 2007
SOURCE: ge side by side not cold enough in fridge or freezer
the fan behind the freezer panel inside
Posted on May 31, 2008
SOURCE: ge model gsh25jfrfww not cooling just clicking
Replace the main board on the back i got the part for $130 at a wholesale parts store
Posted on Mar 06, 2009
  • 14 Answers
SOURCE: Refrigerator and freezer running warm
Check and make sure fan in frezer section works properly.you should be able to hear fan slowing down when you open freezer, or find door switch and press and hold..hope it helps you..
Posted on Jul 07, 2009
My water dispenser quit working any ideas on how to fix or reset it
Mine just stopped also, apparently the water line on certain models is prone to freezing inside the door, (your model is included in the list). After time (in my case 8 years) water migrates into the foam insulation. You can thaw it out with a hair dyer but it will probably freeze again. Here's a link to a part you can get to fix it, haven't received mine yet so I don't know if it works (others say it does). Just call GE and demand that they sell it to you for $20. They will if you're persistatnt Redirect Notice
Feb 22, 2015 | GE Adora DSS25KSTSS Stainless Steel Side...
My GE Adora refrigerator - the freezer quit working. Where is the setting or the on - off switch. Or whatever I need to do. Need some help. Thanks
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 30, 2011 | GE Adora (DSF25KGTBG) Side by Side...
Our GE Adora Refrigerator's ice maker isn't working properly
Perhaps your freezer isn't set cold enough - or your freezer door seal is not sealing correctly and the ice cubes are melting in the bin and sticking to one another and the spiral screw that delivers the ice.
Mar 14, 2010 | GE Adora (DSF25KGTBG) Side by Side...
My fridge and freezer stopped working last night. I have model number FRT21HR6AB4. I can feel air coming out of the freezer and fridge, but its not cold air. any suggestions?
Is the light on inside? If yes, it could be thermostat, defrost timer or compressor start relay. All are worth fixing. Worst case would be compressor, but check those other items first.
Mar 03, 2010 | Refrigerators
I have a GE refrigerator side by side that is 2 years old. We noticed last night that food wasn't very cold, so we checked the temperature setting. The setting is at 9 the coldest, yet it doesn't seem to...
If the refrigerator is not cooling it could be for a couple reasons.
Either there is an excess of ice buildup between the freezer and the refrigerator or the compressor is bad. If its just and ice buildup all you need to do is remove the ice by either defrosting the refrigerator or using hot water poured down into the air vent inside the machine.
If its not the ice, its probably the compressor in which case you would have to get a professional to come and replace it which is rather costly. In most cases you are better off buying a new machine rather than replacing the compressor. Especially since it is not that old and is already having a major problem. If you decide to buy a new machine I recommend Whirlpool brand appliances.
Dec 12, 2009 | GE Refrigerators
Ice maker not making ice Adora GE
yes I have the light blinking, no ice jam, changed the water filter, so how do I get ice?
Mar 22, 2009 | GE Adora (DSF25KGTBG) Side by Side...
I have a G.E side by side refrigerator model #gss20iembww. The problem is it isn't cooling anything down, it just stopped, last night it was fine, today everything is warm. The light is on inside the unit,...
YOU MAY NEED A NEW FILTER. CHECK ON THE UPPER PART OF REFRIG. IF COOLING PROPERLY-IT SHOULD BE GREEN IF RED OR ORANGE YOU MAY NEED A NEW FILTER. WE BOUGHT OURS AT AN APPLIANCE STORE AND INSTALLED IT OURSELVES.
Sep 13, 2008 | GE Refrigerators
GE ADORA Refrgerator :
The water line from the house to the frig works, however the water in the frig just stop working one day. Any suggestions?
Feb 09, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Adora DSS25KSTSS Stainless Steel Side by Side Refrigerator Logo
124 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
