Question about LG WFT1071TP Top Load Washer
Cannot reset PE error
Have a PE code error, replaced the Pressure switch still showing the error and still not working
  • Masadatech
    Masadatech Nov 16, 2014
    I have a WFT-8501TP (LG). Had the error code PE as well. I used the method found on here, remove, blow. It worked but it also came back on after a few cycle. I called LG Canada (am in Vancouver BC). LG Canada said they didn't even know such a product (parts) code existed.
    Problem Solver:
  • 6 Answers
Model: WFT8501
Country: Canada
Error Code: PE
I am new to this forum. I followed the suggestion above and blew down the clear, plastic tube, and turned on machine, and walllla, it worked. My wife was amazed. Can\'t thank this forum enough and all the people who posted suggestions and helpful hints.
My machine was working just fine two days ago. Today, it showed PE code and it showed right at the get-go, no water, nothing worked, just PE and the beeping sound.
Hope this helps.
1. Unplugged the machine. Meaning not connected to the wall sockets.
2. I took two screws in the front off
3. I took two screws in the back off.
4. Forgot to unscrew the hose connecting to my sink. So I did that.
5. For my machine, model number above, the round unit is located on the far left side, left to me as I am standing and working from behind the machine.
6. The unit is round, perfectly round, and it is about 2 inches big, maybe 2.5 inches. It is connected to a plug, when unplugged, there are three wires.
7. The unit is sorta loose. This tells me there must be an easy way to remove it.
8. On top of the unit, there appears to be a screw, and it looks plastic-like. I initially wanted to use my screw driver on it, glad I didn\'t.
9. Look closely at the rounded part, it should have three tiny plastic (the whole thing is made of plastic and the ring around it, is also plastic), but upon closer inspection, you will find three little plastic groves, that is designed to hold the unit in place, I bent the plastic parts back, there are three but I only needed to do to two of the plastic prongs and that is all is required to pull the round unit (Pressure Sensor) right up and away.
10. Unit is connected by plastic, clear hose and maybe some other wires, so you can lift it up but not completely, as it is still tied down.
11. You will see a small metal clip, that holds the plastic tube to the Pressure Sensor, use small needle nose. Remove plastic hose, blow down it. Put it back.
12. I didn\'t even put the back cover back on. Just wanted to make sure it works first.
13. I did put the two screws in the front back though. After all the machine will be spinning and doing things at high speed.
14. As I write this, I can hear my beautiful LG humming in the background.
Again, with gratitude. Glad I found the answer and glad I joined this community. Will be posting more in the future.
Posted on Oct 25, 2014
  • 43 Answers
When you see the error code unplug the power cord wait a second than connect. You can also have a cut hose( it connects to switch and tub.
Posted on May 03, 2014
Lg wf-t1022tp gives a PE error code.
Try this first before replacing any parts or disassembling your LG washer:
- Unplug the washing machine for 1 minute.
- Plug the washing machine back into power.
- Restart the wash cycle.
- The washing machine may now have cleared the PE error code, if not see below...
You will need to check the wiring harness that connects the water level pressure sensor to the main control board.
- Check for a loose wire harness, a damaged wire harness, or a burnt faulty wire.
- Check that you get continuity through the wire harness by checking it with a multimeter.
- If the wire harness from the water level pressure sensor to the main control board is found to be faulty, replace it.
- If you get continuity and the wiring harness is securely connected to both the water level pressure sensor and the main control board, then proceed to the step below...
LG WASHER PE ERROR CODE - FIX METHOD #2
Water Level Pressure Sensor Switch Is Faulty And Needs To Be Cleaned Or Removed And Replaced.
Most commonly, if the wire harness is secure, tight, and not damaged, the part that needs to be checked is the water level pressure sensor.
- First check to be sure the water level pressure sensor is not caked with hard water or other debris.
- If the water level pressure sensor is not clean, the PE error can display.
- Remove the water level pressure sensor from your LG washer and clean off any hard water or debris.
- Clean out the tube that connects to the
- If you found the water level pressure sensor was caked with debris and you have cleaned it, replace it back into the washer and run a test.
- If the washer runs without the PE error code displaying, the washer is fixed and the PE error has been cleared.
- If you find that the water level pressure sensor is faulty, remove it and replace with a new OEM part.
lg-electronics-washing-machine-water-level-sensor-pressure-switch-hth0u4ums0hor52ud1sodlv4-2-1.jpg
Replacing the water level pressure sensor simply involves locating the sensor in your LG washer. Remove it from the washer and replace it with a new genuine LG washer part. Test washer to be sure the PE error code has cleared and the washer is now working properly
Mar 20, 2017 | LG Washing Machines
My lg fuzzy logic shows PE
The PE or pressure sensor error or fault code indicates that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
May 30, 2015 | LG Washing Machines
I have a LG 3step Turbodrum Fuzzy Logic WF-T8018TP when I put on the auto/off button it keeps on showing me the error PE how can a fix this
The PE error or fault code indicates that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
May 14, 2015 | LG Washing Machines
I get an error code PE on Samsung washer WA5451washer
PE error code is a pressure sensor code, and more than likely the sensor will need to be replaced. Try unplugging the unit for about 5 minutes and see if it will clear it out. If not, will need to replace pressure switch and hose (switch looks like a little UFO under the console, pretty easy job.
Nov 11, 2013 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
"PE errors lg washer wm2032hw" I replaced the
Check the condition of the tube as any small crack or hole will render the pressure switch useless.
If in doubt replace the tube.
Sep 03, 2013 | LG WM-2032H Front Load Washer
WhirlPool PE Error
PE error relates to the fill level of the washing machine. The fill level sensor is a pressure operated device. There is a sealed air line that goes from the bottom of the tub to an air pressure sensor. As the tub fills, it compresses the air in this air pressure sensor. When the tub is filled to the level selected on the dial, the sensor stops the fill cycle.
This air line can be plugged or the sensor itself can be faulty. This air pressure sensor is usually located near the top of the tub just under the top cover.
Nov 10, 2012 | Whirlpool Washing Machines
Whenever i given its shows error peep sound ,its indicate error worrd -PE
Hello, LG Washing Machine Error Code "PE" -Pressure sensor error code -Check wiring connection to the pressure sensor. -Replace pressure sensor The sensor repair is simple and straight forward. If this helps please rate me thanks..
Jun 08, 2011 | Washing Machines
I have a LG WD-1018C that won't work and has PE on the screen and I can't find the manual to fix it. Can you please tell me what PE means. Thanks
The error code "PE" stands for pressure sensor error. This is typically caused by a malfunctioning water pressure sensor switch.
Mar 09, 2011 | LG Washing Machines
How to reset eprom for PE error
Hi, PE error code means there is an pressure sensor error in your machine .You need to check pressure it will be giving incorrect indication . Pressure switch is faulty you need to change it . Procedure for changing is : 1.Power off the machine remove backcover and top cover. 2.The pressure switch is a round item about 3 inchesacross with several wires and a thin rubber pipe attached. 3.It generallysits just under the top cover.
Apr 08, 2010 | LG WFT1071TP Top Load Washer
Dish washer displays pf code
PF is probably PE like mine, sometimes the bottome row of the liquid display doesn't work properly
PE is a Pressure Error - condition - The water level in Tub goes down during operation
Possible Causes
¥ The Circuit of Pressure Switch
shorted or disconnected.
¥ Pressure Switch is troubled or
disconnected
¥ The Controller is troubled.
¥ The Air Tube is kinked or damaged.
Possible solutions
¥ Repair or replace the Circuit of
Pressure Switch.
¥ Replace the Pressure Switch.
¥ Repair or replace the Controller.
¥ Remove the cause of kink or replace
the Air Tube.
Jul 18, 2009 | LG Dishwashers
LG WFT1071TP Top Load Washer Logo
530 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
