Question about DeLonghi Magnifica XS Espresso Maker
The empty coffee grounds comes on too soon
Empty coffee grounds
Ground coffee is like mud
the coffee is too fine.Fix it from coffee beans section
Nov 05, 2013 | Saeco Incanto Sirius Fully Automatic...
Recalls on keurig
Empty the reservoir of any water. Fill it back up with white vinegar. Get a paper clip and poke it up in to the needle that the water comes out of on the top of the lid. Run the vinegar through the machine until the reservoir is empty. You can even let the vinegar sit in the coffee maker for 10-15 minutes. Refill reservoir with purified water and run the maker until all the water is dispensed and the reservoir is empty. There should be no more vinegar smell. Never use tap water. Do this every two months. Note: if the area where the K-Cup sits gets dirty with grounds, put a large bowl under it and then pour a glass of water over the whole area to clean. Also, on occasion just run a cup of water through the machine (with no coffee) just to make sure that there are no grounds caught in the needle. Done!
Feb 19, 2012 | Keurig B60 Coffee Maker
I need to clean my capresso c1000. i can't find the instructions. i put a cleaning tablet into the ground coffee area, and ran the ground coffee button a few times. is that it?
No, first push the self clean button (hold until lights come on). Then pull the grounds unit and empty it, that will turn off one red light. Fill the water tank. Then drop the tablet. Then hit the ground coffee button. Cycle through and dump the grounds each time the grounds light illuminates.
Jul 09, 2011 | Jura Capresso C1000 Espresso & Coffee...
I have a new to me Starbucks Italia. I have made a few shots and it is telling me to "empty grounds". I have done so but the empty grounds mssg won't go off and it won't function. what do I need to do?
Hi
When you want to empty the grounds because it says to in the menu, REMEMBER TO LEAVE THE MACHINE ON when you remove the drawer. The machine is a counter and when it reaches the magic number for that machine the message comes on. If the machine is turned off when you pull the drawer out, the machine doesn't know this and the message will be there when you turn the machine back on. Also remember to leave the drawer out for at least 15 seconds or a little longer so the machine thinks you actually dumped the grounds.
Oct 04, 2010 | Starbucks Saeco Italia Digital Barista...
Repeats "empty coffee grinds drawer". drawer is empty.
Check the area behind the draw there might be some ground coffee preventing the tray from sitting correctly.
Jul 05, 2009 | Saeco Royal Professional Espresso Machine
I can't get the coffee grounds plastic dispenser back into the
remove the used grounds container and place a folded piece of paper where the grounds container touches the micro switch ( that is in a slot in the left side where the container enters approx 8cm inside) and then restart the machine and the grounds container will now be able to enter, remember to remove the folded paper before inserting the container
Nov 18, 2008 | Saeco Vienna Deluxe
Saeco Italia sensor problem
It does that after about 8 rounds of brewing, and it doesn't matter if you empty the grounds after every brew or not. It's automatic.
Sep 16, 2007 | Starbucks Saeco Italia Digital Barista...
DeLonghi Magnifica XS Espresso Maker Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
