Question about Sharp AR-235 Copier
Creasing paper on exit but fuser "looks" ok - Sharp AR-235 Copier
  • 313 Answers
Check the paper tray paer guides to make ure the paper is sitting square in the tray if the guides are out of place adjust so that the paper cant shift from side to side as this will cause the paper to feed through the machine at a small skew and when it hits the fuser the pressure pulls it through at an angle and this causes the creases..good luck A
Posted on Jun 15, 2009
Crease in paper when printing
Your information is a bit limited but we'll try anyway.
If the crease is a corner fold or a pressure line down the page, it will often be caused by something in the paper feed path close to the main drive bar in an inkjet or near the fuser in a laser printer. Have a look at the leading edge of the paper as it exits the printer for a nick or mark that may give a clue where to start looking. If there is a fold or crumple line down the length of the page, look at the paper pick up mechanism in an inkjet (usually the paper tray is a good start) or if it is a laser printer you should remove the fuser and check the fuser sleeve and pressure rollers. If you could let me know what the machine is and where the crease is I may be able to give better advice.
Jul 09, 2015 | Office Equipment & Supplies
Why does paper keep creasing up
can I get a little more info what do you mean creases is it jamming or just coming out crinkled if it makes it through the machine check the guides and the paper type the tray is programmed for if it stops around the fuser and folds like an accordion replace the fuser
Aug 05, 2014 | Kyocera Office Equipment & Supplies
Crease in page when printing cannon image runner 1310
A crease is usually caused by two issues. 1 ) paper is hitting something on the way to the fuser causing a skew. This type of problem would be repeatable every page as well as causing the image to be off centre. The 2) reason is the more likely cause. A bearing on the lower (pressure roller) is beginning to seize. Causing paper not to feed straight through the fuser. This cause a wrinkle from from to back on the sheet of paper. This wrinkle although repeatable generally the wrinkle position up or down on the sheet. This gives the impression of something that is getting in the way of the sheet. If you can change your lower pressure bearings you should be ok again.
May 03, 2013 | Cannon Office Equipment & Supplies
Hp laser jet P2035N has a crease down the center of the page as the paper exits it is actually slightly raised so the print is smearing
Check to make certain that the fuser unit is not damaged. Often a crease or dimple is caused by foreign material on the fuser roller or the fuser is damaged. If the fuser is damaged, look into replacing the device, it may be cheaper than repairing the fuser.
Jan 31, 2013 | HEWLETT PACKARD - LASER JETS New - Hp...
On my oki 5150 the printed paper develops a crease usally in the middle of the page. Usually about 4 inches long, with a small overlap that ends up in a crease ... it's starting to get sufficiently bad so...
If the paper under the crease has print and the fold is "glued down", it is most likely to be a problem with the fuser. Try removing it and look for evidence of warping in the pressure roller. If the fuser looks clean and tidy, go to the other end at check over the paper tray and paper feed mechanisim. It is possible the paper is catching on something at the start of the process. This is most likely if there is print over the crease but not under the fold.
Jan 01, 2018 | OKI C5150n Led Printer
Canon GP 225, When using the photocopier function on this machine the copies are coming out with a crease on them, almost even a fold in the paper, the machine is not jamming however and the paper comes...
This crease is most likely caused by the paper buckling just before it enters the fusing unit. The fuser is the part that gets hot just before the paper exits the machine. I would check the "ramp" that guides the paper into the fuser. They sometimes get toner build up that the paper catches on. If the paper does not go straight and flat into the fuser you will get a very tight crease or z-fold in the paper due to the heat and pressure applied to the paper to fix or "fuse" the toner onto the paper.
Dec 23, 2009 | Office Equipment & Supplies
Hp laserjet 1010 paper tearing
If the paper is tearing and creasing at exit the problem is a worn fuser fixing film. This will need to be replaced.
Oct 17, 2009 | HP LaserJet 1010 Printer
Wrinkled paper
Many possibilities can cause this....
The Pick Up Rollers could be worn out and not picking the paper up correctly.
Something blocking, or catching in the paper path
The Fuser unit rollers could be sticking, going bad..
The Exit Delivery could be warped, cracked.
After these machines get old, the heat from Fuser unit causes the delivery Exit to melt, warp, and become extremely brittle.
The simple things you can check your self:
Entirely remove the paper tray, look in the copier where the paper tray slides in, look in side the machine where the paper tray goes, make certain there is nothing in the trays path.
Take the paper out of the paper tray, go through the paper make certain there is no crumbled paper in the tray, it should lay flat and even in the tray...
My favorite, check the paper it self.
I once was at a customer whom recently changed their paper supplier; every 10th piece of paper was creased from the new **** of paper. I found that the entire Box of paper had creases in every ****. It was the paper not the machine. It was pre-wrinkled.
Feb 06, 2009 | Sharp AR-207 Copier
PAPER CREASES AS IT EXITS THE PRINTER
No you will have to get a techie out - the plastic gears is not aligned - seems to be due to wear and tear. (this shoud be re-fastened or replaced. (not an expensive exercise)
Apr 19, 2008 | Xerox DocuColor 12 Printer
Printed paper is creased
First thing to check is try it with a fresh unopened ream of quality paper, paper with too much moisture content, drys out and goes wavy when it runs threw the fuser roller at rear (180 deg), otherwise it will be the fuser rollers themselves causing your problem, which means that you need to replace fuser assy
Dec 05, 2007 | Samsung CLP 300 Laser Printer
Sharp AR-235 Copier Logo
188 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
