Both our brand new copy machines SHARP M316 have problem with the
Both our brand new copy machines SHARP M316 have the same problem with the Reversing Single Pass Feeder AR-RP7.
Paper moved into the feeder, the original seemed to be misaligned when reaching the position for scanning. On its further way it is blocked somehow, so that the original paper is crushed by the feeders transport system.
  • 313 Answers
First thsing to check is the side guides for the paper make sure they are set against the paper being fed through if not the paper will be pulled through at an angle and this can cause your problem you can alson get a slightly heavier paper and put that through to see if you have a jam..did you remove all the packing tags and paper protectors
Posted on Jun 15, 2009
My sharp ar m316 reads"call for services code h4 -20
Mean you ahve a issue with the fuser unit the part that get hot,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 08, 2016 | Sharp Office Equipment & Supplies
How can I download open driver for sharp ar-m316 printer in windows 8?
GO TO SHARP & DOWNLOAD THE WINDOWS 8 8.1 PROGRAM FOR THAT PRINTER
http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx
I’m happy to help further over the phone at https://www.6ya.com/expert/wynn_5ba0205233ebfc15
Dec 14, 2014 | Sharp Office Equipment & Supplies
Unconsistant scanning function error can't connect
first change usb cable.(blue one) remove software then re install.
May 25, 2010 | Sharp AR-M205 Copier
After changing toner on my sharp, SF-2022 copy machine, the copies are coming out with black smudge marks across the paper? how/where should i clean?
This means the machine is over-toning ie using more toner than required caused by either improper toner or different brand of toner. The correct toner is sf 222T1. Replace developer and use the right toner and clean the drum and its blade. You may need to clean fuser rollers for cleaner copies.
Nov 13, 2009 | Sharp Office Equipment & Supplies
Sharp AL 1551 CS RSPF not feeding
This can be a fault of the controller of the direct current. Apply to service This fault can be not eliminated by you.
Mar 23, 2009 | Sharp AL-1551CS Copier
New cartridge; now won't print any document, fax or copy
It is not impossible to get a brand new bad ink cartridge. I've seen lots of bad ones.
Oct 04, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
52 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
