Question about Vehicle Parts & Accessories
Reset anti theft device
(unlock#anti-theft code)
    Problem Solver:
  • 5 Answers
Hi there.
I dont know specifically what your problem is, but if your alarm keeps going off but you cant turn it off, if you have a key hole on your car, close your door and turn the key both ways.
Posted on Mar 28, 2014
3 Suggested Answers
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
  • 434 Answers
SOURCE: I need code to reset my anti theft code on my
The only luck I have had is to do a search on the internet and pay a few dollars to get it. Sorry, I know that's not much help.
Posted on Jun 25, 2009
  • 50 Answers
SOURCE: Can I reset my anti theft device by using one key
Yeah, put the first key in and let the anti-theft light go completly out (about ten secs), take that key out and do the same with the second key. Take it out and start it with the first key. Maybe this will trick the system , hope this helps.
Posted on Jul 05, 2009
How do I reset the anti theft device on a 1998 ford Taurus?
You don't reset anti-theft systems ! Your ford has the PATS - passive anti-theft system ! Is the red light on top of the instrument panel flashing when trying to start the vehicle ? Need to see what DTC'S - diagnostic trouble codes are stored , fix the problem !
Sep 05, 2016 | 1998 Ford Taurus
How to stop anti theft device activation
Unlock car, disconnect battery and leave fo 10 mins. Reconnect battery and see how you get on
Dec 20, 2015 | 1994 Toyota Corolla
How to reset anti-theft on a 2000 alero
The security, antitheft or lock picture/icon is a visual indication that something in the car's antitheft system is failing. In most GM cars and trucks there is a hidden system that most people are unaware even exists. From the moment you put your key in the ignition, there begins a constant line of communication between your key's security chip or transponder, to the ignition's lock cylinder, and then to the car's TDM (Theft Deterrent Module). These 3 parts are in CONSTANT communication. If the key is in the ignition, then these parts are sending signals to each other. The security light illuminates when that signal gets broken, even just for a second. When the signal breaks, the car misinterprets this as an attempt at theft and goes into antitheft mode. The car thinks its being stolen or hotwired because it is not getting that signal from YOUR specific key. This is why the security light turns on and shuts down your vehicle. This link explains it pretty well.
http://www.diy-gm-security.com/
Apr 04, 2015 | 2000 Oldsmobile Alero
How do I reset the truck to start after the anti theft lock has been activated?
Insert correct key in to Drivers door and turn clock wise then turn counter clock wise unlocking and resetting security system. This usually dose the trick HUCK.
May 06, 2017 | Chevrolet Cars & Trucks
Is there a way to reset the anti theft device on a 2007 Ford Edge
Cars equipped with keyless entry are common now. They contain a remote key chain that triggers the door to unlock. Inorder to reset the anti Theft device on the 2007 Impala a scan tool is needed. It does sometimes reset after 10 min.
Renault CAN Clip Diagnostic Interface V123
Dec 12, 2012 | 2007 Ford Edge SEL Plus
I DO NOT REMEMBER MY PIN HOW DO I RESET IT
If you forget the PIN or password unlock code to unlock the Garmin unit, the best solution is to bring it to Garmin to get unlocked. It is a anti-theft feature, you can't clear it.
Apr 23, 2012 | Garmin Nuvi 660 GPS Receiver
Please help me to get the code number to unlock the radio for honda crv 2003
    • 1 Look in your owner's manual booklet for your radio anti-theft code. The code is printed on a small card (similar to a credit card) and included with your owner's manual. If you can find the code, skip to Step 5.
      If you cannot find the code, you'll need to retrieve it.
    • 2 Turn your ignition off to begin retrieving your radio code. Press and hold the "1" and "6" preset buttons on your radio. Turn your ignition on.
    • 3 Write down the code displayed on your radio. The display will flash with two numbers: one beginning with a "U" and one beginning with a "L." Write down both numbers (beginning with the "U" number), and then disregard the "U" and the "L."
      This number (eight digits) is your radio serial code. You'll need it to retrieve your radio anti-theft code.
    • 4 Contact Honda to retrieve your radio anti-theft code. You'll need your 17-digit Vehicle Identification Number, found beneath the driver's side of the windshield and your radio serial code. Honda's customer service number is (800) 999-1009. Provide the representative with the information to acquire your radio anti-theft code.
      You can also retrieve your radio anti-theft code online for free at https://radio-navicode.honda.com/
    • 5 Turn your ignition to "Acc" or "On" to power on your radio. Enter your radio anti-theft code using the preset buttons at the bottom of your radio. For example, if your anti-theft code is "55512," you would press the "5" button three times, then the "1" button, then the "2" button. This will unlock and reset your Honda radio.
Oct 09, 2011 | 2003 Honda CR-V
265 garmin pin probem
What pin problem are you having?
If this is the Garmin
Lock (anti-theft feature) security feature.
Going back to the security location will unlock the unit but in order to reset the pin code, the original pin code must be input.
To unlock the unit, it must be sent back to Garmin.
May 01, 2011 | Garmin Nuvi 265W GPS Receiver
The battery died on my 2001 eclipse, now the radio only says ''off''?
This is the anti-theft device on your factory radio. When the battery died, the radio thought it had been removed from your car and went into anti-theft mode. When you turned the car back on, the radio should have read "CODE" on the display, at which point you need to enter the factory anti-theft code. After 3 failed attempts at entering the code, it will simply read "OFF" and the radio is locked.
At this point:
- find your factory anti-theft code - it should be in your owner's manual, or you can contact a dealer to retrieve it
- turn the key to the ACC position (radio and accessories on, but engine is off)
- turn on the radio so the display reads "OFF"
- let the car sit for 1 hour
- radio will turn off automatically and reset
- turn the radio on again, and it should read "CODE"
- enter the factory anti-theft code
Make sure you have the code before starting the procedure. To enter the code, use the radio preset buttons. For example, if your code is "4321", hit Preset #1 button four times, Preset #2 three times, Preset #3 two times, and Preset #4 one time. Then hit the "Tape" or "CD" button. Radio should now be unlocked.
Sep 13, 2009 | 2001 Mitsubishi Eclipse
Vehicle Parts & Accessories Logo
83 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
