Question about AMD 2.3GHz Phenom X4 Quad-Core 9650 AM2+ 3600MHz HT 2MB L2 HD9650WCJ4BGH
Hai i have Asus M3A78em Mother and AMD Phenom x4 Quadcore proccer. ram is 2GM i want 64bit support mother board driver what i do i need install windows Xp 64 bit Os please help me
Windows 64 bit os is not working probaly it ask driver support for 64 bit
    New Friend:
  • 36 Answers
Simply acquire a copy of Windows XP 64bit and install. You should then update all drivers needed with 64 bit drivers.
Posted on Apr 04, 2014
MORRISS
  • 40 Answers
SOURCE: I installed a AMD Phenom(tm)
There seems to be some sort of incompatibility issue between your motherboard and the Phenom, or maybe some option is not enabled in the motherboard bios that windows is only sensing half of the GHz, like if the processor is only running 2 cores instead of 4.
About the memory diference, that same problem is because the 64bit difference. Unless you have a 64bit XP you won't see the full 4GB. Windows XP is limited to 3 or 3.5GB of ram it can use, you are showing 2.75 maybe because some video board is integrated in your motherboard and it may be borrowing an extra 0.25GB from the 3GB that are usable under windows XP 32bit OS.
Please comment what motherboard you have, since the cpu alone can't be blamed nor configured.
Posted on Jan 03, 2009
  • 13433 Answers
SOURCE: Driver
Thats a prosessor, theres just one driver for that, and still its not a must have.
now if its a motherboard that you need drivers for, now just the processor, go over here and select the right motherboard, you will get the drivers you need.
http://support.asus.com/download/download.aspx
and you can get a prosessor driver from here for AMD
http://support.amd.com/us/Pages/drivers.aspx
Let me know how that goes.
Thanks,
Ekse
Posted on Jun 03, 2009
  • 81 Answers
SOURCE: my system is based on amd athlon 64 bit 3200
You will need to find the model of your motherboard. It is usually printed on the board itself. Or you can try to use programs to find the information you need. The you can search for the drivers in the manufacturer's support site.
Posted on Apr 03, 2010
Testimonial: "thnk u"
  • 245 Answers
SOURCE: looking for update drivers for
It was designed for today's systems so the Win7x64 would be the best choice.Problem being,64 bit apps are still lagging in catching up as far as volume. Cost will be the same with either version of 7,they're on the same disk if you buy the full retail version.
You could go cheaper by using XP,the rumors are already out about "Windows 8",it won't be named that.
You need to decide on your OS before you download your drivers.XP and 64 bit Win7 will not be the same.
Post back and let me know what you want to go with and I'll find it for you.
Please rate my post?
Thanks
Bob
Posted on Aug 15, 2010
Testimonial: "Than you for your help"
dracconus
  • 64 Answers
SOURCE: plz. help getting blue screen error.
There are a few things that can cause this. 1. One of your RAM modules (rectangle with cmall black rectangles on it) located on the motherbarod is bad. 2. You have WAY too many USB devices atached to your system, and there aren't enough IRQ's to go around.
TRY THIS: 1. Remove all the RAM modules, and try booting with them one at a time. if none of them work Then (HOPEFULLY) it's not your ram. (if it Isn't the second one, it could mean the RAM slots on your motherboard are bad, and misreading, or all your RAM is shot.) 2. Remove one USB device at a time, starting with anything plugged into an external USB Hub. And, as a future tip, never boot with any USB hubs, or external storage devices present, as they're known to cause issues with the boot process due to it's method of reading, and writing files to a drive.
What I mean by that, is that sometimes, if a removable drive's inserted upon boot, or while installing an operating system, it could have the boot files written to it, then when you take it out, you no longer boot, because you don't have the files to, so as a precaution, never have external drives or flash media inserted at boot. Dracconus
Posted on Jan 08, 2011
Can you tell me if AMD Phenom X4 9550 95W works with motherboard ASUS M2V-MX? Or if just that motherboard support quadcore CPU?
go to Asus web site and get the pecs for the board. it should tell you what processors will work with the board.
Feb 27, 2015 | AMD Phenom X4 9550, 2.2 GHz...
Upgraded cpu and fan om HP p6320y desktop won't stay powered up
The AMD Phenom II X4 850 (HDX850WFK42GM) uses up to 95 Watts of power,
http://www.cpu-world.com/CPUs/K10/AMD-Phenom%20II%20X4%20850.html
(Electrical/Thermal parameters)
While the AMD Phenom II X4 965 uses up to 125 Watts, or 140 Watts; depending on which Part Number....
HDZ965FBK4DGI uses up to 140 Watts.
HDZ965FBK4DGM uses up to 125 Watts.
http://en.wikipedia.org/wiki/List_of_AMD_Phenom_microprocessors#.22Deneb.22_.28C2.2FC3.2C_45_nm.2C_Quad-core.29
Scroll down a little.
I'm going with Not enough power from the Power Supply.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01969880&tmp_task=prodinfoCategory&cc=us&dlc=en&lc=en&product=4120661
Power Supply is ONLY 300 Watts?
Yes, the Power Supply is too small IMHO.
Is there also a graphics card you have installed, and not stated?
Regards,
joecoolvette
May 14, 2013 | Computers & Internet
CPU upgrade for ACER rs780hvf
you could upgrade to AMD PHENOM II X4 960T but you should probably try and overclock and save your money.
Apr 03, 2012 | Computers & Internet
Can processor AMD Phenom X4 9650 Quadcore to use motherboard Asus M4A78T-E ?
you cannot use m4a78t-e to amd phenom x4 9650 because it does not support am2+ socket, it only support am3,phenom II,sempron 100, and athlon II processor.
Aug 18, 2011 | AMD 2.3GHz Phenom X4 Quad-Core 9650 AM2+...
My Mother boards asus M4A78LT-MLE but when computer start fast screen appear " this cpu is not supports please call asus costumer care" and pres F1 enter bottom to star contnue, processor fan...
Click here to view the list of supported processors for the ASUS M4A78LTM LE Mainboard.
The AMD AM3 Phenom 2 X4 965 3.4GHz is not supported as it is a 125Watt or 140Watt Processor.
The ASUS M4A78LTM LE Mainboard supports up and including a 95Watt Processor.
Therefore you either need to downgrade, purchase a Processor that is supported as shown in the list or purchase a Mainboard that supports your AMD AM3 Phenom 2 X4 965 3.4GHz Processor.
I myself would go for an ASUS M4A88TD-V EVO/USB3 Mainboard, its a good companion for that monster of a Processor you have got.
See if you are able to return the Mainboard and purchase the ASUS M4A88TD-V EVO/USB3
Click here for it's Specs.
There is also the cheaper ASUS M4A785TD-V EVO
Tell me how it goes!
All the Best!
damnor01
Dec 14, 2010 | ASUS M4A78LTM LE Motherboard
Hardware upgrade required for autocad 2009
Your existing CPU will not work with that motherboard. The AM2+/AM2 processor slot is for AMD processors only. For this motherboard, you will need one of the following processors: Phenom FX / Phenom / Athlon 64 FX / Athlon 64 X2
Jul 06, 2009 | Dell Dimension 8250 PC Desktop
AMD Phenom II x4 920 processor works with a GA-MA790X-UD4P
Yes, that Gigabyte motherboard does support the Phenom II X4, for additional CPUs it supports check out the following website on the specifications tab:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128387&Tpk=GA-MA790X-UD4P
Mar 12, 2009 | Gigabyte Computers & Internet
AMD 2.3GHz  Phenom X4 Quad-Core 9650 AM2+ 3600MHz HT 2MB L2 HD9650WCJ4BGH Logo
89 people viewed this question
Top AMD Computers & Internet Experts
David
David
rafnix
rafnix
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
