Question about Asrock P43DE3 LGA 775 Intel P43 ATX Intel Motherboard
Not work usb & ps2
Burn smd resistor notred number R
  • Asrock Master
  • 3,320 Answers
Buy a new motherboard.
Posted on Mar 28, 2014
What is the value of resistor 601
600 ohms
A resistor with a number code instead of a letter code is a SMD:
Surface Mount Device. You might have searched for SMD resistor code and got some hits.
The system for SMD resistors is:
1st value-2nd value-multiplier
6 - 0 - 1 following zero
= 600 or 600 ohms
603 would be 60,000 Ohms or 60k
6 - 0 - 3 following zeros
Mar 21, 2016 | Televison & Video
Tip
How to Calculate SMD Resistor Code
SMD resistor codes isdifferent from the normal resistor color code (color bands) you had seen in theelectronic circuit boards. Surface mount resistors is very much smaller in than the normal carbon film resistor and because of this the numbers andletters were stamped upon or printed on the top side of the component. Thosenumbers and letters have a meaning and you could use that as information tofind out or calculate the desire resistance values. Sometimes the resistors aredesigned in a very small until we have difficulty to read the code. Byusing a magnifier glass we could easily read the resistor codes. clip_image002.jpg clip_image003.jpgThere are two types ofsurface mount resistors used in an electronic circuit board-the 3-digit and4-digit code SMD. The first two digits represent the two digits in the answer.The third digit represents the number of zero's you must place after the twodigits. Theanswer will be in Ohms. For example: 104 which mean 10 0000 (4 zero's)and the final answer is 100k. Let's calculate the 4 digit SMD, 1182 which mean118 00 (2 zero's) and the final answer is 11.8k.
on Oct 07, 2010 | Televison & Video
Need repair kit for bn44-00307a
  • Transistors QX801 and QX802
  • SMD resistors RX802, RX803, RX832, RX833 (all with the same value)
  • SMD resistors RX804 and RX805 (same value)
  • SMD diodes DX803 and DX804 (same kind)
can buy parts online or on e-bay.
Sep 18, 2013 | Televison & Video
Supermicro SuperServer 5013G-M - PS2 error
Hello here is the homepage:
http://www.supermicro.com/products/system/1u/5013/sys-5013g-m.cfm
Is your Mouse a USB mouse or is it a HYBRID Mouse? Look at the bottom of mouse and see what is written. It should give you the: (1-) Name (2-) Model Number & it will either say: "USB Mouse" or "USB 2.0 and PS2 Compatible". If it is USB 2.0 and PS2 Compatible, then it is a HYBRID MOUSE - You should have a - USB to PS2 - Adapter that came with the mouse.
Use that adapter and plug into the PS2 Mouse port - (only if it is a HYBRID). It will automatically configure itself as a PS2 mouse. Now you will have both your Input devices set as PS2.
(2) - If it is a USB mouse, can you obtain a PS2 mouse to temporarily use? If you can; try using the PS2 Mouse Port?
Now you may have to set BIOS on - with regard to:
(1) - Legacy USB Support -(Either Support or Disable)
(2) - USB settings to what Motherboard supports
Try also to upgrade the drivers/bios, if nessesary.
SET LEGACY USB SUPPORT TO "DISABLED" FOR BOTH MOUSE & KEYBOARD IN BIOS.
Good luck
Nov 24, 2011 | SuperMicro Computers & Internet
I have a Technics Stereo Integrated Amplifier SU-G75 That does not allow the Tuner, CD Player, Tape Deck work. I connected the components to a working Stereo and all work. The Stereo/Amp power up and the...
You can try replacing the resistors. They are available using part number: ERDS1FJ100 from tritronicsinc.com for $1.10 each. Typically though, the reason for the silence is a defective output amp-pac. This too can be purchased from tritronicsinc.com using part number: RSN3305-P for $65.73. This is the amp for the front speakers. The rear and center speaker5s use part number: SVI3205B which is listed as no longer available.
Hope this helps,
Dan
Nov 26, 2009 | Audio Players & Recorders
Drive powers up but will no longer be recognized by my computer. Drive activity light does not flash.
Sound the interface cable going to the drive. Replace the cable, they are usually resoanable price.
Oct 17, 2009 | Maxtor Personal Storage 3100 (M01E100) 100...
HP ppp009 laptop power supply
The best way is to get one off ebay by part number. Take it apart and write them down. Then order the resistors and you will have 2. Then you can either sell the other one back or keep it. You cant lose if you have electronics skills.
Dec 31, 2007 | HP Compaq NC6400 Business Notebook
Slimline PS2 disc not spinning
my friend i have a ps2 that its cd does not rotate ( i open it completely ) and the lens is working the lens is producing a red ray and it is movinng up and down but just the cd motor doesnot rotate so i checked the smd fuses using my fluke dgital multimeter i found one that is open when i replace it the ps2 work perfectly fine for your information the smd fuses are marked ps1 ps2 ps3 ps4 etc
Apr 30, 2007 | Sony PlayStation 2 (PS2) Console
Asrock P43DE3 LGA 775 Intel P43 ATX Intel Motherboard Logo
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
