Question about Samsung Microwave Ovens
Run microwave empty
We heard something is popping inside and we smell something is burning can we still use it
    Master:
  • 397 Answers
I would never recommend using a microwave that emits a burning smell.
Posted on Mar 27, 2014
WHEN I USED MICROWAVE HAD BURNING SMELL & BLACK SOOT APPEARED. STILL HAVE POWER BUT DOESN'T COOK
Just had the same problem. It was an electrical short and the repairman said that it could have burned the kitchen wall and been a catastrophy. Get rid of it immediately!
Mar 02, 2013 | Microwave Ovens
Micro GE Spacemaker XL1400 Sunday I was warming up soup for three minutes when ready open door and I heard a click, micro shut down I tested the power outlet with the blender and It work An hour later the...
IF YOU SMELLED BURNING TAHTS BAD, IT SOUNDS LIKE YOUR MAG TUBE WENT OUT (ITS WHAT MAKES THE MICROWAVES) iT WILL BE CHEAPER TO REPLACE IT, NEW UNIT STARTING FROM $115 FOR THE SAME MODEL
Jun 07, 2010 | GE Microwave Ovens
Heard a pop and then an electrical smell. Unit is working but a faint electrical smell occurs each time unit used. Should I continue using it? It is built in with a trim kit.
No that is a very dangerous situation. What is sounds like is you had a short that blew apart but not completely damaging the wires. You should unplug, and open it if its out of warranty and inspect the wires. If the wires are partially burned it can heat up and cause an electrical fire.
May 19, 2010 | Panasonic NN-S541 Microwave Oven
I just ran my GE microwave for 7 minutes while empty. Heard a pop sound and now it won't run. Is is ruined?
The worst thing you can do for any microwave is run it empty as you have found out the hard way. What has happened is RF from the magnetron has reflected back into your magnetron. Some models even have an RF filter window that has the same color as the insode of your unit but a fiber appearance. Running the unit empty causes the RF to burn through this RF filter and stright back into the magnetron itself. Some units have a thermal protection thermostat on the magnetron that turn off the power to the magnetron when it gets too hot. Since you heard a pop you could have a bad load capacitor that has failed or the chassis diode itself has failed. You can take the unit in for service but if they tell you that the magnetron needs replaced I would think hard about having it repaired as the cost can be as much as 50% of a new unit. the Cap and Diode replacements are much more resonable repairs. Good Luck.
Jan 10, 2010 | GE Spacemaker JVM1540 Microwave Oven
Sparks pops odd burned smell
I would certainly take it to a repair shop if you want to try and salvage it. Until then keep it off and unplugged.
Feb 14, 2009 | Frigidaire PLMV168 Microwave Oven
Is the microwave possibly dangerous after it popped & now smells
Hello jeffnlaur,
The sound you heard could be any number of things but I would attempt to verify the basic preformance of the microwave was ok by placing a cup of water in the cooking compartment and switching the micro on for about 2 minutes.. The water should be close to or at a boil after this time ( depending on glass type and power output of oven). Listen for any other irregular sounds while it is running. You may have heard something in the soup pop or some of the electronics within the micro arc but it may not mean it is dangerous. Try the water test first and if it continues to exibit internal noises and burning a burning smell, I would discrad the oven. Table top models are very inexpensive and the cost to diagnose and repair would probably exceed the cost to replace,
In terms of dangerous, there are safety devices to cut off power to the magnetron and other components if warranted. Not sure that helps you but with limited info from your side, diagnostics are 'iffy' at best..
Regards
Rick
Jan 09, 2009 | Panasonic Microwave Ovens
Service to Whirlppol MH7130xez-1, circuit breaker popped then unit went dead
water may have leaked inside unit causing a short.the transformer output is about 1400 volts that feeds a large capacitor. a direct short can blow the transformer instantly or any support parts without time to burn something. creating little or no smell. I never sujest that a person
to try to repair a microwave oven because
the capacitor can still be charged and very lethal.
Feb 25, 2008 | Whirlpool MH7135XE Microwave Oven
Emerson Model MW8627W does not heat after changing fuse!
check the magnitron and capacitors one of this is bad
Sep 18, 2007 | Emerson MW8627W Microwave Oven
Microwave Ovens Logo
63 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
