Question about Funai Televison & Video
My Funai dvd recorder wont record on dvd-rw
Brand new discs
SOURCE: dvd recorder won't record on DVD-RW disc.
CLEANING THE DISC LENS ? If this unit still does not perform properly although you refer to the relevant sections and to ?TROUBLESHOOTING GUIDE? in this Owner?s Manual, the laser optical pickup unit may be dirty. Consult your dealer or an Authorized Service Center for inspection and cleaning of the laser optical pickup unit. FROM EWR20V5 OWNERS MANUAL FUNAI-CORP.COM
Posted on Jul 01, 2007
SOURCE: Sylvania DVR90VE DVD Recorder / VCR - formatting DVD-RW
This unit only supports 2X -RW discs or 4X -R discs.
Posted on Oct 28, 2007
SOURCE: DVD Recorder tells me it cannot record on disc
You can't use 16x or anything that says 1x-16x or 1x-4x.
The 4X speed DVD-R are difficult to find. (Tried Office Depot,OfficeMax, Staples, Microcenter,Best Buy and Walgreens!) Finally found Princo brand at
They worked great!
Posted on Aug 09, 2009
SOURCE: Funai VCR/DVD recorder DVR 2737. My -R discs
I was advised to try another make of blank discs. I bought Sony discs & they worked ok. I had been using supermarket own brand.
Posted on Oct 18, 2009
SOURCE: my recorder wont record on new discs
Daewoo DVD Recorder/VCR combi (I believe the model number is DF-4100P it wont record on disc but it will on tape mode plus the drawer in the dvd wont open please can someone send me an answer of whats wrong with it thank you
Posted on Jun 08, 2010
Record tv to dvd on Funai recorder
The Funai ZV427FX4 doesn't have a tuner. You'll need a set-top box (either a digital tuner or a cable box) that has a composite A/V out. Make sure to use a compatible DVD-R or DVD-RW disc (see page 27 of the manual given below). For basic recording, insert a DVD and press DVD to make sure that the recorder is ready to record to disc instead of video tape. (You may need to format the disc for DVD-RW.) Press Rec Mode until the correct mode is chosen. Then press Input to select composite input 1 or 2 (L1/L2). Set this source to the desired channel. Then press Rec. (For scheduled recording, make sure that the unit is set to DVD. Then press Timer. Follow the on-screen cues to set the time to start and end the recording. Otherwise the steps are the same. Then press Timer Set.) See the manual for screen-shots of the procedure.
The manual for this model is available on the product page: . Click on the Downloads tab. The direct link is currently . For older Funai units with an NTSC tuner, you will probably still need the set-top box. However, you can either connect the box to the composite video or RF input. (If you want to record a program from a low-power analog station, you would skip the set-top box.)
I hope this helps.
Aug 28, 2016 | Funai ZV427FX4 DVD Recorder/VCR Combo
Help quetion
Which brand of DVD-R disc did you use? What error did you get? What is your video source? Most TVs don't give video output. The tuner on the WV20V6 is an NTSC (analog) tuner. Thus you need to use a set-top box (OTA digital-to-analog converter, cable or satellite box) with the recording "channel" set to video input 1 for most channels or analog cable input to the recorder.
Verbatim DVD-R 8x, Maxell DVD-R 8X/16X and JVC DVD-R 2X have been tested and proven to work by the manufacturer. A number of DVD+R and DVD+RW or DVD-RW have been tested as well.
I've found that you have to test each batch of DVDs. Different manufacturing plants can lead to bad discs from a previously good brand.
The manual for the WV20V6 is available from Funai Corp (who manufacture the recorder for SV2000). The direct link is . See page 25 of the PDF for tested optical discs. No CD-Rs will work.
I hope this helps. Please add a comment with more information about your situation for additional support.
Jun 22, 2013 | Funai WV20V6 SV2000 DVD Recorder and VCR...
Disc say cant record,what disc do i buy
This model (PY90DG) DVD recorder supports the following disc recording formats: DVD+RW/DVD-RW/DVD+R/DVD-R for everyday video. These should record fine. The RW discs are for repeated recording/erasure while the R discs are once-only recording types - the R discs must be finalised in this deck to make them playable on other DVD players. DVD-RAM discs are NOT supported by this unit. This recorder will play MP3 files on a CD-R or CD-RW (not DVD-ROM) just fine as well, but will not record them.
Best discs to buy for this type of recorder are DVD-R (recommended brand - Verbatim or TDK if you can get them, but not Memorex). These are OK.
Feb 22, 2011 | Funai PY90DG DVD Recorder
Can't delete recorded programmes from a DVD-RW disc. Also, the wording on the t.v. screen is not the same as shown in the Owners Manual when I use the remote controller.
U can't deleting the recording matrials in the DVD+RW disc.U only can recorded over it with new recording matrials over the old materials.What do u mean?Diffreence lanuages from the tv screen not in english or ur own country lanauge?
Oct 27, 2010 | Funai TruTech DVDVCR Dual Recorder
I transferred some pictures from my computer on a Maxell RW disc. When I played the disc on my Funai DVD/VHS Dual recorder model DRV-2737 no picture appeared on TV screen. What could be the problem? On the... seem like your dvd/vhs player is outdated...(do the rw disc plays in pc?) are you using Nero software? this will curve the problem...or try another DVD RW brand that funai is compatible with...dvd players, dvd recorder and pc dvd burners do roll back...all must be a year or less apart to work with each other....
May 26, 2010 | Funai PY90VG DVD Player/VCR
FUNAI SV2000 WV10D6 DVD recorder Recording errors on new DVD +RW discs
You can try cleaning the dvd lens with a commercialy available cd/dvd cleaner.
Aug 27, 2008 | Computers & Internet
Dvd recorder funai
I have fixed mine with the same problem , all it needed was the lens cleaned , i used a laser lens cleaning disc from maplin for 6.99 and voila good as new.
May 09, 2008 | Funai PY90DG DVD Recorder
No Disc
I have the same model ... you can't use DVD-R or DVD-RW discs, only DVD+R or DVD+RW
Apr 26, 2008 | Cyberhome DVD Recorder - DVR1600
Py90vg recording error
look for what format the dvd records on [ dvd-r, dvd-rw, dvd+r, dvd+rw. the manual showed tell you
Feb 04, 2008 | Funai PY90VG DVD Player/VCR
Televison & Video Logo
Top Funai Televison & Video Experts
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
