Question about Maclaren Baby Gear
Replacement wheels with 8mm axle
Model number and name "DEXPOSE" 2252 1595 BLUE, inspected May 1999
  • Maclaren Master
  • 1,629 Answers
Hi Mike
We'd recommend you make contact with Maclaren for assistance.
Sites maclaren US Site
Posted on Apr 06, 2014
The front wheel of my mclaren is a bit bent how do I fix it
Hi Sumaya
We would recommend you contact Maclaren for assistance.
Feb 04, 2014 | Maclaren Baby Gear
1999 plymouth breeze. step on brakes and the front brakes have a bad pulsing to them. previous owner hab brakes done rotars turned and pads replaced. any suggestions on how to address this problem
Symptom: Brake Pedal Pulsates Change When: Braking Change Where: Passenger Compartment Change -->lg-bl.jpg lg-br.jpg
Priority Action Part Type Cause 1 Inspect Brake Drum Specs Brake Drum Out of Adjustment, Out of Round, or Cracked. 2 Inspect Brake Drum Unevenly Worn or Out of Round Brake Drum(s). 3 Inspect Brake Rotor Incorrectly Machined Brake Rotor. 4 Inspect Wheel Bearing-Front Incorrectly Tightened or Installed Wheel Bearing. 5 Inspect Wheel Bearing-Rear Incorrectly Tightened or Installed Wheel Bearing. 6 Inspect Wheel Nut Loose, Worn, or Damaged Wheel Nut(s). 7 Inspect Rear Axle Bent Rear Axle.
Apr 13, 2013 | Plymouth Breeze Cars & Trucks
Axlerear
remove the rear wheels and brakedrums or calipers and rotors depending on the model remove the rear diff cover there is a large round pin in the center of the carrierer rotate the carier untill u see a 8mm bolt on the pass side through the pin remove the bolt slide the pin out push the axles in and remove the u shaped clips and slide the axles out
Jun 03, 2012 | 2000 GMC Jimmy
How do I rgerplabe how do I replace a front wheel bearing?
TO REMOVE FRONT WHEEL BEARING.YOU NEED TO SAFELY RAISE SUPPORT VECHICLE ON JACK STANDS.MAKE SURE SITTING ON LEVEL SOLID GROUND.BEFORE RAISING VECHICLE OFF GROUND YOU NEED TO LOOSEN HALF SHAFT AXLE NUT JUST A LITTLE BECAUSE WHEEL IN THE AIR HARD TO LOOSEN AXLE NUT WHEN YOU HAVE HOLD THE WHEEL WHILE LOOSEN THE AXLE NUT WHICH IS TORQUE ON ABOUT 200 FT LBS.USING A SIX POINT AXLE SOCKET SOCKET SIZE COULD BE 34 OR 35 METRIC 1/2 INCH SOCKET.YOU NEED 1/2 INCH BREAKER BAR.ONCE YOU LOOSEN AXLE NUT A LITTLE THEN RAISE VECHICLE THEN REMOVE WHEEL.THEN FINISHING REMOVING AXLE NUT AND WASHER.THEN REMOVE THE CALIPER FROM THE STEERING KNUCKLE AND SUPPORT IT ASIDE USING A PIECE OF WIRE.REMOVE BRAKE ROTOR.THEN REMOVE THE 3 HUB BEARING ASSEMBLY BOLTS. USE A SWIVEL SOCKET GOING TO BE HARD TO REACH SPOT WITH A REGULAR SOCKET. REMOVE THE HALF SHAFT FROM THE HUB BEARING ASSEMBLY.REMOVE HUB AND BEARING ASSEMBLY. PUT EVERY THING BACK VISA VERSA. TORQUE HUB BEARING BOLTS TO 70 FT LBS. TORQUE AXLE NUT 284 FT LBS IF YOUR CAR IS 1998 MODEL AND TORQUE AXLE NUT 100 FT LBS FOR THE 1999 TO 2001 MODELS.THE WHEEL HAS TO BE ON THE GROUND JUST ENOUGH TO KEEP IT FROM TURNING.DONT LET ALL THE CAR WEIGHT DOWN UNTIL YOU HAVE TORQUE WHEEL TO THE RIGHT TORQUE.LET ME KNOW IF YOU HAVE ANY PROBLEMS.
Mar 21, 2011 | 1999 Oldsmobile Alero
How do I remove the rear axle
The rear axle shaft?? Or the entire axle? I'm going to go with the axle shaft. Secure the vehicle. Loosen the lug nuts. Jack it up. Take the wheel and tire off. Remove the caliper and/or bracket. Remove the rotor. Place a pan under the rear differential cover. Remove the rear differential cover. Spin the axle shaft to reveal the center pin. Locate the 8mm-5/16 bolt that holds the center pin in place. Remove that bolt. Slide the center pin out, BUT DON'T TURN THE AXLE SHAFTS WHILE ITS OUT! Push the axle shaft in from the outer portion (where the wheel goes). A "C" clip will fall out inside of the differential. Pull the axle shaft out. Slide the center pin back in. Replace the 8mm-5/16 locking bolt and spin it a few times to keep everything in place.
Feb 23, 2011 | 2000 GMC Jimmy
How do you remove the front wheel axle to remove the front wheel?
I had this exact bike. I loved it btw.
1. You'll have to remove the two hex key bolts on the calipers so you can pull the wheel off (I believe 8mm)
2. There are tow large nuts that just unthread from the axle tube itself.
3.Once nuts are off just tap the tube out. Wheel should be free to pull out.
4. Careful not to damage the speed sensor that see's the little pickups on the left hand rotor. This is for your speedo and is an expensive replacement part.
May 27, 2010 | 2007 Husqvarna SM 510 R
1999 jeep quadra drive all wheel drive, front wheels not pulling
the sensor in the front axle may be cracked or damaged. follow the wires to it make shure there are no gouges in them or the they are not cut. there is a portion in the axle that will unscrew(where the wires hook up) remove it and inspect it,
Dec 07, 2009 | 1999 Jeep Grand Cherokee
Remove and replace rear wheel bearing on 1997 f150
REMOVE DIFF COVER ON 3rd MEMBER THERE WILL BE A SMALL 8mm BOLT REMOVE BOLT SLID PIN OUT PUSH AXLE IN AND REMOVE HORSE CLIP DO SAME FOR OTHER SIDE PUSH AXLE IN REMOVE CLIP. YOU'LL NEED A BEARING PULLER TO REMOVE BEARING INSTALL NEW BEARINGS WITH NEW SEAL, INSTALL BOTH AXLE WITH HORSE CLIPS INSTALL PIN AND 8mm BOLT, COVER AND REFILL.
Nov 04, 2009 | 1997 Ford F150 Regular Cab
Getting rear gears out of the difential case 1999 dodge durango
  1. Raise and support vehicle. Ensure that the transmission is in neutral.
  2. Remove wheel and tire assembly.
  3. Remove brake drum. Refer toBrakes, for proper procedure.
  4. Clean all foreign material from housing cover area.
  5. Loosen housing cover bolts. Drain lubricant from the housing and axle shaft tubes. Remove housing cover.
  6. Rotate differential case so that pinion mate gear shaft lock screw is accessible. Remove lock screw and pinion mate gear shaft from differential case
  7. Push axle shaft inward and remove axle shaft C - clip lock from the axle shaft
  8. Remove axle shaft. Use care to prevent damage to axle shaft bearing and seal, which will remain in axle shaft tube.
  9. Inspect axle shaft seal for leakage or damage.
  10. Inspect roller bearing contact surface on axle shaft for signs of brinelling, galling and pitting. If any of these conditions exist, the axle shaft and/or bearing and seal must be replaced
Feb 07, 2009 | 1999 Dodge Durango
Rear Axle Removal
if you are talking about the axle seals, 1.REMOVE THE WHEELS.2. REMOVE THE DIFF COVER(slowly)3.REMOVE THE BRAKE CALIPER ASSEMBLY.4.REMOVE THE 8MM PIN IN THE DIFF CARRIER. 5.TURN CARRIER AND REMOVE THE LARGE PIN.6. FIRMLY HIT IN THE AXLE, A SMALL RETAINING C CLIP WILL FALL INTO THE DIFF HOUSING. DO THE SAME WITH THE OTHER SIDE. ( be careful if you have rear speed sensors remove it when you remove the brake calipers . you will break it when you are pushing in the axles.)7.pull axles and replace seals
May 29, 2008 | 1999 Chevrolet Blazer
Baby Gear Logo
103 people viewed this question
Top Maclaren Baby Gear Experts
Jennifer Rock
Jennifer Rock
xxxxxx xxx
Jim Goldsmith
Jim Goldsmith
Are you a Maclaren Baby Gear Expert? Answer questions, earn points and help others
