Question about Troy Drywall and Panel Hoist with Extension DPH1116
Replacement parts i need rubber cap tend 716 269 4523
Gas cap rubber came off and cap won't stay closed
sounds like the gas cap is worn out and just needs to be replaced. you may be able to buy a universal at your local auto parts store.
Nov 15, 2013 | 2002 Jaguar S-Type
My check fuel cap light is on but i see nothing wrong with it. I made sure it was on tight. it is a 2005 ford taurus
As with all rubber gromets, O-rongs, and gaskets they tend to "shrink". This effect leaves room for fuel vapor to escape, which will result in an evap failure. Replacing the fuel cap tends to be the best solution.
Aug 08, 2011 | 2005 Ford Taurus
There is a pvc/rubber hose that goes from the oil filler cap and down that is broken. what is it for?? volvo v70 2,5 t 2005.
Hello and welcome to FixYa!
You may be referring to the brake master cylinder. If the hose is worn out it tends to leak. You will need to have it replaced.
Hope this helps and thank you for using FixYa! Have a good one!
Apr 25, 2011 | 2005 Volvo V70
I am trying to find a replacement part: The rubber cover that protects the housing for the front wheels of the Aspire "Quickie" power chair.
The front rubber cover and bracket for the Aspire front wheel is part #561670 and the list price is $160. It is available from Sunrise Medical at 800-456-8165. I replace these quite often because they wear out. The components underneath tend to be sharp and can cut your foot and ankle. I am afraid that this part is available only from the manufacturer.
It is possible to use a rubber inner tube or large rubber hose to cut and shape a replacement part if you are inclined to save a little money. I don't know how well this would work in practical use. Hope this helps.
Dec 27, 2010 | Health & Beauty
Where can i buy parts for mag light 3d size flashlight , the parts that i need is a switch and rubber cap .... thanks
Hi and welcome to FixYa, I am Kelly. Please see this link for the parts you need:
http://www.maglite.com/anatomy_spare_D.asp
Rubber cap is item 7 The barrell with switch is item 6. (mouse over the item numbers and the part number is on the right. If you order the barrell with switch you probably do not need the rubber cap.
The phone number contact page is here:
http://www.maglite.com/spareparts.asp
They may be able to tell you a retailer that sells spares close to you. For sure they can get you the parts you need.
Thanks for choosing FixYa,
Kelly
Dec 11, 2010 | MagLite Mag-Lite& Flashlight
Water leak from cooling system, carn't see a water leak and have tried a bottle of rad weld, but its still loosing around a litre of water to every 50 miles. Any suggestions for self repair and where to...
If there isn't water obviously appearing from somewhere it's either a head gasket failure or radiator cap. Check the oil filler cap for emulsion. Just hope that it's the radiator cap.
Oct 20, 2009 | 1996 Volvo 960
Th gas cap light stays on all the time
check the rubber o ring around the gas cap they tend to crack and deteriorate
Jun 29, 2009 | 2007 Dodge Ram Truck
Fg 110 mini tiller by honda
I have had the same problem.
The first time the solution was to replace the rubber membrane underneath the primer bulb. Take off the bulb, then remove the plastic part underneath the bulb. There is a rubber membrane underneath that. The ethanol in the gasoline tends to deteriorate the membrane. The honda dealers sell them for about 14 dollars.
The second time the problem was caused by the gas cap, not properly venting. In this case the engine would start and run, but when I gave it full throttle, it would quit.
It got so bad that it wouldn't even run. I noticed when I loosened the gas cap it ran great.
So I took off the cap, removed the inner parts, and got a diaper in and pushed it though the holes in the plastic part underneath the cap, and through the rubber plug in the center. I did this a few times and check with my mouth to see if I could pull some air through the cap. When it breathed satisfactorily, I put the cap back on the gas tank and it ran great. Now it runs better than new.
Jan 13, 2009 | Honda 25cc 4-cycle Mini Tiller
2002 Hnda Accord Coupe
that;s all, no other problems except to clean any mess caused by the oil spiting out.
May 25, 2008 | 2002 Honda Accord
Troy Drywall and Panel Hoist with Extension DPH1116 Logo
178 people viewed this question
Top Troy Drywall Experts
Tim Hunt
Tim Hunt
ray gallant
Jim Parker
Jim Parker
Are you a Troy Drywall Expert? Answer questions, earn points and help others
