Question about Toys
TORQUE SETTINGS ON C9 CATERPILLAR
I NEED TORQUE SETTINGS FOR HEAD BOLTS AND ROCKERS ON A C9 CATERPILLAR ENGINE.
SOURCE: Engine Bolt Torques- 2005 Chevy Impala/3400 Engine
Head Bolts
Step one 37 ft lbs then tignten 120 degrees more
Rocker arms
Step one 11 ft lbs then tighten 90 degresss more
Upper intake
89 inch lbs
Lower intake
132 inch lbs
Posted on Dec 02, 2008
  • 254 Answers
SOURCE: Need torque wrench settings for cylinder head bolts
try here http://www.manualz.info/
hope this helps
Posted on Jan 04, 2009
SOURCE: Angle Torque settings head bolts
Use new bolts, tighten in the following stages 1. 20Nm 2. 100Nm 3. wait 3 mins 4. slacken bolts 1&2 retighten to 20Nm +110 degrees 5. carry out stage 4 for bolts 3,4,5 & 6 then bolts 7,8,9 &10 Sequence, 8 4 1 5 9 7 3 2 6 10 Bolts 9 & 10 are flywheel side of the engine.
Posted on Mar 17, 2009
chuck943
  • 783 Answers
SOURCE: Head bolt torque specs needed for 96 tbird 3.8
Head bolts are torque to yeild so you MUST use new bolts.
Tighten cylinder head retaining bolts in numerical sequence in three steps as follows:
  1. 20 Nm (15 lb-ft).
  1. 40 Nm (30 lb-ft).
  1. 50 Nm (37 lb-ft)
Loosen retaining bolts one at a time two to three revolutions and retighten as follows:
Long bolts:
  • Tighten to 40-50 Nm (30-37 lb-ft).
  • Rotate an additional 175-185 degrees.
  • Go to next bolt in sequence.
Short Bolts:
  • Tighten to 20-30 Nm (15-22 lb-ft).
Here is a pic of the sequence
http://i253.photobucket.com/albums/hh43/chuck943/Headboltsequence38L.gif
Posted on Mar 19, 2009
  • 7353 Answers
SOURCE: head bolts torque settings for dogde neon 2002
assuming this is the "C" engine 8th digit on VIN plate. Use new bolts. torque first step to 25lbs, 2nd 50lbs, then 3rd 50lbs, then 1/4 turn.
Posted on Sep 23, 2009
Torque specs 2003 olds silhouette rocker arm 3.400
Here is a suggested updated torque spec for this engine's rocker arm bolts;
Rocker arms
Step one: Torque to 11 ft lbs then tighten an additional 90 degrees of bolt head rotation. Some guys don't fuss with the torque specs and just get them good and tight. Either way, be careful, as the heads are aluminum. You do not want to over tighten these bolts
Oct 07, 2016 | 2003 Oldsmobile Silhouette
Flywheel torque spec's for 1983 Ford F-100
Could it be a F-150 instead?
Ford Engine Bolt Torque Chart Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type Torque Spec Main cap bolts 60-70 ft-lbs Outer main cap bolts 35-40 ft-lbs. Connecting rod bolts (40-45 ft-lbs. for 289 HP & Boss 302) Cylinder head bolts 65-72 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs Oil pump bolt 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolts 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351W Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 90-100 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs. Oil pump bolts 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351C, 351M Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C) Cylinder head bolts 105 ft-lbs. (125 ft-lbs. For Boss 351C) Rocker arms (non-adjustable) Rocker arms (non-adjustable) 5/16in. intake manifold bolts 21-25 ft-lbs. 3/8in. intake manifold bolts 28-23 ft-lbs Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 9-12 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs. 360, 390, 406, 427, 428FE Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Crossbolts for 406-427 40 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427) Cylinder head bolts 80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427) Rocker arm shaft bolts 40-45 ft-lbs. Intake manifold bolts 32-35 ft-lbs. Oil pump bolt 12-15 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 429-460 Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 140 ft-lbs. Rocker arms (non-adjustable) 18-22 ft-lbs. Intake manifold bolts 25-30 ft-lbs. Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs.
Dec 18, 2015 | Ford Cars & Trucks
Torque spec's for the fly wheel
Dec 18, 2015 | Cars & Trucks
Rocker arm pivot torque for olds cutlass 1987 307
Oldsmobile Torque Specs - GbodyOlds.com
www.gbodyolds.com/forum/showthread.php?754-Oldsmobile-Torque...
Feb 7, 2013 - 2 posts - ‎2 authors Oldsmobile Small-Block Engines Cylinder Head Bolts (1/2in. bolt) 130 ft. lbs. Cylinder Head ... Rocker Arm Pivot Bolt 25 ft. lbs. Rod Bearing ...
Rocker Arms - AutoZone
www.autozone.com/...Cutlass...1987.../Rocker-Arms/_/P-0900...
AutoZoneGM Cutlass RWD 1970-1987 Repair Guide ... To remove the rocker arms from the shaft, the nylon arm retainers must be removed. ... 7: Engine valve system, 260, 307, 350, 403 Oldsmobile built engines ... Unfasten the two bolts that attach the rocker arm pivot to the cylinder head. ... Torque the retaining bolts to 25 ft. lbs.
Dec 01, 2015 | 1987 Oldsmobile Cutlass Salon
Torque settings for mitsubishi 4D34 engine bolts
get the service and repair manual from the given and get the solution easily http://toolsnyou.com/
Nov 03, 2012 | Mitsubishi Cars & Trucks
What are the torque measurements for the rocker arms and intake manafold?
2.2L Engine & 2.4L Engines
These engines are not equipped with rocker arms. The camshafts directly actuate the valves.
3.1L Engine & 3.4L Engines
When install or connect the check the following:
- Pushrods and the rocker arms. Torque the bolts to 24 ft. lbs. (32 Nm). - Rocker arm cover using a new gasket. Torque the rocker cover bolts to 89 inch lbs. (10 Nm).
- Heater bypass pipe. Torque the screw at the water pump to 106 inch lbs. (12 Nm), the bolt at the cylinder head corner to 18 ft. lbs. (25 Nm) and the nut to 18 ft. lbs. (25 Nm).
About the INTAKE MANIFOLD...
Intake manifold nuts and bolts and tighten to 89 inch lbs. (10 Nm)
- Pushrods and rocker arms. Torque the bolts to 89 inch lbs. (10 Nm) plus an additional 30 degree turn. - Lower intake manifold. Apply sealant to the threads of the bolts and torque the bolts to 115 inch lbs. (13 Nm).
Exploded view of the upper and lower intake-3.1L & 3.4L engines
Fig. Lower intake manifold tightening sequence-3.1L & 3.4L engines
Hope help.
May 04, 2010 | 2000 Pontiac Grand Am GT
I need the engine torque specs for 99 chevy malibu. like the head bolt torque sequence and rocker bolt torque sequence
99 chevy malibu v6 3.1 engine, head bolt torque is-- 98 through 2001 is step1- 37 foot lbs, step 2- rotate an additional 90 degrees (1/4 turn). the rocker arm bolts are 168-in. lbs.
Mar 12, 2010 | 1999 Chevrolet Malibu
Blown head gaskit need to remove head and replace with new ong
2.2L (VIN 4) Engine
  1. Before servicing the vehicle, refer to the precautions section.
  2. Relieve the fuel system pressure.
  3. Drain the cooling system.
  4. Remove or disconnect the following:
    • Accessory drive belt
    • Air cleaner outlet duct
    • Engine mount
    • Intake manifold
    • Exhaust manifold
    • Engine Coolant Temperature (ECT) sensor electrical connector
    • Power steering pump
    • Radiator inlet pipe
    • Spark plug wires
    • Rocker arm cover
    NOTE Whenever valve train components are removed, keep them in order for installation purposes.
    • Rocker arms and pushrods
    • Lifters
    • Alternator rear brace and the alternator
    • Ignition coil assembly
    • Accessory bracket
    • Spark plug wires
    • Cylinder head bolts
    WARNING Two sizes of bolts are used; note the location of each.
    • Cylinder head
  5. Inspect the cylinder head and block surface for cracks, nicks, heavy scratches and flatness.
Cylinder head torquing sequence—2.2L (VIN 4) engine
  1. Install or connect the following:
    • Cylinder head with a new gasket and new cylinder head bolts. Torque the long bolts, in sequence to 46 ft. lbs. (63 Nm) and the short bolts to 43 ft. lbs. (58 Nm) plus an additional 90 degree turn on all the bolts.
    • Lifters
    • Pushrods and rocker arms. Torque nuts to 22 ft. lbs. (30 Nm).
    • Rocker arm cover. Torque the bolts to 89 inch lbs. (10 Nm).
    • Spark plug wires
    • Accessory bracket
    • Power steering pump. Torque the bolts to 22 ft. lbs. (30 Nm).
    • ECT sensor electrical connector
    • Exhaust manifold. Torque the nuts to 118 inch lbs. (13 Nm).
    • Alternator. Torque the bolts to 37 ft. lbs. (50 Nm).
    • Intake manifold. Torque the bolts to 17 ft. lbs. (24 Nm).
    • Engine mount. Torque the bolts to 55 ft. lbs. (75 Nm).
    • Negative battery cable
  2. Refill and bleed the cooling system.
  3. Start the vehicle and inspect for leaks.
Oct 08, 2009 | 2000 Chevrolet Cavalier
Tightening head
New Headbolts are recommended
Long bolts are torqued to 46'lbs + 90 degrees.
Short bolts are torqued 43'lbs + 90 degrees.
Start in the center, and work to the edges, torquing the bolts in two stages.
Rockers are torqued to 22'lbs.
Dec 21, 2008 | 1999 Chevrolet Cavalier
Toys Logo
347 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
