Question about Toshiba 37X3030D 37 in. LCD TV/HD Combo
Toshiba no picture
Screen fails to light sound OK
    Top Expert:
  • Toshiba Master
  • 74,232 Answers
Check and replace damaged component/s at its back-light inverter stage circuit, or replace the back-light inverter board. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 27, 2014
Testimonial: "I was in the trade until 1999 but have had no experience of LED displays. Like you I have gone for the back-light board. there 2 flashes from a component on this board when switching from standby to on. I am looking at this TV as a favour for a friend so I don't want to go down the road of trying to source components. Friend said that display did come back on for one day so I was hopeful that this was a dry joint but maybe thats a thing of the past! Thanks for your help"
Toshiba 37X3030D TV. Screen fails to light, sound OK.
That'll be the inverter board. It might be the 6632L-0490A made by LG Philips. If it is, you'll find the 2 capacitors have leaked and a bit has blown out of the chip. The inverter board is hidden behind the main board on the 505 model.
Mar 27, 2014 | Toshiba 37X3030D 37 in. LCD TV/HD Combo
Sound but no picture
This could be a problem in the vertical sweep circuit, as when the vertical circuit fails, The video or screen will blank out so the picture tubes do not get damaged. In this chassis, I have seen the convergence IC's cause this, or the capacitor in the sweep power supply that feeds the voltage to the vertical IC has failed and blew out the vertical output IC. If you have no solid state repair experience, play it safe and call in a trained tech to assist you in this repair. Good Luck.
Aug 11, 2007 | Toshiba 43AX60 43" Rear Projection...
32L1300U
In what way is the screen broken? cracked, distorted picture, no picture but has sound?
If it is cracked. Replacement of screen is expensive. Cheaper to buy a new TV.
If Distorted. Parts linked to the screen can be the culprit. Most common part to fail is the T-con board. Main board may not be sending signal to the T-con board.
If its no picture but has sound. Back lighting has failed which could be several things that can cause that.
without any other details besides "broken" it will be hard for someone to help with diagnosing your problem. We need symptoms like. has sound but no picture. Picture has horizontal or vertical lines. part or half of the screen is black, black borders don't count. Hope the info here has, in some way, helped bring you closer to what to do with your TV.
Mar 26, 2014 | Toshiba 32L1300U 32" LED TV 1280x720, 120...
Laptop is on but screen is black
Try an external screen. That will exclude the motherboard. Shine a bright light at the screen, if you can see a picture, the back light has failed.
Dec 30, 2013 | Toshiba satellite c660
Have Toshiba 42AV500U that has no back light.
I have an idea that your power supply has failed
Jun 06, 2013 | Toshiba 42AV500U 42 in. LCD HDTV
My tv powers on good, but has no picture
I need some help, no picture, no sound either or what? Also was set doing anything unusual before it failed?
Dec 09, 2012 | Toshiba 57HC85 57" Television
I have a Toshiba 50hp66 that the power light cycles from red to green with a simultaneous clicking of a relay on the power board. I check for power at a few points per the Toshiba service manual and iy is...
Check the fuses on the ysus & zsus boards. Are any fuses on boards open . Disconect power cabels to ysus board first {board on left} . put tv on . if the light is green the ysus board must be replaced.
Mar 28, 2010 | Toshiba TheaterWide 50HP16 50 in. Plasma...
Toshiba regza has sound but no picture.
Hello: One solution to see if the picture is there and you just don't have any back lighting is to take a flash light and shine it at the screen you if you see a faint picture in the background then the inverter boards has failed, and you have no back lighting. If you see no picture then more then likely the Main control board has failed or the power supply has problems.
Nov 08, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Toshiba 50HP16 Plasma tv has sound, no picture. Screen is flashing like a camera flash....on-off at random. Volume works with remote. No menu. Screen flickers/flashes. Power light in front is green. TV is...
Display IC seems to have gone. It will be a replaceable module. Only you have to figure out which one it is. Such thing happen in electronics. Look for any burnt or bulged IC.
Oct 07, 2009 | Toshiba TheaterWide 50HP16 50 in. Plasma...
No Picture - No Sound - Pilot lite OK - hear speakers 'blip' when turned on
Toshiba did have a problem with a protection ic that would fail. It is possible that this is the problem. But some trouble shooting will need to be done buy a repair shop.
Dec 06, 2007 | Toshiba 40H80 40" Rear Projection...
Toshiba 37X3030D 37 in. LCD TV/HD Combo Logo
80 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
