Download my wireless router on tv
Trying to put it on tv
  • 3,320 Answers
What tv? what router? tv connects to router, NOT the router to tv.
Posted on Mar 29, 2014
My router disconnects every hour and when I directly put the cable into the PC it works perfectly fine . can anyone tell the reason and fix it?
I think you are saying that when the router is wireless it disconnects and when you plug it in via Ethernet it never disconnects. This is a common occurrence. You might also be saying that your are bypassing the router and plugging the Ethernet from the cable or DSL modem directly into your PC. In any case you can try the diagnostics below:
First try the easy obvious fixes.
How far away are you from the wireless router when it is disconnecting? Try putting them next to each other when you are connected wirelessly. If they don't disconnect then the problem is they are too far apart. If the problem is resolved, try putting the router half as far away and see if it is OK at that distance. If the problem is a distance problem, put the router up higher or closer to your PC, or try moving the antennas around if there are antennae. This will look funny, but you can also put a sheet of aluminum foil on the side of the router opposite the PC, so the router is in between the foil and the PC, it will reflect the signal back to the router, and that might strengthen the signal enough.
It can also be interference from other electronic devices. Try putting the wireless router away from everything by at least 2 or 3 feet and see if that solves the problem.
It can also be a heat issue, make sure the wireless has enough air circulating around it. I had a router once that would overheat and then disconnect, then cool down and reconnect. I couldn't get that router to ever work correctly, it overheated often, so I upgraded to another wireless.
If none of those above helped ...
Then it has something to do with either the wireless router, or the wireless adapter on your PC. Do other devices also disconnect every hour? Can you borrow someone else laptop and see if they disconnect every hour also, if so then it is the router.
Now you have to get the router manual out because this will get a little advanced, what you want to do is update the router firmware if it needs it. First check what version of the firmware you have on the router. You can do this usually by clicking here in this browser on your PC http://192.168.1.1 if that doesn't work try this http://192.168.0.1 if that doesn't work read the manual and see what the address is to check the firmware of your router. Usually you will use your browser and type in a number similar to the one above. You will need a username and password to login to the router. Find the version number of the firmware that you have loaded on this router. Write that down.
Look at the back of the router, write down the exact model number and version of the wireless router. They usually will have a version. Now search for that model number and version and also for the words "firmware download". If this version is newer then download it to your PC. If it is newer then start the router firmware upgrade process. Plug the router directly into the PC with an Ethernet cable, connect to the router thru the Ethernet only using the 192.168.X.X address above. (probably need to disable wireless on the PC to make sure it is going thru the Ethernet). read the manual how to backup the router. Back it up to the PC if you can. Or write down all the settings and passwords on paper. But backup somehow. Double triple check you got the right firmware for the right model. Now read thoroughly how to upgrade the firmware for your model router, not always, but usually a matter of going to the right page inside the router, then click on upgrade firmware and browse to the firmware file you downloaded above. Then make sure you wait till the upgrade process is complete. Do not disturb it while it is in process. OK, now after rebooting the router check if the connection is stable.
If that didn't work then you can do a similar process for your PC and see if your wireless adapter needs to have the firmware updated, but usually it gets updated when the PC does, but check anyway.
If none of the above work, then time for a new router. Luckily they are not too expensive. If after you buy a new router you still have issues then sorry, it was probably the PC.
Aug 29, 2014 | D-Link Dlink Dir-600 Wireless Router...
I cant connect to 192.168.1.1 using my comtrend CT-5372 router
Check that is the actual address in use. They might have set up something else. In a DOS (cmd.exe) window use 'ipconfig' to see what the gateway address is. Use ping 192.168.1.1 to see if it is really there.
If you want password protection, you have to manage the router yourself. Download the manual and use the 'reset' button to take ownership of the router.
Sep 09, 2012 | Comtrend Computers & Internet
Can I Put my Lynksis Wireless-G 2.4 in my Laptop? Also does anyone know how to fix the back light in this computer?
Routers do not operate on the same frequencies as the old tv bands. So no. To the other questions you won't put a router in a laptop you would use a wireless adapter which 99% of laptops already have. Last question if the back light is out it is most likely the inverter board is bad. These run $40-120 and are fairly high degree of difficult to replace.
May 30, 2012 | Linksys Wireless-G WRT54G Router
I have Time Warner cable and use vonage. My set up is a D-Link Model: WWR-VR vonage router and an SMC8014W-G EZ connect wireless router provided from time warner. The cable internet is connected to the...
Welcome to Fixya. I would like to know the location of the wireless router and the wireless computer and the google tv. Are they in a same room, same floor? any walls or obstacles that can block the wireless signal? any other device that has the same issue with the router when put in a same room? Please provide the information needed to be able to fix the issue.
Thanks
Sep 09, 2011 | Linksys Wireless-G Broadband Router
Everything works well on my wireless linksys e2000 router my itouch, my computer except my samsung wireless lan adapter wis09abgn cant seem to connect to the internet on my Tv i plugged it in the usb slot...
IT looks like it might not be accepting the type of security on the router..try changing the security typa it might work.
(P.S. YOu might need to re-connect all the wireless computers to the new network once you change the security.)
Hope this helped.
Feb 13, 2011 | Computers & Internet
New router no download speed
I would recommend trying to shut down the nortons or any other firewalls and trying a speedtest,maybe at speedtest.net, then put the firewalls back up one at a time and see if one of them is slowing you down. this is usually the case
May 03, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I have wireless-G WRT54G2 V1...the signal coverage is weak. If it is more than about 5 m then the signal is lost. Any clue how to fix
the easiest solution is to buy a wireless expander.
http://www.linksysbycisco.com/US/en/products/WRE54G
this will expand the range of your current router.
however before buying check the following:
your router is not near wireless land telephones, near a tv, or near any other obstacles that could block the signal.
try to put your router somewhere high.
Jan 24, 2010 | Linksys Wireless-G WRT54G Router
I HAVE A SIEMENS SL2_141 ADSL WIRELESS ROUTER.I AM
first off make sure your wired in when your trying to configure setting on the router, second try manually setting your ip on the machine your using to 192.168.1.100 while your using these. one more thing, dont use "http://" just use the actual address
Apr 11, 2009 | Siemens Televison & Video
Router will not connect with on demand direct tv
I had the same problem. I fixed everthing by updating the router's driver. Try that and see if it works.
Mar 01, 2009 | Linksys WRT160N Wireless Router
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
