Question about Dell, Inc Dell Color Printer C1760nw - printer - color - color - LED - LED
Paper stuck in printer
Small piece of paper stuck
    Master:
  • 397 Answers
The best thing to do is gently try to remove it, without tearing it and leaving chunks behind. A pair of tweezers can be a great help. Some printers have a "feed" option to manually feed the paper. You might want to try it if your printer has the facility, feeding will turn the rollers and potentially release the paper. Be careful and check direction of feed as it could just as likely make the problem worse if it feeds the paper further into the printer.
Posted on Mar 27, 2014
CannonMP495- paper jam when there isn't
Because there might be small dust/paper part would be stucked at the roller sensor just make sure and make it clean you can find some dust or small paper piece stucked with your roller so its showing paper jam error when theres no paper inside.
Aug 12, 2011 | Canon PIXMA MP495 InkJet Printer
Printer keeps saying i got a jammed paper there is no jammed paper
There are many places in a printer where a small piece of paper can get stuck. It's not always a sheet of paper. Open all the access panels and check the roller track for pieces of paper. If it is clear, unplug the printer for a few seconds and the plug it back in. This should clear the problem if it was in error. Also check the paper feed for too many sheets stuck together jamming the feed. Before loading paper always "fan" the paper first to avoid sheets being stuck together.
Apr 14, 2011 | Canon Office Equipment & Supplies
It says my printer has a paper jam but i dont see no paper jamed and i refill it and it says say thing like it would let it go like its going to print then says jamed paper
Try and see if you can locate a small piece of paper that might be causing your printer to jam. Turn the rollers and see if you can see any small pieces of paper stuck in between the rollers.
Mar 02, 2011 | Canon Pixma iP2600 Photo InkJet Printer
A warning sign has appeared on the printer, which says: 'Paper is jammed in the printer. Turn off the printer, open the scanner unit, and remove the paper. See your documention'. But There is no paper...
either a sensor broke
or
a small tiny piece of paper is stuck
after removing a jam if the paper tears a small piece of paper can cause the jam error message
Jan 19, 2011 | Office Equipment & Supplies
Lexmark T642 Printer giving me a paperjam error#241.10. There is no paperjam
Normally this is caused by either a small piece of paper stuck in a sensor or a bad sensor. Lots of times printers use optical detectors and it may just have paper dust causing a sensor to think there is a stuck piece of paper. Give the printer a through cleaning and let me know what happens.
Mar 20, 2010 | Lexmark T640 Laser Printer
Paper jam, removed paper but still says jammed. Is there any way to tell where the jam is or reset machine ?
You should be able to have a piece of paper feed all the way without hanging.
Most of the times, you can see a small piece of paper stuck in a corner.
I have used a cut piece of plastic ( from a file folder ) and worked small pieces out that way.
Good luck, Happy Holiday's
Nov 30, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Printer error MP 970
try and print another piece of paper and it should come out
or take the ink cartrages out and take the bottem platform off
there should be another box looking thing take it and slide it over
then you should be able to see the paper
Dec 11, 2008 | Canon MP970 Photo All-In-One InkJet...
Showing paper jam but no paper in machine help!!!!
please confirm that all paper detecting switches are in normal position and can move freely and no small pieces of torn paper inside-clean all switches with dry cloths or brush.-reset your copier off-on-operation.
Jul 22, 2008 | Office Equipment & Supplies
Paper stuck
you have to open the printer and cleaned the pieces otherwise send it to some qualified professional for servicing
May 16, 2008 | Samsung CLP 300 Laser Printer
Paper Jam
Probably some piece of paper stuck in the printer, try looking for small pieces of paper that might confuse the sensors.
May 19, 2006 | HP PSC 1610 All-In-One InkJet Printer
Dell, Inc Dell Color Printer C1760nw - printer - color - color - LED - LED Logo
69 people viewed this question
Top Dell, Inc Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Dell, Inc Office Equipment and Supply Expert? Answer questions, earn points and help others
