Question about Mastercool 90065-220
Our mastercool vacuum has stopped working
Our mastercool has stopped working and is extremely hot to touch i have tried turning it off and on again but it sounds as if there isnt any power to it?
My dirt devil keeps shutting off randomly
It's overheating. Empty the cup and replace the filters. There's a breaker that opens up and turns it off when it gets too hot. When it cools down it closes back up and it will run again. It'll argue with you til the end of time or until you fix the problem.
Good Luck
Jan 13, 2013 | Dirt Devil M085805 Upright Vacuum
My dyson dc 24 smells and sounds as though it is crackling it also got hot ,I let it cool down and tried it again but it did it again
I'm sorry to hear about this - I'd recommend that you don't turn the machine on again, and get in touch with us as soon as possible so we can help. You can call us free on 0800 298 0298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Oct 31, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I bought a reconditioned mop 7 months ago. It worked fine until tonight. The light comes on, but the steam is not hot, well, the pad didn't get hot at all. I heard like a small explosion of some sort....
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Nov 13, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Electrolux central vaccum works sporadically
The the hose, wands and power nozzle to the nearest AERUS store for repair. You have a short that needs to be fixed. They should just be able to replace the wire assemblies inside the wands, handle and power nozzle.
Jun 09, 2010 | Electrolux Central Vacuum
Brush is not rolling. I have checked the belts
Unhook the belt see if the motor shaft turns by itself. If it doesn't then the motor is the issue. If it runs then its probably the belt or the brush roll.
Dec 01, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
FQ95x...motor gets very hot very fast
It sounds like you have a blockage either in your hose or the carpet sweeper. Try dropping a coin through the hose. If it comes out then check the sweeper.
Jul 15, 2009 | Rainbow 75th Anniversary Canister Vacuum
Kenmore bagless upright Model # 116.35726401
There is actually an internal fuse in the vacuum. You may have blown this. The circuit board connected to the ON/OFF touch pad may be bad too but probably unlikely. There is also an overheat sensor that trips the vacuum off when it gets too hot. This could be bad preventing it from coming on too. All of these solutions, require you to open the vacuum to fix.
Sep 25, 2008 | Kenmore Progressive Bagless Upright with...
Dirt Devil Upright Bagless
The cord may be bad, you may want to have it replaced, or have it checked before you get a bad shock.
Mar 12, 2008 | Dirt Devil M087500 Bagless Upright Vacuum
Mastercool 90065-220 Logo
20 people viewed this question
Top Mastercool Vacuums Experts
JoeVacs
Are you a Mastercool Vacuum Expert? Answer questions, earn points and help others
