Question about Mastercool 90065-220
Mastercool 142ltt/min has stopped working
Our mastercool has just stopped working and is extremely hot to touch there seems to be no power to it?
I have a Hoover Rewind, the plug always got hot, tonight it just stopped working, I know it is not expensive and older but I really don't want to buy a new one if I can avoid it at this moment
I am not sure of the motor wattage but it is unlikely to exceed 2kw and is probably much less so that sort of load being plugged into a power outlet capable of safely delivering a much larger current is unlikely to cause heating of the plug. That the plug did become hot indicates a poor contact between the supply cables and power outlet, between the power outlet and plug or what seems the most likely, between the plug and the power cord.
Given that the plug has been getting hot and that most breakdowns of portable appliances including vacs are internal breaks of the power cord usually at or somewhere near the plug, so that would be a good place to start testing...
Mar 02, 2017 | Hoover Vacuums
Hoover bagged wind tunnel 2 vacuum turns its self off after about 10 min. of normal vacuuming I can press the power button right away and the vacuum will turn back on and vacuum for sometime as long as 5...
There is a thermal sensor in the motor which shuts power off if it gets too hot but usually it won't turn back on until it cools down. It seems you might have a defective switch
Oct 06, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
My dirt devil keeps shutting off randomly
It's overheating. Empty the cup and replace the filters. There's a breaker that opens up and turns it off when it gets too hot. When it cools down it closes back up and it will run again. It'll argue with you til the end of time or until you fix the problem.
Good Luck
Jan 13, 2013 | Dirt Devil M085805 Upright Vacuum
Ball filter is popping up, stopping ball rotating and ball area is getting hot
I'm sorry to hear you're having difficulties with your DC25 Animal. If the filter inside the Ball will not stay in place during use, please make sure that when you refit it, it locks into place with an audible 'click'.
I can confirm it's normal for your Dyson to become warm during use, but if you're concerned that it seems excessively hot, I'd encourage you to get in touch with us directly so we can help. You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 16, 2012 | Dyson DC25 Animal Bagless Upright Vacuum
I bought a reconditioned mop 7 months ago. It worked fine until tonight. The light comes on, but the steam is not hot, well, the pad didn't get hot at all. I heard like a small explosion of some sort....
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Nov 13, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Electrolux central vaccum works sporadically
The the hose, wands and power nozzle to the nearest AERUS store for repair. You have a short that needs to be fixed. They should just be able to replace the wire assemblies inside the wands, handle and power nozzle.
Jun 09, 2010 | Electrolux Central Vacuum
Turning off / overheating?
Reading of another poster's similar issue caused me to realize there was indeed a third filter in this bagless vacuum cleaner. It was saturated with thick dust that was difficult to remove. Cleaning it cured the problem and I will know better next time to read my manual when I purchase a new item.
I do agree with other readers though that this particular vacuum is not savvy when it comes to picking up dog hair. It would rather push it around for a while then do the job right.
Jun 13, 2009 | Bissell 37604 Lift-Off Pet Bagless Upright...
Power Unit VX475 Stops Working
The problem is definetly the motor. make sure the filter is not covered in the hair, if not you need a new motor. i fixed plenty of them.
Jan 31, 2009 | Broan-NuTone VX475 Bagged Central System...
Belt is hot to touch
If the belt is hot or you smell it burning then chances are it has stretched a little and is slipping on either the motor shaft or beater bar shaft. If you are sure the beater bar is not restricted from turning then I would just replace it. Try this.. With the power cord disconnected, open the vac head to gain access to the beater brush and belt.. then remove the belt.. place the beater bar back into its holder and see if it easily turns by hand.. if it is free to turn..then plug the vac in and turn it on for a few seconds.. you will see and hear the motor come on but you should NOT smell anything burning at that time. If you do.. you may have another issue with the motor or power cord or both.. if you don't smell anything burning, then disconnect the power and just replace the belt.... Good luck.
Sep 12, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Mastercool 90065-220 Logo
16 people viewed this question
Top Mastercool Vacuums Experts
JoeVacs
Are you a Mastercool Vacuum Expert? Answer questions, earn points and help others
