Question about Philips Dcm292 Micro Music System With Ipod And Iphone
Reset Philips Dcm292
Hard reset for new remote control unit ...
Dcm292 philips no audio all other functions ok
Check the speaker/s first. If it is OK, check and replace the damaged component/s at its audio output section circuit. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 02, 2016 | Philips DCM292 Mini Audio System
I have a Philips tv model 32pack4507. It was working but I can't get it back on either manually or with a remote. Do I need part or new tv
Check batteries in remote. Or possibly a new universal remote. I just purchaced a RCA universal remote. Works better than the original factory remote, and easy to program to the correct code.
Apr 14, 2015 | Philips Televison & Video
Digital tv channel stuck on Setup blue screen
Just contininue to try that it if not then you'll have to do a hard reset.
Feb 01, 2014 | Philips Televison & Video
Philiips dcm292-37 home audio; door in front keeps opening and closing on its own; won't play cd. door closes quarter of the way when powered off and opens quarter of the way when powered, then opens and...
Hello.
Sounds like a mechanical problem with the CD drive.
There is a one-year warranty with product. If your product is still under warranty, contact Philips for a repair or replacement.
TO OBTAIN ASSISTANCE IN THE U.S.A., PUERTO
RICO, OR U.S. VIRGIN ISLANDS...
Contact Philips Customer Care Center at:
1-888-PHILIPS (1-888-744-5477)
TO OBTAIN ASSISTANCE IN CANADA...
1-888-PHILIPS (1-888-744-5477) - (English or Spanish Speaking)
Hope this helps.
Mar 22, 2011 | Audio Players & Recorders
Philips remote control needs resetting to work with Panasonic TV
Hi Shirley,
Check this site, they normally have code lists for a huge number of remotes:
Remotes
Dec 17, 2009 | Philips Universal PH301S Remote Control
Philips universal remote control
first you will need to find the model number of the universal. look it up online for the manual and code book. you should probably get the original remote that goes with your unit. type in the model number of your unit in the search on ReplacementRemotes.com and find the OEM remote.
Dec 21, 2008 | Philips Magnavox Learning Universal Remote
Philips RC4318 Remote Issue
SOLVED!!!! Make hard reset of the remote control:
1. Five seconds Mute & Menu buttons 2. Press Select untill four lights comes up, exept TV 3. Press OK That's it! Get your remote control as a new :)
Sep 14, 2008 | Philips 50PF9630A 50 in. Plasma Television
Can't turn off child safety lock
Go to the philips site and download the full manual. There's the child lock reset key instructions there too. This link might help.
Michael
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=DVP721VR/05&scy=GB&slg=ENG&grp=HOME_ENTERTAINMENT_GR&cat=DVD_HOME_THEATER_CA&sct=DVD_COMBIS_SU
Apr 30, 2008 | Philips DVP721VR DVD Player/VCR
Problem, please help
The unit should be under warranty. What you're describing is not normal and I would attempt to get a replacement from the place of purchase or take the unit to an authorized repair center. Below is the Philips support page for your unit. You can check warranty status as well as request repair.
Philips 42PFL5332D/37
Dec 07, 2007 | Philips 42PFL5332D 42 in. LCD Television
Philips Dcm292 Micro Music System With Ipod And Iphone Logo
52 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
